Gen2 Gas Mileage Mystery - Better going over Hill than on Flat !?!
Discussion in 'Gen 2 Prius Fuel Economy' started by DashingDave, Feb 13, 2026.
  1. DashingDave
    DashingDave Junior Member
    39
    Monterey
    From time to time I drive a Gen2 over Pacheco Pass in California (about 1300 foot / 400 meter rise).
    Puzzlingly (but not at all unwelcome) I consistently get better mileage reported (onscreen)
    for the total Up and down (~54-55mpg) - than in the subsequent miles driven over the flat Central Valley toward Yosemite (roughly 51-52mpg).
    Yes, I know I'm going varying speeds heading up and down.
    On the looong downhill section I do get up to freeway speeds (~65-70),
    versus maybe 40-ish going up the steep portion.
    Pacheco Pass - Wikipedia
    Any evidence based clues on what unusual engineering is going on here?
    #1 DashingDave, Feb 13, 2026
  2. Dany Dan
    Dany Dan Member
    57
    Québec, Canada
    2024 Prius Prime
    SE
    We're not in the generation 5 section by chance...
  3. Trollbait
    12,777
    Climbing the hill requires a higher load on the engine. For a gasoline powered one, that means a wider open throttle. More gas burned, but pumping losses are reduced, so that fuel is burned more efficiently. Then there is the coast down the other side. Even if the engine isn't shut down, little fuel is supplied to it then.
    This is why pulse and coast can improve fuel economy in any car.
  4. VelvetFoot
    VelvetFoot Senior Member
    1,388
    538
    New York State
    2026 Prius
    It's an estimate.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,970
    912
    Southern California
    I'm not sure how one would determine the mpg like that with any accuracy. The display gives a number, but I have never found those numbers to be very accurate. For instance, if it says a tank was 45 overall the actual miles and gas added to the tank usually come out more like 42.5 - 43. It is definitely true though that one can almost coast from the top of the pass until where it flattens out past the base of the dam, with just a few brief regions that are uphill. The elevation change is 417 meters at the top to around 50 meters at the 33 and 152 intersection, so 367 meter drop.
    I don't go up that grade at 40 mph though, unless stuck behind a truck or other traffic. When the traffic is moving well vehicles will come roaring up on one's butt with closing velocities of 20-30 mph, which is not conducive to a restful drive.
  6. Mechanic40years
    Mechanic40years Junior Member
    "I don't go up that grade at 40 mph though, unless stuck behind a truck or other traffic."
    :LOL: Going up the West side is so steep, somehow my Gen2 isn't happy going much more than 40mph. :LOL:
    Plus as you mentioned, due to the steepness, slow trucks nearly always block my ability to go faster anyway.o_O
    Still looking for an evidence based explanation for why up and down hills gets significant better mileage.
