Next-level Fuel Economy
Discussion in 'Prius c Fuel Economy' started by Leadfoot J. McCoalroller, May 6, 2026 at 10:23 AM.
  1. Leadfoot J. McCoalroller
    8,175
    7,680
    Pennsylvania
    2018 Prius c
    I'm posting this in the Prius c forum though the topic surely applies to all cars.
    With fuel prices somewhat elevated (May 2026) and on their way to record heights, I've started looking deeper at improving fuel economy.
    There aren't likely to be any revelations here; just little improvements that weren't quite worth capturing previously.
    The challenge I'm making for myself is to use tools I already own (mostly a spreadsheet and some mapping apps) to make some money-saving decisions. I'm not interested in modifying the car or using an anti-social driving technique- besides, that's already been explored heavily in other threads.
    I looked at the driving I need to do today and found that I can save about $0.73 by driving alternate routes through the city at lower speed. The overall trip will be about two miles shorter, and it will be done at a higher fuel economy due to the lower speeds involved and I'll spend about seven more minutes driving it.
    So far, this looks worthwhile.
    I'm curious to learn if there are any good mapping apps which help the user to prioritize fuel economy over simple trip duration. It is officially time for that feature.
    #1 Leadfoot J. McCoalroller, May 6, 2026 at 10:23 AM
    Isaac Zachary likes this.
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,703
    1,424
    I haven't had any success with mapping apps, but then again I don't live where traffic can change to the point that a mapping app can point me to a route with less traffic on it.
    Hypermiling does help. I have gotten well above 40 mpg in my 40-mpg-rated Avalon hybrid by hypermiling. Basically, you push the accelerator until the ECO needle is on the line right between ECO and POWER, you get up to your acceptable top speed for when the engine will shut itself off (the Avalon will do that around 45 mph), and when it does you shift into neutral and coast back down to your acceptable lower speed. Then you put it in D and do it all over again. This pulse-n-glide technique causes the engine to be running either at its most efficient load or not run at all and to keep cycling between the two.
    I'd be interested in aeromods, but those really only help at higher speeds. Most of my driving is around town.
    As much as I hate the idea of riding my bike due to the fact that it's basically suicide with the way people drive these days, I'm thinking I really need to get back into it too.
  3. Mendel Leisk
    42,052
    If the object is to spend less money on gas, besides improving efficiency, consider also reduction of driving, and consolidation of errands.
  4. rjparker
    10,674
    6,706
    That works for retired people but is not effective for the majority who still work using their vehicles or have a serious commute five days a week. Companies experimented with remote work but have largely dumped it due to the obvious efficiency losses and inability to judge work ethic and management potentials.
    Merkey and Mendel Leisk like this.
  5. PriusCamper
    PriusCamper Senior Member
    13,201
    5,346
    Pacific Northwest, USA
    One thing that's helping me save money is owning multiple Prius and loaning them out for free, which usually leads to the person borrowing it filling the gas tank... :) Only bought one tank of gas so far in 2026. :)
    But when it comes to Prius C, I have one coming in for 100K mile maintenance and I'm wondering about the EGR system and if it ever gets clogged and requires the same amount of cleaning? Also what beyond spark plugs and Oil change and MAF sensor and throttle body? Got any links to the best thread for that?
  6. PriusCamper
    13,201
    5,346
    I'd argue remote work was killed because of how much money companies have put into their real estate and the need to justify its existence. Whereas to Government agencies like here in Washington State it's way more efficient and is an enormous money saver, which has also reduced rush hour traffic.
    As for age, It really doesn't have as much to do with that as where you decide to live... People who don't like crowded noisy cities and live a significant drive from town are gonna spend a fortune in coming years because every time they need something they have to get in their car...
    As for me in the PNW I used to live rural and it was heartbreaking to see so many vacant lots with big huge trees growing on 'em get destroyed for new housing. But a year and a half ago I moved to within a 2-3 blocks of all the major stores and places to eat and the big trees in this neighborhood were mostly wiped out a century ago. Took me a while to get out of the habit of driving. But I'm more and more often having days where I don't need to drive at all. Also have way more tree pruning and gardening jobs that are just a short walk away. So grateful that I'm no longer required to get in my car if I need to go somewhere. It took some time getting use to a life at walking speed.
    #6 PriusCamper, May 6, 2026 at 1:31 PM
  7. Isaac Zachary
    2,703
    1,424
    It can still be a consideration.
    A family that makes a shopping list that they go get once a week after coming home from work or that one of the working adults swings by and gets on his or her way home from work will use less fuel than one that goes to the store whenever they need an ingredient on the whim.
    Also making sure you have a valid payment method on you before driving is always helpful.
    Prius c Maintenance Schedule | PriusChat
    The only thing I absolutely disagree with is yearly/10,000 mile oil changes. This will destroy the engine before 200,000 miles. The manual says do 5,000 mile or 6 month oil changes (whichever comes first). If you're doing more than 10,000 miles a year than go with every 5,000 miles (at 95,000, 100,000, 105,000, etc.) If you're doing less than 10,000 miles a year then change every 6 months (every spring/fall equinox, or every summer/winter solstice.) The way I understand the manual is you can do yearly or 10,000 mile oil changes if you live in Pheonix, AZ and only drive on the highway on flat ground with no cargo box or trailer, etc.
    Sparkplugs: every 12 years or 120,000 miles.
    I don't think you need to do anything to the MAF sensor or throttle body unless you get a check engine light.
  8. Leadfoot J. McCoalroller
    8,175
    7,680
    Pennsylvania
    2018 Prius c
    I think the general idea I'm chasing is that I'm going to add trips to my spreadsheet, and I'll do it in two ways.
    One is a prediction of savings for two different routes to the same destination.
    The other will be a record of actual results.
    I figure once I get a few trips of each route in there, I can use this to pick the most economical routes to various local neighborhoods.
    When I compare the prediction to the actual for today's trips, I see that the savings were a little short. I attribute this to the fact that the route selected by the computer (optimized for distance) included a couple of hill pulls- I could probably have done better by driving 10% more distance without the elevation change. Around the hill vs. over it.
    That just brings me back to wanting a friendly mobile mapping app that can be optimized for fuel economy rather than simple trip time or A-B distance.
    It's a tantalizing goal- let's burn a few watts on computation to prevent burning many more on transportation.
    It was a waste of time at $2.50/gallon. It's a curiosity while we're knocking on $5. It'll be pretty darn important when we hit $10.
  9. notspam3
    notspam3 Member
    118
    65
    Toronto
    2024 Prius Prime
    XSE Premium
    Don't forget that weight is your enemy for fuel economy. Remove unnecessary items and clutter from your car.
    If you drive to the same destination every day it is easier to pick routes to minimize start-stops and hills. You will do better with constant speed routes with lower speeds.
    I'm not a fan of apps and AI routing, they don't always make the most sense because they have their own paradigms when it comes to route selection and their solutions are not the most sensible when it comes to fuel economy.
    We are getting to the $8/gallon $1.95/L range here as oil companies are quick to jack up prices and slow to reduce them. It's a supply and demand problem. When demand is high prices go up. When supply goes up prices go up. When demand is low prices go up...
    VelvetFoot likes this.
  10. Starship_Enterprius
    Starship_Enterprius Active Member
    333
    163
    Ottawa, Ontario
    2018 Prius Prime
    lol... might as well start removing seats, linings, sun visors, spare tire, and gas only for the days commute. After that add moon caps, wheel skirts, taped joints, and aero dynamic tails.
  11. Isaac Zachary
    2,703
    1,424
    The advantage or not from doing this is affected by what kind of driving.
    The more someone has to slow down and start back up (e.g. stop-n-go traffic, neighborhood streets with stop signs or stop lights, etc.) the more weight hinders fuel economy. Regenerative braking helps, but no system is 100% efficient.
    If you cruise along at a constant speed then weight will contribute towards rolling resistance, but rolling resistance usually isn't all that much in comparison to aerodynamic drag.
    So, while driving around neighborhoods aeromods don't help that much but weight reduction does. And while weight reduction isn't going to help all that much while cruising down a highway at a constant speed, aeromods can help on that same highway.
    But the way we drive can also have just as much of an effect. Driving slower in general produces less aerodynamic drag without any aeromods. And speeding up at steady rates with the engine RPMs kind of low and load at around 80% and then start slowing down long before you have to stop or turn also reduces losses due to braking and engine inefficiencies.
    Of course, a lot of use do mixed driving. And every little bit helps.
  12. Leadfoot J. McCoalroller
    8,175
    7,680
    Pennsylvania
    2018 Prius c
    I don't have a normal commute, so there is no optimization to be done there. But there's still a school run at each end of the day, and often other errands get added to one of those trips or the other, which is why I like working from a map app to help optimize things.
    I did a trip to the little food markets today after the school drop. I went through the city instead of on the highway that goes around town. Shorter route, lower speeds, significantly higher MPG, and one nice side bonus- a lot fewer pickups and commercial vehicles on the same route. It took a few more minutes, but I had the time today.
  13. notspam3
    notspam3 Member
    118
    65
    Toronto
    2024 Prius Prime
    XSE Premium
    Don't forget that your A/C usage will affect your fuel economy
    So does keeping useless items hanging off your vehicle
  14. Starship_Enterprius
    333
    163
    Ottawa, Ontario
    2018 Prius Prime
    The Prius hvac is so efficient i no longer worry about it. Once the engine is fully warmed and the cabin set to the preferred temp, I could sit in my Prime for hours in winter/summer and barely affect my charge.
  15. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    This is a misconception (and I can guess where you picked it up, because I did too on the same forum). Even at 60-65 mph, rolling drag is nearly as much as aerodynamic drag on a lot of cars, and the break-even speed goes higher as vehicle weight goes up (e.g. EVs). Plus, in the end resistance force is resistance force, and making it smaller by reducing weight or reducing aerodynamic drag will both affect fuel economy. Rolling drag also goes up with speed, not as quickly as aerodynamic drag but it still increases.
    Fuel economy is a function of overall vehicle efficiency (which is the product of thermal efficiency and propulsive efficiency), the energy available per unit of fuel (Q), and resistance force (F). Reduce resistance force in whatever way you can (weight or aero) and, if overall efficiency doesn't change, fuel economy will go up. Put this in a spreadsheet, convert everything to like units, and plug in dimensions of your own car and you can model how and how much fuel economy changes with changes in things like drag coefficient and vehicle weight at any given speed. At steady-state with the gas engine running, overall efficiency can't be larger than engine thermal efficiency, so if you know that (which Toyota has published for every[?] generation of Prius) you can plug it in to find theoretical maximum steady-state fuel economy:
    Driving techniques like hypermiling increase that first variable by running the engine closer to its peak thermal efficiency more of the time, or coasting using little or no fuel so you effectively get distance traveled with minimal or no energy input, or in the case of a hybrid or EV capturing kinetic energy through regenerative braking etc. Since both F and overall efficiency are functions of speed (among other things), it's all about finding that balance on your car, on your routes, with your driving profile if your goal is maximizing fuel economy.
    I did some quick road testing this week to estimate steady-state overall efficiency of my Prius, and will be putting up a post about how to do it soon (after my brother does the same test on his Model 3 for comparison, which should show much higher overall efficiency):
  16. Isaac Zachary
    2,703
    1,424
    I still don't think it's a misconception. The degree to which it might not be as applicable in a certain depends on the car in question. What percent of cars on the road break even between rolling resistance and aerodrag at 60 to 65 mph? Do pickups break even at that speed? What about boxy SUVs? What about older cars? Not everyone is driving a Tesla or similar.
  17. Leadfoot J. McCoalroller
    8,175
    7,680
    Pennsylvania
    2018 Prius c
    I've been looking into using an AI widget to help out.
    The idea is that at the conclusion of a trip, I'd record a brief audio message: "Origin, destination, route note, distance traveled and reported MPG" I'd be reading the distance traveled and reported MPG from the Prius' "goodbye" screen.
    The AI transcribes that into 5 cells in an online spreadsheet and moves on to the next row.
    Just a clean way to gather and organize data for later analysis.
