Featured EVs have fewer repairs?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Moving Right Along, Jun 22, 2017.
  1. EVs will have more problems
    2 vote(s)
    6.9%
  2. EVs will have the same number of problems
    6 vote(s)
    20.7%
  3. EVs will have less problems
    21 vote(s)
    72.4%
  1. bwilson4web
    16,552
    Not in the Common Wealth since the Sunday Mail was sued by Sudbury for slander. <GRINS>
    hill likes this.
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Not so, gear oil is also present, but it tends to be treated as a lifetime fill.
    Also, smog checks aren't wear items, but they are expenditures related to the legal operation of the vehicle in the areas where they're required.
    Robert Holt and Trollbait like this.
  3. Trollbait
    12,832
    It has to do with the large investment Toyota made into the entire production line for NiMH batteries, and they like to squeeze their investments dry. Just look to the Yaris and Corollal models in the US. They were and still are using 4 speed automatics for years after the competition switched to more efficient models, and their engines are dated in terms of technology the company has available.
    BASF had an announcement a few years ago now that NiMH has room for improvement. The main hurdle for it is cost. The required nickel simply costs more than lithium. To everyone except for perhaps Toyota, Li-ion is cheaper than NiMH at this point in time. maybe BASF will come through with what they say, but that won't change the fact that nickel is simply a rarer element here on Earth.
  4. bwilson4web
    16,552
    We'll I've got my spare Gen-1 pack stored with the Kugerands.
  5. 3PriusMike
    3,101
    2,421
    Silicon Valley
    The only real measure it lifetime maintenance costs...or at least 10 or 12 years.
    But we don't have that much data yet on EVs.
    Mike
  6. bisco
    52,902
    unfortunately, after 25 years of hybrids, there are still very few repair shops outside of dealerships.
    I hope ev repair becomes more commonplace, but it won't as long as we're fixated on gassers
  7. Isaac Zachary
    Isaac Zachary Senior Member
    2,787
    1,506
    It seems to me that mechanical repair is becoming less and less common in general. It's more about general maintenance and then suddenly, "Oh! You know you need a new engine (or transmission, or both, or an HV battery as in the case of EVs) and it will cost more to fix than what the car is worth."
    bwilson4web likes this.
  8. bwilson4web
    16,552
    Assembly is optimized to reduce costs. Design for field repair is more expensive and seems to be a lost art. One that seems to be an anti-goal of manufacturing. For an extreme example, see ‘John Deer’.
  9. bisco
    52,902
    the trade off seems worth it to keep new car prices down. I want to explore car prices and inflation
  10. bisco
    52,902
    this is interesting.price-inflation
    the only problem is that you can't compare apples to apples. cars are so much better today than the 70's, when I first started driving.
  11. mikefocke
    4,083
    1,865
    Sanford, NC
    My first car was a 1960 Volvo PV544 in 1964. i suppose my 3 person family has had at least 30 cars in the intervening years. Every make and model under the sun (but no turbos nor plug-ins nor EVs).
    I have had a single failure I paid for by me (an Acura transmission at 70k miles due to a poor recall repair done 20k miles earlier by a dealer). Zero oil or exhaust repairs.
    And if I have a failure, I have dozens of convenient shops that know how to repair them.
  12. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    984
    Monument, Colorado USA
    My co-worker has a Tesla and had to replace tires after a year! Why? Because it will burn rubber on all 4 when you floor it and who doesn't like showing that off to folks??? (I made him show me twice!!)
    I haven't confirmed it, but heard car insurance can be 10-15% more than for an ICE vehicle...that would stink since rates are, already, insane here in mini-California...I mean, Colorado.
  13. bwilson4web
    16,552
    I changed to a different, longer wear, lower rolling resistance tires for my Model 3. Now I get ~60,000 miles out of them using:
    • Replace rear drive tires when wear bars are flush
    • Front tires to rear
    • New pair on front
    This minimizes tire costs while increasing from ~4 mi/kWh to ~4.5 mi/kWh. Still goes like scat in traffic.
    #73 bwilson4web, May 12, 2026
  14. mikefocke
    4,083
    1,865
    Sanford, NC
    You must not drive in the rain much. Down to the wear bars!?!? Any idea what that does to your stopping distance when there are puddles of rain in the tire ruts on the road? Google tirerack's tests. Scary how tread depth affects how fast you hit something with worn tires when newer ones would have stopped you. Can be as much as a 50 MPH difference.
    And was in a tire shop the other day and reading some of their signage while waiting. Was very specific about new tires go on the back.
  15. bwilson4web
    16,552
    We get a little wet in Dixie. Since March 2019, no surprises with one exception, OEM on front and my efficiency tires on rear.
    There was an unfortunate instability with FSD that limited cruise top speed:
    • Quality 4-wheel alignment raised critical speed 5 mph
    • Max sidewall pressure added another 5 mph
    • Replaced OEM tires and problem solved
    Manual steering had enough driver feedback to suppress the oscillation but defeated why I bought FSD.
    I do appreciate references to other sources. Retired engineer, I like to run my own tests as sometimes “common wisdom” is not so wise. <GRINS>
  16. bisco
    52,902
    over on the bolt forums, a few people only got 15k out of the front tires because the high torque can easily spin them from a stop.
    so far, at 13k, mine look like new, and most seem to get 40+.
    oems are Michelin self sealing.
    bolt has no scheduled maintenance until 5 year coolant change.
  17. Isaac Zachary
    2,787
    1,506
    Everything about car prices and comparisons to previous years is all an apples to oranges comparison:
    1. Before the 1950's cars were completely optional since suburbs didn't exist. Work was always within walking distance until suddenly it wasn't.
    2. Things that have really affected the current car market is used car prices and insurance. My goal is to spend no more than 10% of my income on transportation. How do I do that when my car insurance alone is nearly $400/mo?
    3. Car, fuel, maintenance, repair and insurance prices aren't the only prices to factor in. Cars expenses are part of living expenses. If other things, like houses, for example, cost more and people are paying a greater percent of their income on them then that leaves less income for other things like cars. Mommy and Daddy will either have to work 2 40-hour jobs or we have to pick only two or three of the following: food, shelter, transportation, healthcare.
  18. bisco
    52,902
    that's crazy! our insurance is $100./mo.
    Isaac Zachary likes this.
  19. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    Mine is around $200 a month with a new car and full coverage
  20. Isaac Zachary
    2,787
    1,506
    Maybe I should be more honest and include the disclaimer that this is with an adolescent on all our three cars.
    On the other hand, it was still about $200/mo for one car that wasn't new but did have full coverage. Oddly, adding a second car (liability only) reduced that to about $180/mo total for both cars. Then the adolescent came along and it's now more than double. Good thing she's found a job to help pay.
    bisco and ColoradoBoo like this.
