Might be time for new 12v battery for 2020 Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by The Big Sleaze, Dec 8, 2023.
  1. The Big Sleaze
    291
    68
    'frisco
    2020 Prius
    Two Eco
    Bought in late December 2020 but with a whole 40miles so maybe it was around for a few months prior and is the somewhat rare "Moonstone" interior.
    I've accidentally left the headlights on a couple times and run down the 12v to where it needed a jump. Didn't seem to take very long and last time I don't think it was more than 15minutes. My problem seems to be parking in brightly lit parking lots and fussing about for a bit before hopping out and not noticing the lights are still on.
    Questions:
    1)Is the Prime small 12V a different animal that normal car's 12v, because all it really does is boot computer, and power headlights (and run other 12v stuff only when car is "on" and 12v connected to Big Batt power)?
    Shouldn't it be a Deep Cycle or extra long life(calender long) because it doesn't need to crank engine?
    2)The owners manual is just under 800pgs, almost all various electrical related features and options. Is there anywhere that allows it to be set so IF the headlights are left on and car is turned off, they will auto-shut off to save the battery after maybe 5 minutes? Or auto shut off when it reads the 12V battery is getting low, such as before it would be unable to boot computer, to avoid need to jump start?
    3)Any pre-packaged add-on for cars in general to accomplish #2??? Seems like it would be a really nifty feature that could be added for almost zero cost. So many situations where it might be nice to have full headlights while getting into front door or walking down a dark street, and have them then shut off in a few minutes. IIRC my old 1972 Caddy might have had it but I never used it.
    4)Any particular 12v batteries recommended for Primes, or will I do just as good at Walmart or Autozone (where I can easily warranty if needed)?
    I have ordered a cheap $40 Jump Starter, which should be fine for the Prime because it only needs to be able to boot brains, not crank engine, and a set of Cig Plug with clips that should be able to boot brains off my big 10lb Power Bank I use to run laptops, etc, with Cig Socket. Big Power Bank is similar to this, with 12v Cig Socket.
    Duracell Portable Power Station 300W (292Wh/120V) Lithium Battery Backup Portable Solar Generator (Solar Panel Sold Separately) for Power Outages, Home Emergency Kits, Camping, Backyard, and Outdoor
    What would happen if... :)
    5) I took out the Prime's 12v lead acid battery and hooked the Primes battery terminals to some clips off the Power Bank's 12V outlet? Would it allow the Brains to Boot and run the car (except for high load stuff like engine cooling fan and HVAC). Then run from the car's Cig Lighter to charge the Power Bank! :) Not sure of Power Bank's 12V Cig Socket is strictly output, I'm guessing it is and Power Bank ONLY wants to charge from its charging port which is IIRC 15.5 or maybe standard laptop 18v.
    I'm not PLANNING on doing this, but might be nice to know if would for sure kill the whole car or not, if I get in some emergency situation.
    PS-I know you are never supposed to Jump Start another car FROM a Prime (unless you first completely disconnect the Prime's 12v battery).
    #1 The Big Sleaze, Dec 8, 2023
    SlaveToSoftware likes this.
  2. Doug McC
    Doug McC Senior Member
    1,087
    427
    Midwest
    2022 Prius
    If you have the Automatic headlights the timing can be adjusted in the Customization settings (page 692 in the 2022 Non Prime Owners Manual). The settings include 30, 60, and 90 seconds PLUS an Off setting for the 2022
  3. The Big Sleaze
    291
    68
    'frisco
    2020 Prius
    Two Eco
    I've got a base 2020 Prime LE so if that is an "if" I don't think so. Seems like something every car should have in this day and age, maybe even a Govt mandated feature with optional lock out (like if you really really DO want the headlights on for extended period. I'd bet leaving lights on and running down battery, hence at least temporarily bricking the car, has resulted in lots of real harm when people do other stuff to attempt to get out of the situation.
    IIRC as a battery drains it loses voltage so an aftermarket or DIY shut-off between battery and car's terminal shouldn't be too hard or expensive, but I'm electronically clueless. IMO it would sell like hot-cakes up at the front registrar of Auto-Parts store if priced under $20. Just one "save" will more than get your money's worth in time, effort, risk and 'fall out'. Plus its really bad for batteries to be run flat.
    WHOA, now I'm seeing this on other thread. "The new car warranty includes 36 months bumper to bumper coverage, which includes the 12V battery. Hence that warranty would have expired in ~ 2017, three years after the first sale." And IIRC I'm coming up on 3yrs in about 2 weeks! Maybe I'll think about taking it to dealer to see if they will Warranty the battery, but that will be a PIA to drop off and pick up, probably have them claim its barely within specs after that goose it with 50Amp charger THEN check it 3 seconds later, and send me out with damaged battery to boot.
    Reminds me of a story an old boss once told. He has new F-350 with extended warranty and the Tranny is slipping so he takes it to dealer and asks "should I get a rebuilt or brand new replacement A/T?" and the dealer says "Forget about rebuilt, nothing but problems, don't waste your time, it could be DANGEROUS like if your wife was driving and it starts slipping again as she is merging, etc, etc, BRAND NEW is the only way to go, costs more but what is your life worth?" Boss says "Glad I came to you! BTW I've got this extended warranty that covers the A/T" :) Said the dealer's face just fell. :(
    BTW this was a guy who'd buy a brand new truck at that same dealer like clockwork on schedule every 3yrs, and they still try to screw him if possible.
    #3 The Big Sleaze, Dec 8, 2023
  4. bisco
    52,645
    is there something wrong with the battery? i must have missed it
  5. The Big Sleaze
    291
    68
    'frisco
    2020 Prius
    Two Eco
    I'm thinking even with small 12v and WITH new low energy style lights it should be able to leave lights on for a LOT more than 15 minutes and still be able to Boot Brains.
    I'd let it run full flat a couple times overnight, which is really bad for batteries, so I'm wondering if its not on its last legs even if a bit early for SOP. Car has about 90K which is pretty high miles for that new.
    I'm wondering if specs for what a PRIME battery needs to do is radically different. I'm not seeing any sections for "12V batteries for HYBRID cars, for their unique usage profile", just standard line of normal batts in smaller size.
  6. BiomedO1
    4,409
    2,323
    Left Coast
    1. Your way beyond the 36,000 mile warranty and the car should be beeping at you when you try to exit with the lights on. The little green light bulb symbol is also lit on your dashboard, to let you know they're ON.
    2. If you want to leave your headlights on; leave the car in ready mode
    3. Get a jump pack, keep it charged up, throw it in the trunk and call it a day.
    I've noticed my Prime aux. battery is usually hovering around 12VDC, but always above 11VDC - this is with charging every evening.
    #6 BiomedO1, Dec 8, 2023
  7. bisco
    52,645
    that many miles on the car is good for the 12v, not bad. they like to be charged.
    people who don't drive much have the most problems.
    i'd stop by auto zone ad get the free load test before writing it off.
  8. The Big Sleaze
    291
    68
    'frisco
    2020 Prius
    Two Eco
    Another one of my habits is to wear earbuds and listen off my phone, so I guess I missed the beeping. I like earbuds more than even good car stereo because of their semi-noise reducing so the signal to noise ratio is better.
    Ready mode like this? Thx, didn't know it existed.
    I'll experiment and see if I can leave stuff going but not risk someone driving off if they smash out a window.
    Got the Jump Pack on order, plus I'll probably start carrying my big Power Bank, with 12v outlet and plug and clips, to charge up all my laptops, headlamps, phones, etc with the car off.
  9. The Big Sleaze
    291
    68
    'frisco
    2020 Prius
    Two Eco
    I've heard its the biggest of No-Nos to NEVER attempt to use a Prime (or other Prius) to jump start another car because it will see a big pull that can blow some big unit deep inside the system, costing thousands to dig out and fix.
    So I'm thinking I should at least completely disconnect the battery before any Load Test which is basically simulation of big time jump start. I'm thinking if car is fully "off" it COULD/SHOULD be OK to Load Test battery, but I'd be nervous.
  10. bisco
    52,645
    Or you could just replace it. Four years was a good run
  11. BiomedO1
    4,409
    2,323
    Left Coast
    No, Ready mode, green "ready" on MFD. Not sure the DC-DC converter is active in accessory mode, it probably is but it's a bad habit to get into. The car does beep at you, if you leave it running while exiting (ie. ready mode).
    Re load testing, you don't have to remove the battery to get it load tested. Your drawing power from the battery during this test. You may set-off the low battery sensor, if it's tested for too long and by an old style analog load tester, my preference. The cars DC-DC converter normally outputs 50A+ to run the car and recharge the aux. battery; that's why I always warn NEVER use the jump start function on a charger. Pushing more amps into a system designed to move less amps can destroy, weaken, and damage the system.
    Yes, never jump-start another car with your Prius. See the last sentences above. Jump boxes can't output a pure consistent 50A+, cold cranking amps calculations is another matter and most boxes has current limiters built in, that shuts down the unit so they don't catch fire.
    Hope this clears things up..
    FYI; I'm not sure about your head unit, but mine has automatic volume control, which compensates for road noise. It's still not as good as earbuds, but at least you'll hear the emergency vehicle coming towards you. But your an adult, do as you please:sneaky:
  12. Doug McC
    1,087
    427
    Midwest
    2022 Prius
    I did some checking and according to Toyota the Auto Headlights are not an “IF”.
    but are on your car. FWTW
  13. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    A battery load test does not stress any components. Get it tested.
    There is nothing special about a Prime 12 volt battery. While it isn't used to crank the gasoline engine there are not many other types in this size. A size 140R fits. As does an H4. And LN1. The three dimensions need to be close to original, height, width, length, as well as the terminal placement. If you want a longer lived battery for the Prime, look for one with the highest RC...reserve capacity. My choice was an AC Delco LN1 Absorbed Glass Mat (AGM) battery from Summit Racing with an RC of 80 minutes; the best price for an excellent long life battery. It has been working fine. Because the AGM batteries are sealed they can be shipped by UPS and the other usual suspects.
    Reserve Capacity is how many minutes the fully charged battery can supply 25 amps without dropping below 10.5 volts.
    My original battery lasted 5 years. I think I extended the life by giving it a full charge in the high 14 volt range a couple of times each year.
  14. SlaveToSoftware
    SlaveToSoftware Junior Member
    Westford MA
    2020 Prius Prime
    Thanks everyone for all the light shed on this topic. I've got a 2020 that needs a new 12V after six years of service. Not bad given I bought the car just before COVID hit which left me with no commute. The car sat so much the 12V would run down. I learned not to leave the car plugged into the wall for long stretches as the 12V has a drain when the car is plugged in. Reading this thread let me know the 12V battery doesn't turn over the engine, wow how far things have changed since my old 1969 Mustang Grande. Makes sense if you think how often the car might be starting the engine. I'm also going to install an extension on my trickle charger so I can keep it topped up when I'm not driving much.
    PHEVisthefuture and BiomedO1 like this.
  15. PHEVisthefuture
    PHEVisthefuture Junior Member
    76
    Illinois
    Trickle chargers are always a good idea for those with older 12V batteries. I don't have one, and my Prime's battery is original (date code 2017 with 106k miles) so if anyone has worries about their battery, a cheap Harbor Freight trickle charger or Noco battery tender (and a jump pack, doesn't need to be fancy) is all you need!
    This post reminded me to check my 12V battery lol. And charge my jump pack too. I don't know if 9 years is good but I'm hoping to get at least one more year out of the stock 12V (Toyota 12V batteries are awesome!)
