Parts fuel tank, how to test capacity before install?
Discussion in 'Gen 2 Prius Technical Discussion' started by foreverPriusCar, May 13, 2026.
  1. foreverPriusCar
    foreverPriusCar New Member
    24
    florida
    Title. Looking for a replacement tank. Maybe it's an exercise in futility but I'd like to see what my options are before eventually swapping to a Gen 9 Corolla fuel tank. Is there a way to test capacity before installing a used fuel tank?
    Can I fill it up with water then run the fuel pump to drain the tank. Then check how much was pumped out against the amount I put in? If good then fill up with premium and HEET to burn off residual water?
    TIA
  2. Tombukt2
    13,868
    2,520
    I don't think so . You could try it . Gas acts differently
    foreverPriusCar likes this.
  3. foreverPriusCar
    24
    florida
    Ah, that's what I was trying to avoid -- using actual gas to test with no real way of safely disposing of possible contaminated gas.
    for 50 bucks to remove a used one, I might try it.
  4. Tombukt2
    13,868
    2,520
    You could use another solution that acts kind of like gasoline maybe Stoddard solution that's what they're using dry cleaning kind of acts like the gas does expanding contracting etc . Water don't do nothing just sits there. Unless you're going to boil it in there or something. When I get to this we're going to be fooling with the Corolla tank matrix tank something but so far the 8 or so of these I had no gas issues . My 03 Corolla made 508K miles on original efi pump I changed it . Cats never been out of my sight much less worked on by anyone
  5. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    Got links of someone who has done that? Never read of Gen9 Corolla tank working in a 2006 Prius? Seems like the parts in a corolla fuels system would be entirely different than parts in Prius fuel system?
  6. PriusCamper
    13,468
    5,438
    Only option I've ever heard of that's possible is rolling the dice on a complete fuel tank assembly from a wrecked 2004-2009 Prius
  7. Tombukt2
    13,868
    2,520
    No Prius camper you remember the dude that was just here a few months ago that put in a Corolla tank and put pressure sensor in a yeti cup had pictures rt here . You was here! Wasn't really that messy either
  8. Tombukt2
    13,868
    2,520
    I think he put a little tiny dent in the tank to slip it up past something not to kill it just a lil one I think . The guy hasn't posted since so I'm guessing everything is good
  9. PriusCamper
    13,468
    5,438
    I guess I forgot...
    Tombukt2 likes this.
  10. Tombukt2
    13,868
    2,520
    So as far as I'm concerned that's a go because it was so basically easy no mods really . Other than bagging the press sensor . Not sure how much gas that tank holds but I'm imagining it's probably more than what we started with
  11. foreverPriusCar
    24
    florida
    This guy was crazy enough to try it after reading up on another user's unfinished attempt.
    PriusCamper likes this.
  12. foreverPriusCar
    24
    florida
    Yeah, it's surprisingly straightforward. Just have to find a good location for the pressure sensor/clean air sensor. With the Corolla fuel tank I think it's like 5-600 miles, and the guy is now on a Camry tank with like 7-800 miles per tank.
  13. foreverPriusCar
    24
    florida
    Hmm a good thread for me to chase down. Thanks for the input and ideas! Might just take my chance on the totaled fuel tank and make sure it's clean before installing.
  14. foreverPriusCar
    24
    florida
    Probably what I'll be doing. Local guy has a totaled prius and wants $50 for the tank with me removing it.
  15. Tombukt2
    13,868
    2,520
    Yeah with the tank that you have access to you'd be able to clean it put a new pump in it they're inexpensive sending unit have it all ready to go 500K
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    Do you have to get your car through state inspection? If so, then the only reliable route is to install a US spec Gen2 fuel tank.
    Otherwise , you will end up with evap system trouble codes in the ECM.
    Tombukt2 and foreverPriusCar like this.
  17. foreverPriusCar
    24
    florida
    No inspection only yearly registration. Man, that is really another consideration. If moving to a state or county that does require emissions inspection it has to come out and the regular tank has to be put in. That totaled Prius tank is looking better and better now.
  18. Tombukt2
    13,868
    2,520
    I thought with the pressure sensor in the yeti cup or the can or whatever the deal is that was avoided that.? So I guess if the pressure sensors satisfied then maybe the EVAP is also I do not know . It's the pressure sensor that was the issue I think anything can evap you just need solenoids aimed correctly along with correct vac lines
  19. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    Pretty sure a CA smog inspection would fail that. They basically don't let you modify any part of the emissions system. (In theory there is some procedure to verify that a new device is OK, but it requires extensive testing by the state on your dime. Something a company might do, not so much an individual.) That the same tank will pass on a Corolla doesn't matter. To be fair, it is a big ask for the smog inspection station to determine what a modification will do, it is much easier for them to just see that there is a change and nope it. Personally I blame this one entirely on Toyota - the bladder tank was a bad idea, and it is too bad they waited until the Gen 3 to get rid of it. Had they swapped over at say 2007 then tanks newer than that would have been fine, and you could probably have swapped one of those onto a 2005 and gotten away with it.
  20. Tombukt2
    13,868
    2,520
    So you do your best to hide it on this model they're predominantly looking at the catalytic converter and stampings . probably no looking in back much drum brakes and fuel cell. But you never know so you hide everything well that yeti cup gets tucked way up in there and so on make them look for it a lotta guys it's not I they pay grade .
