2023 Prius prime xse premium with advance park
Discussion in 'Gen 5 Prius Main Forum' started by Sean Sean, May 13, 2026.
  1. Sean Sean
    Sean Sean New Member
    XSE Premium
    Hi there, after a minor accident I get some error message on dash. It says system malfunction see your dealer. It’s some pre-collision icons lit up on dash. I took it to dealer and they pulled out X2036 permanent error code. Dealer notes:
    FRONT SIDE RADAR SENSOR OPTICAL AXIS ADJUSTMENT AND THEN RECALIBRATION NEEDED. The dealer wants $800 for radar adjustment and $1200 recalibration. Does anyone knows if there’s any independent shops doing this sorts of works?
    Thank you
  2. Hammersmith
    Hammersmith Senior Member
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Search your area for an ADAS shop. Recalibrations are pretty much all they do. They should do it faster, better, and cheaper. It's still going to be multiple hundreds of dollars, but it shouldn't get close to a thousand.
    ADAS isn't a brand, it's a description. Advanced Driver Assistance Systems. The shop or shops in your area might have ADAS in their name, or it might just be in the description of their services. A google search should help you. "ADAS shop near me"
    RX808 and VelvetFoot like this.
  3. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    Do it through your insurance. They give different prices to individuals vs. the insurance company.
    By the way, this calibration takes hours, as far as I know.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    I had a similar incident. I had a towtruck damage my read quarter panel slightly, and afterwards, I had some systems shut down, including the adaptive cruise control and lane-following. The dealer told me I had to get the body work repaired before any recalibration could be done. I did that, and the body shop said they could include the recalibration. They made it sound like a fairly minor operation. I'm sure with a bit of research, I could have learned how to do it myself.
