solar powered secondary AC system for keeping cabin and battery temps down
Discussion in 'Prius v Accessories and Modifications' started by darknd666, Apr 18, 2026.
  1. darknd666
    darknd666 Junior Member
    176
    24
    Jacksonville, NC
    The only nuance with this is that it's not a factory setup for the V so I would have to manually put the recirculate mode vent off assuming it stays in that position for the air diverter so that way it pulls fresh air from outside. Id really like to see where the wiring goes for the toyota solar vent control box. If I get down the rabbit hole far enough I will dig up the wiring diagrams on here, gonna try a simpler approach first.
  2. darknd666
    176
    24
    Jacksonville, NC
  3. darknd666
    176
    24
    Jacksonville, NC
    You know I wish I could fabricate a panel on the rear spoiler...that would be a great spot for it.
  4. darknd666
    176
    24
    Jacksonville, NC
    I think going with simplicity and more options for.panels I can just get a foldable for the dash and face the sun. The cramic coat on the windshield will undoubtedly reduce the panels effectiveness but a large foldout panel should still work.
  5. Dan H
    Dan H Member
    52
    29
    Miami FL
    2015 Prius v wagon
    I too have recently thought about doing this as the summer temps are already here. Good tints are a must, and so are sunshades. I went with 3m crystalline all around(50% on windshield and 30% everywhere else). Made it too dark at night so that caused me to upgrade halogen headlights to leds. And I have a full tightly fitting windshield sunshade and I also opted to go for the white paint cause it keeps the interior noticeably cooler than other colors. But still, a 90°+ full sun day heats up the inside quite a bit. There has been a bunch of mini 12 and 24 volt compressor portable air conditioners hitting the market. So that got me thinking that 200W~300W of solar on the roof and a 100Ah battery could power one of these on low and maybe make a dent in the heat. It would help with the whole cabin and not just the HV battery. Though would need to find a way to vent it to the outside. Question about the brushless HVAC fan. Anyone ever figure out the amp draw when the vehicle was running compared to the brushed? Aren't brushless DCs supposed to be significantly more efficient?
  6. darknd666
    176
    24
    Jacksonville, NC
    I just did ceramic tint on the windshield, 50%. 35% on the front windows, I wanna say I have 20-15% on the rear. Huge difference, Life changing. I also have a custom fit sunshade for the windshield, not only it has a reflective side but it also has thick foam board it feels like. The current weather conditions will be a real test as the next step is to insulate the roof with sound deadening foil faced closed cell foam. I may not need it but the cost will be way less than the tint job. The material im looking at now is 594mil thickness, it does have foil as I just mentioned. The tint alone has made the AC more efficient, i have a thick blanket I lay in the trunk area, im not 100% convinced it is the reason my battery has been performing better? Maybe insulating it fron the residual cabin heat? I mean the tint alone is what caused that reduction. I need to make these changes slowly with tests in between, to understand what changes made the most efficiency.
    Im not really looking forward to stripping the interior for the insulation install.
  7. bisco
    52,863
    I don't blame you. big job, and nothing ever goes back together the same way
  8. Big Ol' Tree Hugger
    Big Ol' Tree Hugger New Member
    Jacksonville FL
    2023 Prius
    I wondered why they didn't keep making them this way and if it was because it didn't work well. What do you think? Do you have a Gen 3? And if so is it bad nice person?
  9. Big Ol' Tree Hugger
    Jacksonville FL
    2023 Prius
    Sorry I think that might have edited my original thought.
    I wanted to ask if the feature is a positive addition.
  10. darknd666
    176
    24
    Jacksonville, NC
    Im assuming everything I do from here on out is for minimal effect, except for the title of this thread of course lol.
  11. rjparker
    11,119
    6,976
    That is correct. The uv blocking helps the hvac system if the system is running. Insulation has no effect when there is no real difference in temperatures between inside and outside.
    Even in Central Texas a super insulated house will still freeze interior pipes if the heater is not working or was left in cooling mode. Same in summer with heat on the outside, no active cooling and it will be just as hot and usually hotter inside.
    It's just a question of how long the inside takes to equalize. Not long in a car with large expanses of single pane glass.
  12. darknd666
    176
    24
    Jacksonville, NC
    I have 2012 V, so its a gen 3, but the V never had the solar roof option that I know of.
  13. darknd666
    176
    24
    Jacksonville, NC
    I will focus on exhuming hot air first then, before insulation...if I even follow through with anything else.
  14. darknd666
    176
    24
    Jacksonville, NC
    If youre referring to the solar vent option on the regular prius gen 3 then yes, it would greatly reduce cabin temps. Im assuming its a comfort option as the rest of the car should be able to withstand high temps while parked otherwise they wouldnt have made it an option.
  15. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    That much tint in those locations wouldn’t fly in NY.
    30% on windshield and side windows, max.
    Tinted Windows | NY DMV
  16. rjparker
    11,119
    6,976
    Most states allow a 25% Visible Light Transmittance on the top portion of the windshield and many allow a uv blocking clear film inside of the windshield. In fact the Prius v windshield has such a film between the laminated panes of glass from the factory. However most aftermarket windshields lack that feature.
    #36 rjparker, Jul 11, 2026
  17. darknd666
    176
    24
    Jacksonville, NC
    That would explain my aftermarket windshield...and why it felt like my hands were burning in the sun.
