"EGR DELETE" Instructions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paladain55, Jun 17, 2023.
  1. Bill Norton
    Bill Norton Senior Member
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    I believe you will get a CEL code with blocking the flow or unplugging the valve. Two different codes, possibly. The system is expecting a certain air pressure in the manifold. That's the MAP sensor's job.
    It would be easiest to put a thin metal 'gasket/plate' at the intake to 90° pipe. You can make quick with and without tests!
    I doubt 'soot would build up in the cooler if there is no flow going through, right?
    I was planning on using small brass wire rotary brushes in a drill to clean the very small EGR passages in the intake.
    But alas, I came to a better solution!
    Bail on the Gen 3 and buy a Gen 4.(y)
    I'm sill learning about that new EGR system but it sounds much better and does not require so much routing cleaning.
    I bought a '19 Gen4 Eco in Dec '25 with 232k miles, for a song, and it's now at 252k mi. Yes, it's a work car! And it gets much better mpg than the Gen3. Doesn't seem to use oil and keeps it fairly clean between 5-7k mi changes.
    Who needs a '10 Gen3 Level 5 with the Advanced Tech Package, but not the 17" wheels?(y)
  2. Paladain55
    Paladain55 Active Member
    413
    172
    The South
    Just unplug the egr valve connection and move on with life.
    StarCaller likes this.
  3. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Or just give it a try for a day or two. If you have an OBD adapter and free app you can clear the code after plugging it back in, and/or check the codes once a week to see if any other code has popped up.
    I did mine and the change in smoothness was immediately apparent.
    It used to hesitate and feel like it was stumbling a bit on light acceleration.
    Paladain55 likes this.
  4. Stu Wood
    Stu Wood Junior Member
    Bellevue, NE
    I cleaned my egr system and maniford at about 130k. It wasn't too cruded up but I drive the speed limit and don't floor it. I was interested in egr delete which I did and am very happy about it. No problems and get the same mpg. Looked into the egr data. They say engines run 100 to 400 F hotter without it. I have a scan guage 2 and have never seen the temp go over 198F. Here in NE the big seller is 10% ethanol which they say runs 100F cooler then straight gasoline. The egr system only runs part time anyway so I don't get the worry that the engine will run hotter and cause head gasket problems. I would think the manifold cruding up is problably the most likely to cause head gasket failure. Just my 2c worth. I am now at 167k and car runs great and haven't seen any drop in mpg.
    #104 Stu Wood, May 14, 2026
    Paladain55 and Bill Norton like this.
  5. ChapmanF
    18,894
    Sounds like you are conflating two things (which happens a lot in EGR threads): the temperature reached inside an engine cylinder, for milliseconds, in the cloud of burning mix, and the temperature the massive engine itself (block, head, head gasket, and coolant) reach.
    When "they" say something runs "100 to 400 F hotter", they're talking about that peak burn temperature.
    Your ScanGauge shows you that macro engine temperature, seen in the coolant. You're not going so see that change much, because there's a thermostat controlling it, and a radiator. And the thermostat and radiator are sized to keep that temperature fairly stable even under the much bigger changes like when the road goes from downhill to up.
    An engine/coolant temperature 100 ℉ hotter than normal would be way past overheating ... to say nothing of 400 ℉. :eek:
    Bill Norton likes this.
  6. Mendel Leisk
    42,196
    An “EGR delete” and “EGR cruding up” amount to the same thing.
  7. CR94
    CR94 Senior Member
    2,798
    1,231
    Northwestern S.C.
    Maybe.
    That would depend on whether the "delete" is by unplugging the connector or by otherwise blocking EGR flow, and whether the "cruding up" is in the cooler, or only the EGR passages of one or two cylinders.
    Bill Norton and Mendel Leisk like this.
  8. Stu Wood
    Bellevue, NE
    Yes, I meant peak combustion temperature without egr is 100 to 400F hotter than with egr. 10% ethanol lowers peak temperature 100F. Driving the speed limit I rarely see rpm anywhere near 3000. Anyone recall when the engine computer calls for egr?
  9. Mendel Leisk
    42,196
    Mostly in the mid rpm range, tapers off towards the idle and high rpm ends.
  10. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Most definitely ,, No.
    EGR valve unplugged = No flow through that system.
    EGR partially plugged up happens unevenly and the #1 and #2 cylinders get plugged first and that's usually where the head gasket fails.
  11. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    I always drive +5 the speed limit, which can be 80 mph true speed (not indicated speed), and I floor it as needed. I deal with tricky interstate on ramps....
    I really felt the car was smoother when adding light throttle while at low to medium speeds. There was immediate response and no slight stuttering.
    The only problem with the EGR unplugged is having the permanent CEL light. Ideally you should check your codes once a week or so to see if you have anything new, other that 'EGR' code....
  12. Mendel Leisk
    42,196
    Better let Toyota know, the whole EGR enterprise was for naught, lol.
  13. rjparker
    10,887
    6,833
    It is an argument without resolution especially as the gen3 fleet dwindles with age.
    However...
    Given gen2 had no egr, Toyota learned lessons implementing egr on gen3 Prii. They redesigned hybrid egrs by 2016 for use in a start stop, Atkinson cycle, thermal cycling application. These require no routine maintenance which was clearly the goal for gen3s.
    As with many gen3 engineering flaws, Toyota implemented mid production changes which provided an improved egr valve, intake, ecm software and piston assemblies.
    Which reduced the basic problem of a hybrid egr with intake before the cleansing cats.
    In addition, their stated purposes were to improve mpg and reduce emissions from their "near zero" vehicle. Which they did using egr without the uber expensive catalytic converters of gen2.
    Evidence shows no mpg degradation with "deleted" egrs even though this practice is against epa rules.
    Toyota value engineered gen3 on a tight schedule and seemingly were more interested in deploying the ground breaking advanced safety tech features.
    To say nothing of gen3 Prii in Brazil without egrs.
    Do I have an egr delete? No.
    #113 rjparker, May 15, 2026
    CR94, Bill Norton and Mendel Leisk like this.
  14. ChapmanF
    18,894
    I'm not sure the evidence can support the idea that Toyota's move to catalyzed EGR for gen 4 had to do with specifics of a hybrid application: seems more that catalyzed EGR was a topic getting research publications industry-wide during the gen 3 development years, and in time for gen 4 that research had turned up some usable results.
    There was more to the needed research than "dirty bad, clean good", because the catalyst changes the chemical composition of the exhaust in several ways, which then change what the exhaust chemically does in combustion when recirculated.
    #114 ChapmanF, May 15, 2026
  15. Mendel Leisk
    42,196
    Yes, they learned a lot of lessons. Would have been nice if they'd learned those lessons on a test track with pre-production models, but here we are.
    And perhaps retuned engine, richer air/fuel mix, to compensate?
  16. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    I did and toyota doesn't use EGR on Prii in Brazil.
    Do they get better or worse mpg? Who knows. Their gas uses a lot of ethanol.
    Do they have fewer head gasket failures due to the EGR clogging unevenly? Who knows. How could you research that?
  17. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Thanks for the very informative post!(y)
    And how 'bout you with 335k on your Gen3! Has the head gasket failed at some point?
    If not, how often do you clean that cruddy intake manifold?
    I currently have a '10 Gen 3 with 177k and a '19 Gen4 with 277k which is my daily work car.
    I'll be selling the '10 soon and I'm hoping Prius values keep going up with gas prices,,,, due to the "Epstein War". :mad:
    I've owned two Level 5's with the optional Advanced Technology Package, this current '10 and an '11.
    There was a big change in functionality between those years.
    The LKA on the '10 doesn't really nudge the steering wheel when you drift out of your lane, just beeping. Worthless, never use it.
    The LKA on the '11 at least tried to keep you in the lane and it had two 'Self Parking' buttons, (parallel and back-in). The '10 only has 1 of those buttons. Honestly never played with those on either car.
    I never read about all the other features that you listed. Thanks!
    My '19 Gen4 is the Eco model and they all had ACC standard.
    I added the Comma4 system and it is truly amazing!! Just out of the box and a short calibration drive and I now go hours on the highways and only touch the wheel to enter and exit.
    On the highway, a slight nudge of the wheel while bumping the turn signal, the Comma4 does a lane change.
    It will slow down and maintain separation with the car in front, right down to a stop and then a nudge of the Go Pedal and it's back to following in stop and go traffic. I only used this function once.
    It's just part of the ACC now and I've never touched it since the install.
    I know I sound like a sales person, but for road warriors such as me, it really makes life so much easier!!
  18. rjparker
    10,887
    6,833
    The 2012v now has 351k miles with one egr cooler replacement around 175k and intake clean followed about 100k later with a sticking egr valve change, ecm software and a cooler clean. Very early foreign object on speed sensor followed by antenna preamp failure, both during warranty period but they did not cover. They did cover brake booster and inverter. No advanced technology.
    The 22 Rav4 hybrid with lithium is a far better car with no chronic issues; reports are the new 2026 Rav4 is even better.
  19. CR94
    CR94 Senior Member
    2,798
    1,231
    Northwestern S.C.
    Deleting EGR may not have much effect on fuel consumption or head temperature, but will definitely increase peak combustion temperature, therefore increase emissions of NOx above legal limits. If done by physically blocking flow (vs. disconnecting the wiring connector) it may increase peak cylinder pressures and consequent stress on the head gasket.
  20. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    I'm pretty sure the mixture will always be in a safe,clean range.
    True, the combustion temps will be higher. That's the purpose of EGR to lower that. You got us there.....:(
    But how do you explain all the Toyota (and other) engines that don't have EGR?
    Why would there be any difference between an unplugged connector and block in the pipe?(n)
