Traction battery fan — how to tell if it's working
Discussion in 'Gen 2 Prius Technical Discussion' started by Gwyneth, May 19, 2026.
  1. Gwyneth
    Gwyneth Junior Member
    Arizona
    This is regarding a 2004 Prius. After approximately 260k miles (I say "approximately," as the combo meter was working only intermittently for a couple of years until I replaced it), I finally cleaned my traction battery fan. Yes, it was as dirty as you think it was. Maybe even a little worse.
    Things seemed to go OK when I reinstalled the fan, so I hoped all was fine. But I can't hear the fan running, and according to Dr. Prius, the battery temperatures are 88-90°, which is coincidentally the air temperature in the car right now. I don't think the fan is running.
    There are only two electrical connections to the fan, and I plugged both in. I don't know what else could I could have done wrong.
    Does anyone know of a way of checking whether the fan really is working? I'd appreciate any and all suggestions.
    Thanks in advance.
    ETA: It's definitely not working. I'll check the fuses tomorrow, but I may just need a new fan. It is 22 years old, after all.
    #1 Gwyneth, May 19, 2026
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,551
    2,593
    Taylors, SC
    I don't have a Gen 3. I have a Gen 3 2012 Prius v.
    I use a Scangauge 2 that constantly monitors the temperature of the HV battery.
    If the battery temperature does not rise above its design operational temperature, the fan is obviously working.
  3. Tombukt2
    13,742
    2,486
    All mine have been on original fans all of them HVAC HV battery etc just cleaned with a garden hose . And line dried till dry all impellers are bleached white no dust back in service headed to 665k he he .
  4. bisco
    52,669
    was there any corrosion on either side of the plugs? that's a common ailment. you can put a Kleenex on the intake vent if you don't want to obd
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,010
    NJ-USA
    The battery ecu isn't programmed to turn on the fan at 90°F. I think it will go to its lowest speed (1) at around 100°? I know that I can't hear the fan until it reaches around 125° (speed 3).
    If the fan has an electrical fault, then it will turn on many warning lights when the ecu tries to use it.
    Otherwise, I would suggest ignoring it. Some here on the forums are very concerned about what they think the battery temperature should be.
    I am not. Toyota's design went 15 years for the original battery in my 2006, so I'm not going to "mess with success".
