Accidentally submerged MAP sensor on intake manifold in hot water and Purple Power
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GustoGuy, May 20, 2026.
  1. GustoGuy
    GustoGuy Member
    75
    55
    I am cleaning my intake manifold and I accidentally forgot to remove the MAP sensor which is down by the throttle body on the intake manifold and I was blasting it out with Brake cleaner first and small pipe cleaner nylon brushes and I finally soaked it in purple power and hot water. I heard you can clean them with mass air flow sensor spray cleaner. Did I ruin the sensor by submerging it? If so what is a decent non Denso brand MAP sensor brand (Delphi?) I can buy to replace the sensor. I seen that the brand name sensors are really expensive. I guess I could also clean it gently with Mass Air flow sensor cleaner and put it together and see if it throws a code too.
    #1 GustoGuy, May 20, 2026
  2. CR94
    CR94 Senior Member
    2,795
    1,227
    Northwestern S.C.
    Let us know how that turns out.
    My guess is that it will be ok.
    Brian1954 and Mendel Leisk like this.
  3. ChapmanF
    18,889
    All it has to do is say what the air pressure is. You could plug it in and watch the reading on a scan tool.
    If it's close to what your local weather station says when the engine is off, there you go.
  4. GustoGuy
    GustoGuy Member
    75
    55
    My car has been acting up were it will sporadicly and randomly start to idle roughly. I decided to clean my EGR cooler and EGR valve and now I am cleaning the intake manifold. I read that the egr valve and cooler and intake manifold can cause the car to run roughly especially if they are full of packed in exhaust carbon deposits
    #4 GustoGuy, May 21, 2026
  5. GustoGuy
    GustoGuy Member
    75
    55
    I have a Creeder Launch scan tool. I don't have Techstream. I doubt if my reader can give anything but normal or abnormal function codes. Hopefully it works after being washed and I get no codes
  6. Mendel Leisk
    42,183
    Purple Power is caustic i believe? MAP sensor may be ok, probably will be, but the metal embeds in the intake manifold will react with caustic residue, and the intake manifold hold-down nuts and bolts. In your shoes I would very thoroughly rinse the intake manifold, blow everything bone-dry, and spritz all the embeds with WD40 or similar.
    The EGR cooler, being stainless, and very difficult to clean, is the only component I would clean with caustic solution. Everything else I’d stick to conservative amounts of brake cleaner, rags, brushes and elbow grease.
    I know this, from personal experience using similar oxi-clean solution on the intake manifold. Once.
    #6 Mendel Leisk, May 21, 2026
  7. ASRDogman
    ASRDogman Senior Member
    7,977
    4,049
    You may get lucky and it's okay. The only way to know is drive the car and see if you
    get any error codes for it. You should clean it with MAP/MAF cleaner and hope for the best.
    If you need to replace it, replace it with only one from Toyota. Seems no one has had
    success with aftermarket ones, no matter what brand.
  8. ChapmanF
    18,889
    Or look at the reading on a scan tool and compare it to the known pressure.
    Some sensors are tricky to test. For this one you don't need much more than a barometer, or a local weather page and the internet.
  9. GustoGuy
    GustoGuy Member
    75
    55
    Well. My 2010 Prius has has a blown headgasket and the engine coolant overflow was a bit low. At 431,000 miles there is more to it then just replacing the engine with another JDM engine. Despite putting in an oil catch can and changing the oil every 5000 miles like clock work it still popped the head gasket at about 168000 plus the engine had 39000 miles onbit when I bought it. I am buying a 2018 Prius Prime Advanced with 29,688 miles on it. The Gen 4 engines has a different EGR system and a Multi layer steel headgasket as well as higher tension piston rings and as a whole are way less likely to have a headgasket failures than the Gen 3 are. The mechanic said after 200,000 miles the Gen 3 Prius headgaskets failures are unfortunately fairly common.
  10. ASRDogman
    7,977
    4,049
    You don't really know how many miles were on that used engine.
    But it seems you have gotten a lot of miles out of the car.
    Some still have head gasket failures for the Gen 4, but I don't believe it's near as much.
    I hope that it works out for you!
  11. GustoGuy
    GustoGuy Member
    75
    55
    According to a mechanic I spoke to headgasket failures are very rare on Gen 4 and unfortunately common on the Gen 3 model especially once the cars get mileage over 200,000. I need a reliable car for work and I get mileage reimbursement for driving so 25 miles full electric and 54 mpg in hybrid mode will be nice. My old car literally paid for its replacement in mileage reimbursements through out the years I owned it
    ASRDogman likes this.
