suggestions on how to repair cracked 2012 Prius rear bumper cover so it passes MA state inspection?
Discussion in 'Gen 3 Prius Main Forum' started by asthmatic, May 20, 2026.
  1. asthmatic
    asthmatic Junior Member
    34
    Boston, MA
    I'm planning to use Loctite Plastics Bonder to glue the crack together, but I'm not sure what to use to fill the cracks, so they're smooth (just to pass inspection). Seems like there are a lot of issues finding products that would work for a (largely?) polypropylene bumper cover. I'd appreciate your advice. thanks! Screenshot 2026-05-20 at 11.07.24 PM.png
    52,904
    I used colored duck tape :oops:
  3. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You can find aftermarket ones on ebay for about $150
  4. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    The cheapest long-term fix is to drill holes on either side of the tear, and then use black nylon zip-ties to stitch it back together.
    For best results, remove the bumper cover and do this while it is off the car, then reinstall it. Use black zip-ties because they are UV-proof, all the others will degrade and break down in sunlight.
    Random example found on the internet:
    If you want to get really fancy, do it so the pawl end is on the inside of the bumper- gives a cleaner finish.
    Mendel Leisk and CR94 like this.
  5. Mendel Leisk
    42,379
