What is the best 0w- 16 motor oil for 2019 prius?
Discussion in 'Gen 4 Prius Main Forum' started by George W, May 19, 2026.
  1. George W
    George W Senior Member
    937
    520
    San Antonio
    I took my 2019 Prius for its first oil change since I purchased it. I had been going to Take 5 for my 2nd Gen Prius. Their choices in 0W-16 were Mobil 1 or Pennzoil. I chose Mobil 1.
    Maybe it's my imagination but the car seems to be getting worse MPG since that oil change.
    Is this a case where the Toyota oil is the best to use? Thank you.
    52,804
    I've never heard that about mobil 1. it's best to track mpg's by the tankful at the pump. otherwise it can be your imagination. there are too many variables in day to day driving.
    nothing wrong with toyota or pennzoil either.
    iLikeTurtles likes this.
  3. George W
    937
    520
    San Antonio
    Prior to the oil change I had driven three tank fulls of regular gas, where my fuel economy averaged 55 to 57 mpg. Immediately after the oil change the car is indicating a fuel economy of 48 to 49 miles per gallon. The other variables have not changed, such as weather, tire pressure, fuel, etc
    I had seen on my Gen 2 Prius that switching from regular to non-ethanol would sometimes screw up the fuel calculation for a couple of hundred miles, but I'm not doing that on my newer car. Just weird. Thank you
  4. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    I've always gotten better fuel economy with Mobil 1, even when compared to "botique" oils like Amsoil which is much more $$$. Mobil 1 seems to be about as good as it gets, so if they truly put Mobil 1 in, and MPG has tanked that much, there's either something up with their oil change (perhaps they put in Mobil 1 5W-30) or the driving conditions are dissimilar & the MPG will improve over time.
  5. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Why not just go with Toyota’s?
    Tande likes this.
  6. Leadfoot J. McCoalroller
    8,278
    7,784
    Pennsylvania
    2018 Prius c
    Are you certain they gave you 0W-16? there is a widespread shortage in progress, and even Toyota is telling their dealers to substitute 0W-20.
    There shouldn't be a difference in effeciency between brands, but it is likely you would notice a difference between weights.
    Note that a heavier oil will protect your engine just fine, nothing to worry about there. You just won't get the same MPG scores.
  7. BiomedO1
    4,547
    2,392
    Left Coast
    IMHO; an oil change isn't going to shave 7-8 mpg off your average. There's something else going on - bad fuel, new tires????
    George W likes this.
  8. PHEVisthefuture
    83
    25
    Illinois
    I would agree. The difference between 0W-16 and 0W-20 is almost negligible, I think something else is going on resulting in such a drastic drop in MPG.
  9. Mendel Leisk
    42,298
    I used Toyota branded oil for about the first decade with our ‘10, moved on when the price soared. Using Costco’s Kirkland now.
    George W and Doug McC like this.
  10. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    My 2020 Prius L Eco has 488,000 miles now. I have ONLY used Mobil One 0w16. But you asked what oil is BEST. I believe Amsoil Signiture Series is the best......though rather pricey.
