Advice on Best Way to Cool Florida Garage - Prius 4-2016
Discussion in 'Gen 4 Prius Main Forum' started by Betrock, May 22, 2026.
  1. Betrock
    Betrock Junior Member
    22
    Tampabay Area
    Hello-
    I just got a house with a garage on 03/01/2026 for the first time in a long time. I've suddenly realized the lithium battery in my 'Blue P' is roasting! I've researched as best I can, and the only advise seems to be park it outside with a car cover (!) - not happening.
    This is my 2nd Prius, I traded in my 2011 for the 2016 Prius Gen4 - bought new in 2016, now has about 25,000 miles on it. I'm retired and don't drive much, obviously. House & garage has a west exposure, 2 car garage, so it gets really hot in there. I'm in the Tampa Bay area, not near water.
    I've just gotten 2 thermometers that show temp & humidity blue-toothed to my Galaxy S25 phone. I've order 2 round high powered floor fans (not commercial high powered). Plus, I have one pathetic box floor fan.
    As my neighbor does, I began leaving my overhead garage door open about 1-2 ft in the day time. The side door to the yard has a small window I leave open, so hopefully, there is a little cross ventilation. The daily highs are already running in the high nineties outside.
    Where should I place the fans to get the most out of them? Point one at the ceiling to blow down hot air, and the other on the floor towards the 2 ft opening to blow out hot air?
    Should I open all the car windows, put the junky box fan in back seat pointed at backseat window - sort of over the battery area?
    Any other suggestions or ideas? I'd appreciate any and all help anyone can provide.
    Thanks,
    Anne
    P.S. As a 2 time Prius driver, having been subjected to all the scorn, I must point out, for anyone who does not own a Prius, I get between 64 and 68 mpg, and I'm a pretty fast driver. :p
  2. ChapmanF
    18,941
    What shape is the garage? Does it have a peaked roof, where you could have an exhaust fan in a gable?
    Is there some way to arrange for the air that comes in, to replace what's exhausted out, to come in from an underground space, like a crawl space?
  3. Betrock
    22
    Tampabay Area
    Great ideas! and yes it has a Gable roof over the garage, unfortunately, it is a rental property (an important fact I forgot to mention). There are not 'underground; options in coastal Florida. It's an average block house - not elevated, built in the 80s I think. But thanks for the quick response and great ides - in other circumstances!
    Regards, Anne
  4. ChapmanF
    18,941
    Well, maybe you could still lay a duct in the ground to bring air through. At high tide you could call it a swamp cooler.
  5. Betrock
    22
    Tampabay Area
    Thanks I needed a good laugh today!
  6. rjparker
    10,959
    6,874
    You may be overthinking it. A hybrid battery is at risk if it overheats while being used; not so much when parked.
    My experience in a very hot environment in Central Texas is garage cooling via ventilation or actual ac is not needed for the car. The interior of the car is far cooler in a garage than when parked outside.
    Fans to lower temperature in a garage even with open windows and a slightly open garage door just don't reduce the temperature much. I do that when I am working in there since humans benefit from an evaporative skin effect.
    This is my closed garage covering August 2025:
    The outside temperatures were higher than 95f fifteen times during the day while nighttime minimums were around 70f. The average in the garage with two cars operated daily was 80.8f which is not bad.
    I believe the key to hybrid battery reliabilty is to use it a least weekly for 30 minutes of more.
    Obviously garage ac would be ideal but costly to install and operate. A few have it but its primarily for those with $200k cars or people who have a hobby.
    #6 rjparker, May 22, 2026
    Brian1954 likes this.
  7. Betrock
    22
    Tampabay Area
    Thank you for your reply and all the information. You give me hope!
  8. Mendel Leisk
    42,237
    Our 2 car garage can get pretty toasty in summer, doubly so if fully warmed-up car is parked. The two, west-facing garage doors were solid wood, but now replaced insulated steel, which helped "some". Through last winter I got in gear: on the east wall (also exterior) I installed a 16{", 1100 CFM, wall-mounted exhaust fan with magnetic louvres, towards the north end, and at the south end of the same wall, separated by over 10', a 24" square intake air grill with gravity louvers. Wall mounted below the fan I installed a thermostatic switch. Time will tell how much all this regamarole will help, supposed to be a warm summer here.
    overall, interior
    Close-up, fan and thermostat
    Exterior:
    Close up of the make-up air grill and frame; I incorporated a removable bug screen in the frame. There's an anti-rodent screen as well, on the exterior side
    #8 Mendel Leisk, May 23, 2026
    John321 likes this.
  9. Robert21PrimeLTD
    99
    44
    South of Nashville
    I suggest purchasing a multi-layer car cover. I’ve found 5 layer ones on line. The discussions of fans, etc. miss what is happening. They only move the hot air around. If the temperature is hot inside the garage AND also hot outside, you might lower the garage temp by maybe 10 degrees.
    I would keep the car windows closed and cover the car. Simple to do. Just my option.
  10. PriusV17
    PriusV17 Active Member
    434
    206
    CA
    2017 Prius v wagon
    If your garage doors are dark colors, they will easily absorb more heat from the sun. Consider painting them a lighter reflective color that still blends in nicely to your house.
    Also you can consider insulation panels for inside the garage. I think Home Depot and Lowes carries them. Best to look for professionals to install them. Might already be companies that do that out there. No guaranty it will cool down your garage if the heat is also coming from the roof.
  11. Betrock
    22
    Tampabay Area
    WOW, that is an impressive setup! If I could get an exhaust fan like that, my problems would be solved! Unfortunately, I would be homeless, as my landlord would evite me for drilling thru his concrete walls! Oh well! Thanks anyway.
  12. Betrock
    22
    Tampabay Area
    I didn't know car covers came with that many layers! If I can get the garage temp down 10 degrees F, I'll be living large! The parameters I got from Prius for lithium are: Min/Max -4° F - 140° F;....
    Safest is: 59° F to 95° F. Right now, with one high powered floor fan (2nd will be here is a week) and 1 junky box fan, garage door cracked about 2 feet up, I'm at 92.2° F Heat Index 101.7°F. So, pray for me and thanks for giving me another option if garage fails completely.
    Regards, Anne
  13. Betrock
    22
    Tampabay Area
    Those panels are really snazy looking! Again, I'm a tenant, so not an option. However, my doors are heavy hurricane- standard, and white. So at least that helps! Thanks for your suggestions, Anne
  14. Betrock
    22
    Tampabay Area
    One more question, more weather circulation knowledge, than previous question.
    I know hot air rises, and cool air sinks. Given that assumption, if I have my overhead garage door open about 2 feet during the day, where is the best place to point my 2 hi-speed floor fans?
    Point one almost straight up at ceiling- angling slightly towards garage door, hopefully causing the hot air to get pushed down, then the 2nd floor fan pointed just a couple of feet from open garage door pointing straight out, so the hot air gets blown out?
    Or point both at ceiling, angling a little, and hope hot air comes down and goes out the open garage door?
    Or place both fans close to, and pointed out of, garage door opening?
    Anyone have any knowledge or thoughts? Any help would be much appreciated! Thanks, Anne
  15. rjparker
    10,959
    6,874
    This sounds reasonable but not as good as some sort of flow through ventilation similar to Mendel's.
    I don't believe your average garage temperature will be reduced more than 8-10f assuming you keep your fans as planned.
    Our hottest day so far this year was 94f which translated to 100f in an unventilated garage with two cars which were 190f when parked.
    The average temperature for those 24 hours was 81f outside and 90f in the garage. With two hot engines inside.
    Personally, I don't think it's worth the fan operating costs or the risks of leaving the garage unsecured.
    I know the hybrid battery is fine with 90f operating or parked.
    The most effective way to cool a garage is with a $1200 24k btu minisplit (not a portable ac). No garage doors open and adds human comfort when using the garage.
    Regardless your fan plan is reasonable given constraints.
    douglasjre likes this.
  16. Betrock
    22
    Tampabay Area
    Which plan?!? I named 3.
    Thank you for your comments and advise.
    I am a tenant and cannot alter the structure.
    I am retired and can't afford to buy an A/C for my garage, nor would I if I could afford it as I spend little time there.
    Per Prius, the top safe limit for my battery is 95°F, so I think my fans will work, I would just like some knowledgeable info on the best setup WITH only my 2 fans.
    Thanks,
    Anne
  17. ChapmanF
    18,941
    Maybe you could locate one of the fans in the small window to the side yard blowing out, and build some kind of simple ductwork (standalone, not modifying any of the landlord's structure) for it to draw hot air from high at the ceiling. Cooler air would enter down low under the part-open garage door to replace it.
    Or hang the fan near the ceiling and build some kind of standalone ductwork from its discharge to the small window, same effect, perhaps more effective, depending on the type of fan.
  18. rjparker
    10,959
    6,874
    The plan in the first post.
    The garage will never be cooler than the outside air but you have the car and batteries thermal mass working for you. Which means they don't change temperature as fast as the air. As a result, what matters is the average temperature over 24 hours regardless of air temperature peaks measured in the garage. That average temperature is unlikely to exceed 91f on the hottest days.
    Mounting a fan on the door window exhausting out would most closely mimic Mendel's setup. Opening the garage door by six inches would provide enough make up air.
    However mounting a fan on the window would require some modifications you stated were not allowed, eg things you were constrained from doing..
    However I maintain doing nothing beyond parking in the garage is enough. Otherwise executing your first plan would also be adequate.
    #18 rjparker, Jun 7, 2026
  19. ChapmanF
    18,941
    I'd be awfully surprised if there was no way to stand or hang or duct a fan somehow to, around, or near the door window in some way that avoids honking off the landlord.
  20. Mendel Leisk
    42,237
    Can you recap: the garage doors are west side? The window(s), how many, what side (north, south, east, west), if multiple how much separation? Would the windows accept window-mount fans?
