The simplest and easiest LiFePO battery conversion for all Ryobi 48 volt lead-acid battery mowers
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, May 1, 2026.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,531
    2,570
    Taylors, SC
    That's a better price than I paid for the exact same battery. I thought the $359 that I paid was and still a good.
    Like buying stocks, I guess you can almost never buy at the lowest price.
    52,578
    thanks!
    according to the technical penguin at 44 minutes,
    I can use the original OP48RM charger. what do you think?
  3. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    Not a good idea. It has a float feature that with continued use will damage t h e LiFePO4 battery.
    I watched that video, too. As nearly all I could find.
    A P3648 charger will display the battery's voltage and cut off when the battery's charge is full.
    If you do an eBay search, one could be had for about $65.
    The original charger is worth $150 plus used, Mine was the Delta Q charger. The newer version is worth nearly $300.
    Your original charge port and cable is worth $50. I accidentally destroyed mine. That turned out to be good, because it led me to develop a better direct charging cable and system.
    #23 Georgina Rudkus, May 24, 2026 at 6:52 PM
  4. bisco
    52,578
    perfect, thanks!
    battery ordered, I'll order the charger tomorrow.
  5. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    Great. I have the easy to install complete set, if and when you want them.
    If you are on the East Coast, like me, the battery will be shipped by FedEx from New Jersey.
    You'll get it in 2-3 days.
    #25 Georgina Rudkus, May 24, 2026 at 8:27 PM
  6. bisco
    52,578
    thank you. did you do the transaxle fluid while the battery was out?
  7. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    Yes, I changed it with 75-90 synthetic Super Tech from Walmart.
    It was easy.
  8. bisco
    52,578
    thanks, I'll do the same.
  9. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    This charts explaining charge percentage voltages for LiFePO4 batteries.
  10. bisco
    52,578
    I just realized I have the rm300e, I hope the eco worth will still fit. I've started dismantling the mower
  11. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    Yes, it will still fit.
    There is a bar between the front and back batteries.
    You might have to place a couple of pieces of wood to raise the surface above the center dividing bar.
    Since the Eco Worthy battery is much lower than the taller originals, a pressure treated 2×4 would be a good choice.
    I would double stick one cross bar that fits the width of the front battery cavity to the front bottom of the battery and another to the back bottom of the battery and strap the entire assembly down with the 8 ft long luggage strap.
    You want the battery terminals facing towards the back of the mower.
    This video might help.
    If you go with direct charging, you can get rid of the original charging harness, the charger .lockout relay and the lead-acid battery temperature sensor.
    You do not want the on board charger. You want to remove the original charging harness by taking out the three Phillips screws from the back, drill out a half inch hole for the Xt60 connector pigtail.
    #31 Georgina Rudkus, May 25, 2026 at 9:21 AM
  12. bisco
    52,578
    thank you! I was just measuring it. the sticking point seems to be width at rear risers that are only 12" wide. as long as th 17.2" will fir in front of those, I should be able to do some simple mods to make it fit as you said.
  13. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    Looks like you'll be fine. Usung the 2×4 risers will allow you to fit the slightly wider Eco-Worthy battery. Just cut two 12 inch long pieces of 2×4.
    Happy to help.
    #33 Georgina Rudkus, May 25, 2026 at 10:18 AM
  14. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    One other thing that's different with the RM300E is the diameter of the holes in the main cable lugs that connect to the Eco-Worthy battery.
    The lugs have 6mm or 1/4 inch equivalent holes. The Eco-Worthy battery uses 8mm bolts. You'll need to use a round file to enlarge the holes on the lugs of the battery cables.
  15. bisco
    52,578
    I took some measurements, and it looks like the ecoworthy is a tad too large for the space, because of the height adjustment bracket on the left, and the electronics brackets on the right. upload_2026-5-25_14-3-4.png
  16. bisco
    52,578
    I can't find anyone who's done an rm300e except with very expensive batteries
  17. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    I don't see that as a problem. The battery does not need to be centered. You can mount it skewed slightly to the right on top of wood spacer risers.
    I'd wait until I get the battery and try to lower it into the space.
    If it fits skewed, I'd place the wood spacers with the double stick tape on top and lower the battery into the space again, press down and strap the battery down.
    #37 Georgina Rudkus, May 25, 2026 at 3:58 PM
  18. bisco
    52,578
    watch what this fella had to do to get the smaller DC HOUSE battery in:
    there are a lot of different objects in the way
    #38 bisco, May 25, 2026 at 5:29 PM
  19. bisco
    52,578
    very similar size, I'll get the exact dimensions to see if I can stuff in the eco worthy.
    I cancelled my order (I think) so if I go ahead, I'll lose the discount, but it's still the cheapest way to go
  20. Georgina Rudkus
    3,531
    2,570
    Taylors, SC
    Can't open the link.
    Here's the link that will open.
    The DC House and the ECO-WORTHY are the same company. The batteries are the same size.
    The only difference is that the Eco-Worthy does not have the mounting flanges whose corners need not be cut with a hack saw.
    They are the same company.
    #40 Georgina Rudkus, May 25, 2026 at 5:35 PM
