This is Why Stop Leak Should be Banned
Discussion in 'Gen 3 Prius Main Forum' started by jimolson, May 16, 2026.
Tags:
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,315
    925
    Monument, Colorado USA
    I'd got a bit further and say that, besides Stop Leak, MOST additives should be banned. But, of course, it's not against the law to be stupid so they have to sell it.
    Snake oil....as long as you don't say anything that's can be proven a lie....some gullible and ignorant folks will fall for it. I remember "Slick 50" additive in the 80's....said it coated your engine and you could, magically, even run it without motor oil! (I guess you COULD run the engine until you couldn't....because you killed it!)
  2. Mendel Leisk
    42,075
    Maybe "high-mileage" oil too? I remember looking at a bottle, decades back, wondering if I should be using it, since our car was getting up there. Not sure what all is disclosed on the bottles these days, but I've read the difference in this type of oil is additives designed to swell gaskets, which "may" be the cause of oil consumption. It's best reserved for engines with bad oil consumsption, a last ditch effort, and once you start using it, you better stick with it, because switching back to regular oil the swollen gaskets, more worn than ever, will shrink, and oil consumption increases with a vengeance.
    ColoradoBoo likes this.
  3. ColoradoBoo
    1,315
    925
    Yep, the marketing folks are busy! When people ask me what's the best motor oil, I just say, "Whatever you change out every 6-months" I'd rather be using recycled motor oil every 6-months in my vehicles over the best (Mobil One/Amsoil) every 12-months....no question about it.
  4. frodoz737
    frodoz737 Top Wrench
    4,755
    2,529
    33
    Using stop-leak, high mileage or any other bandaid is just a way of trying to avoid doing needed repairs.
  5. PriusCamper
    PriusCamper Senior Member
    13,248
    5,357
    Pacific Northwest, USA
    yep... I bought a Seek Thermal camera that plugs into a phone years ago. It's terrible super low resolution because its so cheap but you can diagnose insulation and water leaks in a house in a matter of minutes. It also made rebuilding OEM battery packs way easier because a hot cell that's soon to fail usually gives no other symptom than heat and with 168 cells to examine a thermal camera can find the ones running hot in seconds.
  6. CR94
    CR94 Senior Member
    2,781
    1,221
    Northwestern S.C.
    Oil compainies (SOPUS specifically, and probably others) have denied that myth, and claim their "high mileage" stuff will not harm new engines.. All legitimate engine oil contains seal conditioners.
  7. rjparker
    10,732
    6,737
    Additives to swell gaskets won't work on the common leaks caused by form a gasket sealants and may swell variable valve timing seals causing more problems.
