Can an actuator go bad after sitting in a junked/salvaged Prius?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, May 26, 2026.
  1. priuslyfe
    priuslyfe Member
    349
    71
    I'm really hesitant to put a used brake actuator in another Prius that needs it since it might not work. I know that the brake actuator worked well when the car was wrecked however after many years wondering if its even worth putting that actuator in another Prius.
    Do they wear down on any kind of timeline? 350K vs 250K or is it all based on use?
    Reading some information that the actuator-issue was fixed for 2008-2009. I think I am pulling from a 2008 and putting in 2007, would that be relevant or are all years for Gen 2 the same?
    Would also appreciate any seller-links that sell good, working brake actuators if you know of any.
    Thanks.
  2. priuslyfe
    priuslyfe Member
    349
    71
    asked AI:
    Yes, a Gen 2 brake actuator (common in Toyota Prius 2004–2009 models) can develop leaks or fail from prolonged sitting/non-use, though it's more often tied to age, mileage, and normal wear.
    Why This HappensGen 2 Prius brake actuators (part of the ABS/hybrid brake system with an accumulator/pump) are known for internal leaks over time. The main issues include:
    • Internal seals and O-rings drying out, shrinking, or hardening when the system isn't cycled regularly. This is a common problem with rubber components left unused.
    • Brake fluid degradation: Brake fluid is hygroscopic (absorbs moisture from the air). When a vehicle sits, it can draw in moisture, leading to corrosion, reduced lubricity, and accelerated seal wear. Old/contaminated fluid worsens internal leaks.
    • Lack of pressure cycling: The actuator's accumulator holds pressure. Without regular use (braking, driving), minor issues can worsen as seals aren't exercised, and pressure drops faster.
  3. Tombukt2
    13,859
    2,519
    Most every Prius I've walked up to in the wild in the junkyard the brake reservoir is full of brake fluid it's clear as water and just sittiitin they're . So when I crack the system and drain the fluid then the crap starts the drying out and so on so wen I crack take all you gonna want once dried out . No good .
  4. priuslyfe
    priuslyfe Member
    349
    71
    what should you do if you already removed a junkyard actuator? should you drain and then fill and flush it with brake fluid?
    what do you recommend?
  5. priuslyfe
    priuslyfe Member
    349
    71
    do you recommend buying a new actuator instead? I'm ready to install but have read many stories about the junked ones only lasting less than 6 months due to drying out during its resting.
  6. rogerthat
    rogerthat Active Member
    411
    129
    Georgia
    I installed a used one I bought on Ebay (You've got to search for the updated model#). However, if you can find a reasonable deal on a new one, that's the way to go. There is no way to tell if a junked actuator is good until it is installed (which is a challenging job!)... although, you have a higher probability if it's the updated version.
    priuslyfe likes this.
