Safety Recall Rear Doors
Discussion in 'Gen 5 Prius Main Forum' started by exbauer, Apr 17, 2024.
  1. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    trusting the old reliable mechanical way was a safer approach that going electronic…at least they have the mechanical backup installed but kind of hard to press down vs just pulling the old style mechanical door handle
  2. Hammersmith
    Hammersmith Senior Member
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Remedy now available to existing owners. You should be able to schedule with your dealership. I just scheduled mine, though I don't know for certain if all Priuses(2023-26) are getting them together or if there are phases. The Prius is so low production that I have to assume Toyota is just doing them all in one batch. After all, it's rear door switches on 140k cars, not full engine replacements on 500k+ trucks/SUVs. ;)
    (My VIN is under 3000, so I'd be in either the first group or the last if Toyota is doing this in phases.)
    stuyguy and Tekz like this.
  3. flarecde
    flarecde Member
    59
    68
    NY
    2023 Prius
    Limited AWD-e
    I had mine in for a tire Saturday and they offered to do it. Took 4 hours.
  4. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Any idea what it entailed?
  5. flarecde
    flarecde Member
    59
    68
    NY
    2023 Prius
    Limited AWD-e
    Nope, besides a ton of time.
  6. Hammersmith
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's supposed to be a 1.8hr job. That's what Toyota pays the dealership(actually 1.7hr for the repair, 0.1hr for administrative costs).
    The process includes:
    1. Removing the rear seats completely(seat backs and bottom)
    2. Remove pretty much all the trim surrounding the rear doors(lower B-pillar trim, floor trim, trim between rear seat and door)
    3. A new wiring harness is run alongside the original harness from a point halfway up the B-pillar, under the door, and up the rear wheelwell.
    4. A new relay is installed at the end of the new wire harness up near the shoulder seatbelt tensioner.
    5. Repeat on the other side and put everything back together.
    I have no idea how a relay placed on the body side of the door and plugged into nothing but a wiring harness that connects to nothing except a different part of a wiring harness is going to prevent an actuator in the door itself from activating, but I'm not a vehicle electrical engineer. I assumed they were going to replace the door switches again, but the doors aren't touched at all. And I don't know why the new relay needs to be installed where it is when it's not connected to anything but the new harness. There's nothing in the dealer or technical instructions about how or why it works, only how to install.
    On the positive side, it's the perfect time to get the fuel tank recall done if you've been putting it off. Both recalls involve completely removing the rear seat.
    soft_r, nukejello and VelvetFoot like this.
  7. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    Fuel tank? Uh oh. First I've heard, lol.
  8. Hammersmith
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Oh, yours is a 2026. I think yours was built after the recall.
    edit: Oh, yeah. You're well clear. The recall was for 2023-24 models. Actually 2023 Prius and Prius Primes, and some 2024 Primes. But the Primes only had to have a software update. It was the HEV's that needed something added to the fuel tank.
  9. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    Educated guess from the description is that the relay intercepts power to the actuator, only letting it get power on some condition like the vehicle being in Park. Presumably this new harness is being connected inline at a connection point.
    The actual new wire harness routing is a bit mysterious. If it isn't actually connecting to anything in the B pillar, then maybe it's just about finding a physical space to put the relay module.
    Maybe the harness is making the connection between:
    • a place in the existing wiring harness where you can both intercept the actuator power and pick up the when-to-allow-power signal; and
    • a space big enough to hold the power interceptor module.
  10. Hammersmith
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry I wasn't clear. It DOES connect to the wiring harnesses in the B-pillar. And then it goes from there, under the door, and up the wheelwell where it terminates in a relay. But that end of the new harness doesn't connect to anything EXCEPT the new relay. So why not install the relay in the B-pillar area and not bother running it under the door?
    I'm sure there's a reason, but I don't know what it is. I'm going to go ahead and link the technical instructions. I'm trying to do that a bit less(especially since my annual subscription expired over a year ago), but this one is so complicated you almost need the visuals to understand.
  11. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    Clarification doesn't change my guess, apart from swapping the locations - there's not physically room for the relay at the interception point..
    Not sure I totally buy that though.
    (But given how concerned they are about properly securing things, maybe it could be stuffed in somehow, but they wouldn't be happy with the longevity, including overstressing the existing wiring)
  12. Hammersmith
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I just figured there'd be enough room near the base of the B pillar under the trim if the relay's position didn't matter. So they'd need a half meter of wiring instead of two meters. And a shorter wiring run would have certainly made it easier for the dealership techs.
    But I guess the only thing that matters at the end of the day is that it works.
  13. nukejello
    nukejello Junior Member
    MD
    2024 Prius Prime
    XSE
    Just got mine done today.
  14. Richard Tran
    Richard Tran New Member
    2026 Prius Plug-in
    XSE Premium
    Wanted to ask, how did it go? Anything different about the doors?
  15. winnertakesteve
    155
    48
    Toronto ON
    2025 Prius Plug-in
    SE
    kinda dreading this. seems like the whole thing could turn into a whack a mole of wiring issues. especially since their first attempt at remedying back door issues clearly didn't resolve things. and my car already has other weird behaviour, like plugging in to charge regularly messes up the locking mechanism on the doors (both key fob and physical door controls stop responding). i know it wouldn't have been feasible, but i'd have preferred it if they just slapped a mechanical handle in place of the button.
    daisy555 likes this.
  16. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    (My VIN is under 3000, so I'd be in either the first group or the last if Toyota is doing this in phases.)[/QUOTE]
    Service manager at my local dealership recently told me they would be done it batches. That I will receive an update when they have the parts available. I’ve heard of multiple people (not local) who have had issues with this repair… mostly damage that was probably tech negligence so I don’t mind waiting until they’ve practiced on a few before mine.
    winnertakesteve likes this.
  17. daisy555
    1,729
    716
    CT
    I wish I hadn’t read what’s involved with this recall repair. I had no idea the repair was this involved. One guy recently posted online that the plastic piece along the hatch area was misaligned after this repair. Doesn’t make sense that they would be removing something from this area but maybe so.
  18. Richard Tran
    2026 Prius Plug-in
    XSE Premium
    That is really concerning, I will be sending it in for recall repair in two weeks and my car doesn't have major issues. I don't want issues starting now..
    VelvetFoot and Tekz like this.
  19. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    Same here, I don’t find any issues with my vehicle and been trying to hold off from the repair as long as I can…
    Richard Tran and VelvetFoot like this.
  20. Richard Tran
    2026 Prius Plug-in
    XSE Premium
    The good news it seems that as the techs have more practice on this recall fix then the majority of have good experiences with the fix. I remain cautiously optimistic, I asked on the prius FB groups.
