Idea for a Sporty GTI competitor for 6th Gen
Discussion in 'Gen 5 Prius Main Forum' started by MechaDragon, May 25, 2026.
  1. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Top Gear or Fifth Gear had an episode in which a Golf with an adjustable suspension was timed around a track in comfort mode then sport mode. It turned out to be faster in comfort mode. Lower and stiffer isn't a handling panacea.
    Some people will still see a harder, flintier ride as "sportier", but suspension tuning has gotten better since those ideas took root.
    The Prius is a FWD format, and even in AWD versions the car will behave at its adhesion limits a lot like a FWD car. One of the obstacles encountered in trying to make a sportier FWD car is that feeding power through the same wheels that propel the car can get them overwhelmed pretty quickly. When MKIV GTIs got a turbo in the early 2000s, it still only bumped hp up from 115hp to 150hp. (For reference, 150 hp is the peak hp for just the engine in a current Prius). Integras were working with 140hp or so and many of the hot hatch competitors were roughly equivalent. When hatches were offered by every manufacturer, big horse power wasn't a problem. As Honda and VW stuck with that format and HP grew, part of their project was mitigating the deleterious effects of too much power on handling.
    You can buy a thicker rear antisway bar on a FWD Prius so it will lift a rear wheel in a turn and rotate more readily, but that doesn't solve the underlying problem of two front tires transmitting a couple hundred horsepower and trying to turn the car at the same time.
  2. MechaDragon
    MechaDragon Junior Member
    Salt Lake City, Utah, USA
    2024 Prius
    Well thats strange to hear considering it has one of the highest ridehights of any passanger car. Like if you dont have a crossover, SUV, or pickup truck, the Prius is very high off the ground for a vehicle that is not a part of one of those categories.
    Its minimum point ground clearance is 5.6 inches. Thats massive. There are actually some pickup trucks and SUVs out there that barely sit over 6 inches off the ground.
    Pretty much only the base model Civic sits any higher than the Prius does.
    And handles well? I mean yea if you have never been in even an entry level sports car, sure it handles well compared to like a base Corolla or Jetta. But once you step into a Jetta GLI, Corolla Apex, Civic Si, anything like that - its a completely different world. The Prius is set up for comfort and has tons of body roll. Its the appropriate choice for what the car is trying to do yes, but sporty? Absolutely not. Its handling has just gone from completely horrible and a joke to acceptable and even slightly better than some other base model cars. It also has tires that are far to skinny to allow for any real cornering force, you will just slide out. Also the steering is completely numb and provides no real feedback whatsoever. Its unfortunately something they would have to work on if they wanted to release a sporty Prius.
    But then again, I guess a sporty Prius would be a complete waste of time because apparently we are getting a new Hybrid Celica soon, which renders the idea of a sporty prius completely reduntant. I mean maybe not if the Celica focuses too much on power and ends up being too expensive to really be worth it. IDK, we will just have to see.
  3. MechaDragon
    2024 Prius
    Firmer suspension is certaintly more sporty, its just that its more sporty up until a certain point where making it any stiffer won't give you any real benefit and could actually make the car handle worse because suspension that is TOO stiff will cause bounciness and not allow the tires to maintain grip over lumpy surfaces.
    The Prius suspension is without a doubt far too soft to be cosidered sporty. But its not terrible and seems like a great balance for regular people who don't care about sportiness at all.
    The GTI has always been the master of balance between comfort and sportiness. Theres a reason why - even if its not selling tons of brand new ones right now, its still the best-selling HOT hatchback in human history.
    Blackat likes this.
  4. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I doublechecked my sources(it had been several months since I read it) and it turns out I partially misremembered. Mazda and Toyota are indeed partnering on the next gen MX-5 and GR 86, but it's for the platform and not the powertrain. The plan is to update the current MX-5 platform and allow it to be stretched to also handle the next GR 86. But the MX-5 will use a Mazda powertrain(likely a hybrid), while the GR 86 will probably(?) use the Prius powertrain. Toyota is saying a 2.0L 4-cyl hybrid that puts out 200hp. That sure sounds like the M20A that the Prius, Corolla, and NX currently uses. The G20E that's under final development is supposed to put out 300-400hp before any hybrid additions.
    Trollbait likes this.
  5. Rafsdhc6
    Rafsdhc6 Junior Member
    28
    Ontario
    2023 Prius Prime
    XSE
    Haha, I hope that was tongue in cheek. It’s a well known fact that the new Prius is not exactly easy to get in and out off. It’s not the ground clearance itself but the roof slope. The base model Prime sits at 5.6 but XSE is at 6.0, due to 19s, which I own. I also own a Crown Platinum which has a 5.8 clearance but has one of the best ergonomics of getting in and out off even though it’s lower than the Prius!
    Bro, I graduated high school a long time ago and don’t really want to sit on a rock for my 1.5 hour commute. I’ve seen maybe 3 Corolla Apex in my life, you know why, because people don’t want to sit on a rock. Too many compromises. The Prius has a great balance in handling and comfort. Steering is quick enough and responsive enough combined with instant torque and it’s a fun, zippy car. Way better than it’s competitors which is compact economy class full of soul crushing characteristics.
    Prius has a ton of body roll? I don’t think you would like my Crown Platinum either . It’s a shame Toyota can’t get their adaptive dampers firm enough like the Germans.
    It would be a complete waste of time because it wouldn’t be a Prius. A compact, ultra efficient car that does most things well.
    Look at the Prelude and absolute hate towards it. Even though it has great handling it’s absolutely hated for not having 300+ HP! Why not just get a Type R, Nissan Z, Integra Type S, a GTI or R? Everyone wants superb handling, 300HP, less than 3500lbs, and 40+ MPGs in the city, for less than 40k, lol. That world doesn’t exist yet.
    But I can see a GR Prius like the new RAV4 with updated Gen 6 PHEV, but I bet high school ricers will hate it still because it’s not extreme enough.
  6. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    That makes a lot of sense.
  7. MechaDragon
    2024 Prius
    Everyone hates the Prelude because Honda didn't even add any power, so its literally a $30,000 Honda Civic Hybrid with a different body (admittedly a beautiful one), and some nice brakes and suspension for a full $47,000-$48,000. People would have loved it if it had even just 25 BHP over the Civic Hybrid and a price that wasn't absolutely stupid. Remember how much hype there was behind the car before the final performance and price figures were confirmed.
    Thats why people love GTIs. They don't ride like a rock, they ride almost as comfortably as the Prius does, and yet they corner flat, corner fast, and have real confidence in the snow too. And of course they are pretty fast. They are also luxurious-feeling, have tons of space inside with a flat hatch and folding seats that turn it into a 2-seater box van on command. They look excellent, they go excellent, and they stop excellent. They are very reliable, hold their value, and remain desirable. They do everything the Prius does, but even better - besides the fuel economy. Thats what the GTI is.
    Now the Civic Si - that one was a rock, especially when I put it in sport mode. Anything more than the most minor of bumps felt like slamming into a massive pothole in any regular car. Its actually the only thing I didn't like about it. Honda focused a little too hard on the track and not enough on daily drivability and comfort. But it has comfortable cloth seats that make up for at least a BIT of the harshness so I was able to live with it, especially as Im only in my Mid 30's so its not like Im an old man with back ache yet.
    Ya the Corolla Apex isn't very popular for a similar reason - no real performance. They just took a regular Corolla, made it look admittedly killer, and stiffened it up with no actual extra power or performance. Ya because your sporty car should be woefully slow I guess ‍*shrug*.
    Anyone who drives a sports car knows they are making a sacrifice of some comfort to get the sporty handling and they are okay with it, especially when the manufacturer is smart like VW and gets the sporty handling while also keeping the car quite comfortable and luxurious-feeling.
    Thats what makes the Corolla Apex and Prelude so dumb. So you make the sacrifice of some comfort for the sporty suspension, you pay more for the car, and yet your car isn't even any faster than the base model. Its a total slap in the face.
    And yes, I already said the 5th Gen Prius is a fantastic car for what it is. I just said don't mistake it for "sporty" because it isnt. Sporty cars enjoy cornering hard and getting heavy lateral Gs with minimal or no understeer or body roll. The Prius doesn't do that, not in stock form. But it is GREAT at what it does, and it handles well for an economy car focused entirely on fuel efficiency and comfort and has skinny, rolling resitance-focused tires. I liked thd other word you used for it - "zippy". Not powerful enough to be acually fast, but its slightly fun and pulls decently when you want it to, yeah. So what I am saying is that it is very good in comparison to others in its own class, but falls short once you begin to look at anything remotely "sporty". And who is surprised by that? Literally nobody, it wasn't even trying to compete with anything "sporty". Thats my idea for a sporty Prius, not the one we have now.
    And ya, the Crown isn't a sporty car either, its a luxurious Grand Tourer. It has the power and luxury, but wasn't designed to corner hard. Just like any other luxury sedan or whatever. Non-AMG Mercedes, Standard Lexus Cars, and Non-M BMWs come to mind when looking for comparisons to the Crown.
    Edit: And yes, I know what you mean about the sloped roof. I have bonked my head on it once or twice and it slightly annoying, but Im used to it now. And that is one of the sacrifices we agree to make for the Prius incredible fuel economy. A huge part of the reason its so economical is the body shape. It was designed in a wind tunnel to have as little aerodynamic drag as possible while remaining practical enough to seat a family and carry a good amount of cargo in the back. Its one of the most aerodynamic cars on the market.
    As for why I chose the Base LE when I could have afforded up to probably about the Nightshade edition - because in my opinion, the LE makes the most sense. Why are you buying a Prius? To save fuel and money. I don't care about a stupid glass roof. It just adds weight and another piece of glass that can break and then needs to be replaced. If I want fresh air in the cabin - I have 4 windows. And in the summer I want to block the sun out because its hot as hell, especially in Salt Lake City with huge UV numbers and 100+ degree days in peak summer. Its the same reason I only opened the sunroof on my Si maybe 3-4 times in the entire 5 years I owned it. The only time opening a roof makes sense is in the night during summer, on a clear, beautiful night traveling outside the city so you can look up and see the stars. Otherwise, roof glass is a waste of money, material, and weight.
    So why not choose the LE that saves you up to $10,000 versus the top trims and is also a nocicable amount more economical, saving you even more money as you own and drive it. And of course there are less electrical items to break. The ONLY features I wish I had on my LE that are from the higher trims are the larger infotainment screen, a heated steering wheel and maybe heated seats (but the cloth ones are super comfy and don't get too hot or cold so... meh...), and then maybe the Nightshade edition Wheels (because they look incredible. Thats literally it, I don't want any of the other junk from the upper trims on my car. I would much rather save the money and the weight, making my car even more efficent - the whole reason you buy a Prius.
    #47 MechaDragon, May 29, 2026
  8. TGTGUUD
    TGTGUUD Member
    100
    77
    San Francisco
    2024 Prius
    I recently switched to DWS06+ 215/55R17 on a new set of 17X7.5 rims, for a sportier ride...1.8kg more unsprung mass each corner.
    I'm getting 45mpg now, down from 55 on the factory Toyos.
    These Toyos were absolute shite in every way except fuel economy...so I think the Prius largely depends on shitty tires (low rolling-resistance touring tires) to achieve the amazing MPG numbers. Any type of real sportiness would ruin that.
    #48 TGTGUUD, Jun 3, 2026
    Blackat likes this.
  9. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
  10. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Other than the efficiency drop, what other changes did you reap? Was tire noise any better or worse? Did you catch yourself carrying higher speeds through bends?
    How wide is the difference in rain handling between the two?
  11. TGTGUUD
    TGTGUUD Member
    100
    77
    San Francisco
    2024 Prius
    The DWS06+ rides better in every way: Less noise, more grip, sharper turn-in, no understeers and even slightly more comfort. The car now corners at scary speeds (I'm the bottleneck). Very stable in wet conditions. The Toyos were not bad in the rain too.
  12. MechaDragon
    2024 Prius
    Ya see I figured the wider and grippier tires would ruin the fuel economy so since my Prius is stock with stock suspension and stock power, Im sticking to efficiency with this one. I just picked up the Bridgestone Ecopia EP422-Plus tires to replace the factory Toyo Extensa's in the OEM 195/60R17 size. I have been learning how to drive the car more efficiently in summer and causing it to kick into EV mode more often. As a result I have picked up a few more MPG lately. I am 200 miles into my current tank and am averaging 66 MPG. I havent installed the Bridgestones yet, I bought them early because there was a Memorial Day sale, but Im hoping I can push to 70+ MPG on the Bridgestones since they actually have a low rolling resistance certification.
    Ya, I know a sporty version of the Prius wouldn't have the same fuel economy. The idea for a sporty Prius strikes an ideal balance. I know a Sporty Prius would get nowhere near the 70 MPG I am getting close to now. However, if engineered smart and correctly, a Prius could be made pretty sporty and still offer a solid 50 MPG. I have the absolute most basic LE FWD to save on costs and be more efficient than any other Prius. To make a Sporty Prius thats still efficient, you would want to start with the base LE FWD to save weight. Simply add 40-50 BHP, slightly wider and larger 18"x7" lightweight forged alloy wheels, 215/50R18 or 215/45R18 tires, drop the ride height about 0.5-0.75 inches, stiffen the suspension 15-20% (not too much we still want a fairly comfortable daily driver, just less body roll and a bit more grip), and then maybe add the larger infotainment screen and a heated steering wheel to make it feel more premium. Then of course you can still add in the rear motor and axle for optional AWD option at the expense of more fuel consumption. Otherwise, keep the weight down as much as humanly possible. There is a very good reason why the LE trim is so much more efficient than the XSE or Limited trims.
    That GRMN Corolla looks incredible, but Ive never really been interested in the GR Corolla. The GR Corolla has always been slower that its competition - the Volkswagen Golf-R, and I would much rather have the more comfortable ride of the Golf for daily driving anyways. Plus, the Golf has drift mode whereas the Corolla can't really powerslide, and thanks to the absolutely TINY 1.6L 3-Cylinder relying so heavily on boost to have any power whatsoever, the GR Corolla has horrible turbo lag. I really don't see the point of the 3-Cylinder. VWs Golf-R offers more power and the same fuel economy with much less turbo lag out of a much more sensible 2.0L 4-Cylinder. The 3-Cylinder idea has always been an odd ball choice ever since its original design for the GR Yaris in Europe.
    If anything, Ill be waiting for the new GR Celica to come out. Its looking like it will be a much better car overall. It will combine a powerful 2.0L Turbocharged 4-Cylinder with a Hybrid-Electric system to create an AWD, 300+ HP beast that should still manage 40-45 MPG on the highway. Much less turbo lag, much better fuel economy, more torque. The only negative is that it probably won't be the liftback body since Toyota already has the Corolla for a hot hatch.
    If Toyota really wants to render the VW options pointless, they have to strike a nice balance between efficiency, power, and comfort that the VWs have always offered. The GTI can do about 35 MPG highway with its 248 BHP Turbocharged 4-Cylinder (its a de-tuned Golf-R engine). So if Toyota can use its hybrid system effectively, I could see a base trim/model GR Celica offering anywhere from 275-300 BHP while offering 40+ MPG on the highway. And then, just like the Golf-R offers an even more premium, higher performance 330 BHP AWD option at 30 MPG highway, a higher-tier model/trim option for the GR Celica could offer 350-380 BHP, AWD, and maybe 33-35 MPG highway, using the hybrid electric system to defeat the VWs across all metrics. However, VW has always been the MASTER at offering cars that are sporty and fun to drive, but are also very comfortable and feel quite luxurious inside. VW is KING when it comes to striking the ideal balance for an enthusiast daily driver. Nothing comes close to the sheer daily driving perfection that a VW Golf-GTI offers. The closest alternative as of right now is probably the BMW 2-Series Coupes, which are great cars but offer less practicality, RWD making them useless in the snow (unless you pay even more for X-Drive), and they cost a lot more with a base model/trim 230i RWD at at full $7,000 more than a Golf-GTI S (base trim).
    #52 MechaDragon, Jun 3, 2026
  13. MechaDragon
    2024 Prius
    Well the upcoming GR Celica is now basically 100% confirmed. He got to drive a prototype yesterday. The Prototype G20E powertrain was put into a GR Yaris chassis/body so pretty much the only things left to do at this point are - Celica Body/Design and the hybrid system that Toyota has mentioned. I don't believe the prototype he drove had the hybrid system in it:
