I bought a 08522-B1010 replacement horn; why are there two different bolts?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Scott_R, May 11, 2026.
  1. Scott_R
    Scott_R Member
    449
    25
    Long Island
    2024 Prius Prime
    I scanned the Japanese language install instructions through Google translate, and they confirmed they are supposed to be two different sizes: M8 x 25mm and M6 x 30mm. Also, the M6 has a Philips head.
    Of course, the instructions aren't meant for a Gen 5 Prius, but the install is for the high pitch horn to be on the left, with the M8, and the low pitch to be on the right (in place of the original, if I'm interpreting the install videos correctly) on the right with the M6.
    I suppose I can reuse the one existing bolt, but are there really two different bolts involved here--are the attachment points different sizes?
  2. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    One of the new bolts(and spacer?) will be a match to what's already on your car. Use the matching one for the new location(passenger side) and reuse the existing one for the original side(drivers).
  3. Scott_R
    Scott_R Member
    449
    25
    Long Island
    2024 Prius Prime
    I don't think the old horn uses a spacer; the replacement has is larger, so I guess the spacer is used so it clears the mounting area. But the one spacer is also sized for the M6.
  4. Hammersmith
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I installed the same kit a couple years ago. I just know I was able to do it with just the parts in the kit(I had some leftovers).
    Eddie F likes this.
  5. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    I just installed this Premium dual horn upgrade kit today. It’s a great upgrade! The kit came with everything needed including some spacers and longer bolts which are not all needed for the Prius but may be required for other models.
    I made a short video showing how I did the install:
    https://youtube.com/shorts/XwnIUXTjHBI?si=q_r9l0heK63YYrZm
  6. Hammersmith
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You didn't install it quite correctly, but the difference doesn't matter. Instead of repurposing one of the hood latch bolts, you're technically supposed to use an open hole that's symmetrical to the existing horn location. It's one of the reasons for the extra bolts in the kit. But your way works well enough.
    If I think about it tomorrow, maybe I'll take some pics or a short video to show my install from a couple years ago using the same kit. I've been wanting to do a little touch up of the wiring that I skipped back then anyway. Just some zip ties to clean it up a bit.
  7. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    The instructions that came with the kit did show the horn mounted to the hood latch and it does fit there.
  8. Hammersmith
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, but those instructions aren't for a Prius(assuming they're the original instructions in Japanese). Did you notice that none of the diagrams matched your car and the other horn in the drawings is nowhere near where it is on a Prius?
    Again, it doesn't really matter because the hood latch location works fine, but there's a second mounting point on the passenger side of the radiator core support that's specifically for a second horn. The Vietnamese version of the Prius comes standard with a second hockey puck style horn and that's where it goes. The only reason I point it out is because I get a little obsessive about keeping things as OEM as possible on my own car.
  9. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    Thanks for the info Hammersmith. I’ll add a comment in my video description.
    Bottom line is that this is a great modification to the Prius. In doing it I realized that the Toyota engineers were looking at every part of the car to save weight and cost and that the Prius efficiency has come about by all kinds of small increments. In this case I am willing to pack around a slightly heavier horn system!
