Serious Rattle and Shake *not at startup
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frontporch, Jun 1, 2026 at 1:43 PM.
  1. Frontporch
    Frontporch Active Member
    541
    125
    Nj
    Just the other day I was going to take a nice long drive and the Prius acted a little funny. The battery was down to two bars and when I started the car it was fine, took it up a small hill and it kind of slowed the motor, shook like crazy and then revved pretty high two times... I shut it down... Convinced the battery just needed charging I tried to drive around a little bit, but my copilot wanted nothing with taking the Prius at that point. Yesterday, days later, I returned. Took the Prius for a short drive this morning and the battery went back up to darn near full on the dash. Thought things were back to normal.
    Just now, at lunch, I took a short drive, maybe 3 miles. Everything seemed fine. Went to make a K turn to park the car and again, the motor kind of started to shake and rattle at what felt like a low idle... parked the car... Later I drove home, things at first seemed OK. Went down that small hill to my house and was going to parallel park... Battery was not low... probably two bars off full.
    When I stopped to back up the motor came on and it started to shake... switched to reverse and there was some crazy shaking... Shut the car off. I started again and using the battery pulled into the driveway.
    No check engine light.
    No loss of coolant or any issues at first start.
    MPG on that short trip was around 50
    No strange smells
    No work done prior to this
    Slow burner of oil but level is fine
    ODO at around 205000
    EGR cooler pressure washed late 2024, EGR piping cleaned
    For the past few weeks I had heard intermittent rattles ( not shaking ) that I assumed was a heat shield
    Any thoughts?
    Appreciate the help
    52,613
    how many miles? has the ego circuit been cleaned?
    Frontporch likes this.
  3. Frontporch
    541
    125
    Nj
    Added that info above.. thanks. I did take the EGR valve apart ( shouldn't have done that) to clean it and was careful to put it back together. Zero problems over 15K miles later
    #3 Frontporch, Jun 1, 2026 at 1:46 PM
  4. CR94
    CR94 Senior Member
    2,785
    1,224
    Northwestern S.C.
    Were the small EGR ports in the intake manifold also cleaned? That's the most critical area---although a lot easier to remove and to unclog than the cooler.
  5. bisco
    52,613
    I hate to say it, but the very beginning of a head gasket leak won't use noticeable coolant. I am surprised there's no cel.
    plugs? injectors? throttle body? air filter and housing?
  6. Frontporch
    541
    125
    Nj
    I always thought the shaking was at startup when coolant is in the cylinders. This happens after a little driving. Doesn’t seem like hydro lock
    I did clean the intake manifold but i must admit that the insides were coated with a substance like tar so cleaning that was a chore. That said I soaked and soaked and sprayed. Was at it for a week with degreasers and boiling water…
    plugs may not be newer. I would expect mpg to have issues and drivability other than idle??
    pretty sure I cleaned out the throttle body when I was cleaning the intake manifold, recent air cleaner.
    have not touched the fuel injectors
    #6 Frontporch, Jun 1, 2026 at 4:56 PM
  7. Mendel Leisk
    42,112
    Was that the first EGR cleaning? Seem to recollect you did clean before, but I can barely remember what I had for breakfast.
  8. Frontporch
    541
    125
    Nj
    That makes two of us
    I got the car about that timeframe in 2024. Cooler was clogged as well as intake ports. 188k on the car and I expect my cleaning was the first. Now it’s about 17k miles later
    I was thinking of disconnecting the eGR harness to see if the intermittent shaking goes away
    I was considering picking up a used eGR and cleaning that. I made the mistake of disassembling the guts of the eGR valve but I suppose after all of the trouble free miles it was operational. Maybe till now
  9. Frontporch
    541
    125
    Nj
    I thought for sure disconnecting the eGR would smooth things out but the issue persists. The ice starts smoothly but starts to stumble pretty quickly. There was a smell of raw gas from he tailpipe
    because I disconnected the eGR to now have a code
