Looking for hybrid battery for 2011 Toyota Prius
Discussion in 'Gen 3 Prius Main Forum' started by Gerald10, May 23, 2026.
  1. Gerald10
    Gerald10 Junior Member
    Brian1954 would that show as many infos are toyota techstream?
  2. Brian1954
    Brian1954 Senior Member
    2,650
    1,058
    South Central PA, USA
    Yes, I believe it does.
    I like the Autel AP200 because it is small and inexpensive, and it can easily be stored in the Prius so that it is available whenever I need it. I always carry my cell phone, which has the Autel app installed, when I travel.
    I also have Techstream, and I like the user interface better than the Autel AP200 app. Techstream software needs to be installed onto a laptop computer. I use it at home. I normally do not carry that old laptop in the car when I am traveling.
    There are many other scanners that are capable of reading freeze frame data. They are priced from a few hundred dollars all the way up to thousands of dollars.
    #22 Brian1954, Jun 3, 2026
  3. Brian1954
    2,650
    1,058
