Looking to Buy a 2002, good idea?
Discussion in 'Newbie Forum' started by Bannister, May 28, 2026.
Tags:
  1. Moving Right Along
    Moving Right Along Senior Member
    737
    593
    Generally speaking, if the battery charge seems to rapidly go from empty to full and back again and you’re regularly getting average fuel economy that’s below 30 mpg in winter or below 40 mpg in summer, it means your traction battery is having problems and is getting close to worn out. Another potential sign of a weak traction battery is poor performance when trying to go uphill. If that is happening as well, I would suspect that the traction battery is not doing well and could need to be replaced relatively soon (possibly in the next few months to a year).
    Bannister likes this.
  2. Moving Right Along
    737
    593
    Each car shown is a specific amount of energy recovered by regenerative braking. The more you drive downhill (using brakes) and in stop and go traffic, the more of those car icons you should see. If you’re driving on roughly flat surfaces at a constant speed, you won’t see any. The symbols don’t tell you much about the health of the traction battery. They just let you know the regenerative brakes are working properly.
  3. ChapmanF
    18,838
    Each little car symbol is worth 50 watt hours (not kilowatt hours! :eek:) Any time your regen braking has recovered that much energy, a little car is shown. (I think you can also get half little cars, worth 25 Wh.)
    For a sense of scale, 50 Wh is about the energy needed to raise a one-ton weight 66 feet up. (Or a 1000 kg weight 18 meters up, if that sounds better.)
    50 kWh :eek: would be like a one-ton weight raised 12½ miles.* If you could recover that much energy in regen braking, we'd really want to know where you were driving!
    * I'm treating g there as the same as at ground level. At 12½ miles that's probably lazy of me.
  4. Bannister
    Bannister New Member
    Washington
    Thanks guys, learning all of this in real time. Apparently Bluedriver doesnt work with Dr Prius so I’m gonna have to wait for payday. Getting an inspection by Toyota is $200. Any of you think it’s worth it? I need some kind of post buy inspection so i guess it doesnt matter.
    But yeah I think my battery is worn down but i think i can make it for another few months so i can save up.
  5. bisco
    52,638
    I wouldn't waste the 200 bucks
  6. Bannister
    Washington
    Really? Don’t you recommend getting it inspected? Or are you saying these are things i can do myself? Is there a thread that has an inspection checklist?
  7. bisco
    52,638
    there's no inspection checklist, and most dealers will fabricate money making repairs.
    I'd invest in getting dr. prius working, tech stream or auto scanner, and the tools necessary to diy if you're so inclined.
    if not, I'd start putting aside money for actual repairs, if and when necessary.
