Help No start 12v battery pull down to 5v
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by BG90, Jun 8, 2026 at 11:13 AM.
  1. BG90
    BG90 New Member
    Friday
    United States
    2014 Prius Plug-in
    Hi there. Wanted to see if anyone have seen this issue before? I'm having electric issues on my 2014 plug-in prius. The 12V battery is getting pull down to 5V and symptom is that of a total dead battery. Car will start with a jump pack. Car drives normal and is charging the battery at 14v. Battery is around 3 year old but still good. Battery measures 13v when disconnected from the car but 5v when connected. No check engine light on. Any help will be appreciate it.
  2. Brian1954
    Brian1954 Senior Member
    2,540
    1,007
    South Central PA, USA
    Are you saying that when the 12v battery is connected to the car and the car is off, the battery voltage measures 5 volts?
