Are these recommendations the same? ‘Replace brake accumulator’ and ‘replace brake actuator assemb
Discussion in 'Gen 2 Prius Technical Discussion' started by Jennifer33777, Jul 12, 2024.
  1. Jennifer33777
    Jennifer33777 New Member
    Ohio
    After taking in my car for an evaluation at the Toyota garage I got this texted to me:
    C1256 low pressure in accumulator
    C1391abnormal leak
    replace brake actuator assembly
    When I picked up my car and the paperwork listed the same codes but it said recommend to replace brake accumulator
    The Toyota shop wants 3.5k for the job, so I’m trying to find another shop that has done this and want to make sure I ask for the correct thing.
    Also, I’ve replaced the 12 V battery (5yrs ago) and the inverter (2-3 years ago) - It seems from this chat that this accumulator issue is common. If I keep the car and repair it am I looking at any other big cost repairs that are common coming up soon?
    I appreciate so much the responses I’ve gotten to previous question.
    Meg&Bear likes this.
  2. ChapmanF
    18,839
    On a gen 2, those are the same thing.
    On other Prius generations, those are two different things.
  3. Tombukt2
    13,716
    2,483
    You stop talking to the Toyota shop right away You're in Ohio You can do a lot better very quickly I didn't notice the city you're in but you can do way better somebody just posted the part up here they bought it online directly from Toyota brand new in the box for $1,100 or something like that so there's that handled they're charging you 14 to $1,700 at the Toyota shop just for the part so that saving you three to whatever $100 right there and then generally this job takes me about 2.2 hours to do the physical labor in about 40 minutes to bleed the brakes with the proper software If I could get close to $2,000 for that I'd be rolling pretty good generally that gets me about 5:50 if I'm lucky too bad you're not closer I guess. You can do better so minus the part price from my total here you see what you're paying per hour for labor and I'm telling you the hours that it actually takes me and I am near 70 years old and I'm not blazing fast I guess I'm quicker than some of these guys doesn't really matter The point is I couldn't consciously charge some poor woman or anybody for that matter 15 to $1,700 for the labor on this job I've been working on stuff a long time there's just no way I can justify 3 hours of my time at $1,900 1750 I would love to but you know that just doesn't seem correct That's the difference between those guys now and the old guys I guess
    AvTech72, Jennifer33777 and Meg&Bear like this.
  4. AvTech72
    AvTech72 Junior Member
    31
    Miami Beach, FL 33140
    Three Touring
    What does the replacement look like? Any reference for the manuals? Any chance to repair it for cheaper?
  5. ChapmanF
    18,839
    Toyota Service Information and Where To Find It | PriusChat
    If you've done any comparable brake work before (say, replaced an ABS actuator in another car), it looks pretty much like that. It will be fairly tedious, with some electrical connections and a number of hydraulic connections to deal with, challenging access, and an air-bleeding procedure when you are done that presumes you have access to a suitable scan tool. If you don't have that already, the Autel AP200 is inexpensive and usually gets favorable comments here.
    Or do you mean what does the replacement part look like?
  6. AvTech72
    31
    Three Touring
    I have not done considerable work, but am fairly competent, namely on aircraft, and would like to learn how to service my own vehicle. Aircraft are alot more mechanic friendly though and have better manuals for diagnosing issues. As a certified A&P, I love my manuals and step by step instructions. Ill even admit, Im a bit spoiled by it! With cars, theres a level of ingenuity and imagination for solving problems that the books, or written manuals, wont explicitly state always.. any specialty tools required or techniques that provide invaluable expertise for a job like this?
    Thanks in advance!
