Looking for others with 12V battery problems for class action lawsuit
Discussion in 'Gen 5 Prius Main Forum' started by Rick B., Jun 4, 2026.
  1. schja01
    schja01 Senior Member
    1,866
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    I have considered this. Just can’t sever the umbilical cord.
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    6,669
    2,647
    Paramount CA
    Yeah, owning a car is much easier.
    If you don’t need to drive the car, simply sit in it for an hour in READY mode once a week. Read a book or surf the Internet. LOL. That should eliminate the need for a battery maintainer.
  3. BiomedO1
    4,443
    2,341
    Left Coast
    That's fine; but I need to point out that your PC MUST be plugged-in too.o_O:whistle: A laptop in sleep mode will eventually die, if unplugged requiring a full reboot. No power to keep the memory circuits alive.
    The reason it burns down the battery is your FOB and alarm system. A physical key system doesn't need to constantly scan the spectrum, because it doesn't know when your going to drive it. An ignition key will pretty much shut everything OFF, when keyed OFF. The nature of the beast; more conveniences requires sacrifices.
    ie; you want accurate AI predictive algorithms; you give up your privacy.
  4. schja01
    1,866
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    The Smart Key system does go into a low power mode after a while. Don’t forget the Telematics system (all the “ Connect” products) is a big power user.
    BiomedO1 likes this.
  5. Gokhan
    6,669
    2,647
    Paramount CA
    No, this is simply false. The smart key system goes to deep sleep in less than two minutes if the key fob is more than three feet away.
    You need to hook up a battery monitor and observe what is going.
    Telematics, which was mentioned, is usually asleep as well.
  6. bisco
    52,694
    I used to leave my gen 2 for 3 months every winter, no problem. gen 3 as well, but the 12v only lasted 6 years
  7. Da1sy
    Da1sy Junior Member
    Wisconsin
    2024 Prius
    I was not advised of this when I purchased my new 2024 Prius Limited. I have had seven battery failures due to the 12 V. the
    The first time was very interesting. I was on a car ferry and it died on the last trip to the island. THAT was special ! My vehicle was also involved in an accident while parked at 350 miles. The back quarter panel, wheel well, hatch as well as the bumper were very damaged. The 12 V actually exploded an impact. After 4 months in the shop and 18,000 in repairs I got it back. I assumed that the 12 V failure was due to an electrical issue with the repairs. The vehicle has now failed seven times. They continue to check the 12 V battery and they’re telling me that it is fine. Should I love it or leave it? I am looking into a CPO XLE AWD with low miles and the white pearl which is difficult to find. I have included a recording of my Prius the seventh time it was in the garage. Please note that the engine noise was present when the vehicle was turned off.
    Gokhan and bisco like this.
  8. bisco
    52,694
    saving gas is expensive. I wonder how the lawsuit is progressing
    Blackat likes this.
