Prius T4 UK Coolant Overflow from the expansion Tank
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Muhammad Sarwar, Jun 8, 2026.
  1. Muhammad Sarwar
    Muhammad Sarwar New Member
    UK
    ----UK----
    I have a Prius T4 UK model.
    3 months ago i got a warning for EGR system. I cleaned the manifold, throtle body, egr valve, pipe and egr coolar. so, no more issues.
    About 2 months ago i got RED overheat warning symbol appear on dashboard for couple of seconds on the motoway, i reduce my speed to 65 miles and it disappear. it happened 2/3 times at the same place on motoway going uphill. i checked the water pump and the rotar was stuck, BUT I DIDNOT RECEIVED ANY ERROR CODE. so, i changed the water pump.
    My car have done 216k plus miles.
    Now, my coolant is getting low and overflow from expansion tank. i keep on checking and toping it up. some time the coolant on the oustside of reservoir is bubbling.
    i manualy checked the cap but didnot find any issue.when i shake cap it produce clicking noise.
    i put a OBDII device and keep checking the coolant temperature which generally remain between 85 to 90 degree Celsius. when on motoway it goes up to 94 max but comes down afterwards.
    So, i need guidance what should i do, change thermostat or cap or ....
    All suggestions and advises appreciated.
    Thanks
  2. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    Did you buy a Toyota OEM pump or an aftermarket pump?
  3. Muhammad Sarwar
    UK
    ----UK----
    it’s original used Toyota I think they replaced the rotor
  4. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Do you have get the engine knocking?
    Because it seems like the head gasket is failing.
    Depending on how long you drive it while it was overheating, hopefully you didn't
    cause any other damage....
    Brian1954 likes this.
  5. Muhammad Sarwar
    UK
    ----UK----
    thanks,
    yes engine rattle at cold start and when i dont drive for months. But after i start using 0W20 it was gone as my garge used 5w30. i didnot have any rattels over a year. my usual commute is 30 miles. when it give the warning i stopped and travel only 6 miles.
  6. ASRDogman
    8,070
    4,092
    You should do a pressure test. And run a bore scope in the cylinders to see if you can see
    the cooling leaking into the cylinders. And check for cleaned off pistons.
    Muhammad Sarwar likes this.
