search engine alternative?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jun 5, 2026 at 7:39 PM.
  1. Stevewoods
    Stevewoods Senior Member
    664
    1,225
    where I am
    Used Google and Chrome for the past several years, but in the past several months, ads on Priuschat became so invasive, taking a hint from Mendal switched to FireFox with Ublock and DuckDuckGo.
    Am finding DuckDuckGo is somewhat okay, but a bit wanting. Okay, a lot wanting. Well, that's me. I am sure the Duck is great for many folk, but I do have obtuse search ideas, such as folks climbing Mt. Foraker in 1993.
    But Firefox with the adblock is fantastic.
    Would like to stay away from Google. Any search engines that "wow" you without raping you in the process?
  2. PriusCamper
    PriusCamper Senior Member
    13,307
    5,379
    Pacific Northwest, USA
    Yeah... Google Search became unusable to me well by end of last year. DuckDuckGo and Firefox was part of my De-Google strategy last Fall. So far it works fairly well for everything except street addresses for directions and to confirm location. It's terrible at making it easy to find stuff on a map. Also its AI is good for brief simple answers but am often failing its reply and heading to Claude to get more accurate info to questions with more complexity.
  3. John321
    John321 Senior Member
    1,472
    1,411
    Kentucky
    Microsoft Edge/Bing with AdblockPlus eliminates all adds for me.
    #3 John321, Jun 5, 2026 at 8:45 PM
  4. fuzzy1
    10,647
    I'm trying to avoid Edge too, don't believe it gives me as much control as FireFox.
    ETC(SS), BiomedO1 and John321 like this.
  5. Trollbait
    12,769
    Policy at work makes adding software more convoluted, so I stuck with Edge with my PC upgrade. Whatever ad-block plug-in I added works. Also set it to wipe cookies and history when exiting.
    Home is Firefox and Ghostery with duckduckgo. Brave is one I haven't gotten around to trying. I keep meaning to add -ai to search queries.
  6. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    You mentioned search in the title but seem to be refering to browsers. I stick with the Safari browser and selected DuckDuckGo for the search engine. I tried the DuckDuckGo browser a while back but came back to Safari.
  7. BiomedO1
    4,411
    2,323
    Left Coast
    Just a note; Edge fires a bunch of background processes and the last time I checked - several years ago; it stored everything in a "back-up" directory - even when set to erase on exit. Ditto; with outlook. That's part of the security and administration process of MS-OS. I believe it's even more tightly knit together with "resume - on another device". That information is saved on a central server somewhere, so you can login from a totally different device and resume your work. Nothing is as private as you think it is. You give up security and privacy for convenience and access across a VPN - if it's setup properly. I started my career as a programmer; now called app specialist, designer??? Don't know and haven't kept up, because the pay was lousy, the hours was long, and there was always that guy in India that would work for rice or peanuts. No offense; cost of living in India is much cheaper than in the states......
    YMMV
  8. Stevewoods
    664
    1,225
    where I am
    Most interested in: Search Engine.
    Google level results.
    Not Google level tracking, etc.
    The duck is just not doing it. Did a search on an Alaska climb and got four returns from duckduckgo.
    Google had pages. Sure, some of Google's results were out there, but many were what I was looking for.
    #8 Stevewoods, Jun 6, 2026 at 1:35 PM
  9. Trollbait
    12,769
    Forgot to mention I use Bing at work. Works well enough. Might double check something on Google, but that's rare.Bing mostly annoys me be the larger AI response splash.
    Just switched DuckDuckGo to Brave at home. Will report back, but I mostly just going to the same old same old, so this may not be soon.
    I assume we are talking full fledge computer here, and not something Android based. I use Firefox Focus for browser/engine on my phone.
  10. Mendel Leisk
    42,121
    How so. I'm using Google, not feeling in pain in my nether region. Ignorance is bliss?
    Absurdly off-topic, but one thing that DOES have that effect, for example: seeing some come off a skateboard awkwardly, that sort of thing. I'll sometimes get a sharp jab of pain, you-know-where. It's some sort of sympathetic reaction I guess.
  11. bisco
    52,648
    I tried the duck but wasn't satisfied. google with Adblock works well, but this is with apple
  12. Isaac Zachary
    Isaac Zachary Senior Member
    2,741
    1,457
    I find that there are these things outside of my house called neighbors and if I go outside under that bright shining sunlight I can sometimes talk to a few of them and ask them questions. And as I go around town on foot I can go into any store and ask even more questions. Sometimes the answers aren't all that accurate (although probably more accurate than what AI can do), and sometimes there aren't any answers, but a lot of time there are answers, and if I don't understand it they break it down for me.
    And then I not only get a lot of answers I also get these things called friends that not only can answer complex questions, they can also help solve problems that search engines can't, like how can I find my cat Mittens? And sometimes I end up being the one who helps solve someone else's problem, like when the neighbor's car wouldn't start but she had these things called jumper cables that I connected to the battery of my own car. The next thing you know the neighbors are coming over asking for a cup of sugar and then come back with pie! It's awesome! Much better than Google!
    (No offense intended with this parody.)
  13. bisco
    52,648
    I do the same with YouTube. it's amazing how smart and talented people are, and kind of them to share their knowledge with total strangers all over the world.
    <and now, back to our regularly scheduled program> :cool:
    Isaac Zachary likes this.
  14. Stevewoods
    664
    1,225
    where I am
    Sorta doubt random neighbors would have answers to routes up Mt. Foraker...
    And last time I went to closest neighbor (1/4 mile away) she came out in a robe revealing more than I needed to see.:oops:
  15. bisco
    52,648
  16. Stevewoods
    664
    1,225
    where I am
    The neighbor with shotgun; no.
    My wife with shotgun after I told her..:eek:..
    Well, not really, but have not been back to that neighbor.:whistle:
  17. Isaac Zachary
    2,741
    1,457
    I just got in from talking to my neighbors. Now I understand why there was a cop at my place when I was pulling in as he was just leaving.
    It's nice to have good neighbors, live near family and friends, be able to take care of my aging folks, etc. etc.
  18. Stevewoods
    664
    1,225
    where I am
    I remember my high school distance coach. He retired the year I graduated. I was not half-bad as a runner. Did a mile in 4 minutes 12 seconds.
    Anyway, he said the key to happy retirement was to move to a small town, far from relatives, but within 45 minutes of a decent airport.
    Seemed to have worked for me.
  19. bisco
    52,648
    you can't beat friendly neighbors, but they can be hard to come by. most people seem to hide in their houses these days
