Could The Drivers Seat Back Be Modified To Go Further Forward?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by richard1540, Jun 5, 2026 at 7:12 AM.
  1. richard1540
    richard1540 Junior Member
    Australia
    i-Tech
    I’ve been travelling in my gen 3 for a while and always sleep in the back. I’m 6’2” and i fit, but it’s a bit tight. It would be great if i could get the drivers seat back to go further forward like a coupe’s front seat does.
    I’m in Australia so my Prius is right wheel drive. The wider section of the rear backrest is on the drivers side so that’s the side i sleep on.
    Is this possible and if it was would it create a safety issue that was illegal.
    52,651
  3. PriusCamper
    PriusCamper Senior Member
    13,308
    5,379
    Pacific Northwest, USA
    If you remove the headrests on the front seats and slide them all the way forward they will recline flush with back seat... And if you replace the center arm rest and area behind it with pillows you'll have a way more comfortable and refreshing night's rest without disturbing your storage space in the back of the car.
  4. richard1540
    Australia
    i-Tech
    I removed the front and rear headrests and moved the front seat all the way forward, but couldn’t get the front seat back past the rear seat back as in the picture. Do i need to recline the front seat back before i put the rear seat back forward? I have so much junk in the rear i haven’t tried yet.
    Are you saying i should remove the centre arm rest completely? I’ve been thinking about doing that for a while as i don’t like the awkward lid openning arrangement.
  5. richard1540
    Australia
    i-Tech
    Not for this particular situation but i would certainly be interested to get a bit more room when driving. Can you tell me if the passenger and driver side brackets are the same?
  6. PriusCamper
    13,308
    5,379
    You need to put the rear seat backs up in their regular position if you want to recline the front seat back down flush with the bottom backseat cushion. Also here's a right-handed drive Gen3 that's been modified to eliminate center console and flying buttress. I hope someday to do a mod like this:
