Looking for others with 12V battery problems for class action lawsuit
Discussion in 'Gen 5 Prius Main Forum' started by Rick B., Jun 4, 2026 at 7:09 PM.
  1. schja01
    schja01 Senior Member
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    I have considered this. Just can’t sever the umbilical cord.
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    6,657
    2,640
    Paramount CA
    Yeah, owning a car is much easier.
    If you don’t need to drive the car, simply sit in it for an hour in READY mode once a week. Read a book or surf the Internet. LOL. That should eliminate the need for a battery maintainer.
  3. BiomedO1
    4,411
    2,324
    Left Coast
    That's fine; but I need to point out that your PC MUST be plugged-in too.o_O:whistle: A laptop in sleep mode will eventually die, if unplugged requiring a full reboot. No power to keep the memory circuits alive.
    The reason it burns down the battery is your FOB and alarm system. A physical key system doesn't need to constantly scan the spectrum, because it doesn't know when your going to drive it. An ignition key will pretty much shut everything OFF, when keyed OFF. The nature of the beast; more conveniences requires sacrifices.
    ie; you want accurate AI predictive algorithms; you give up your privacy.
  4. schja01
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    The Smart Key system does go into a low power mode after a while. Don’t forget the Telematics system (all the “ Connect” products) is a big power user.
    BiomedO1 likes this.
  5. Gokhan
    6,657
    2,640
    Paramount CA
    No, this is simply false. The smart key system goes to deep sleep in less than two minutes if the key fob is more than three feet away.
    You need to hook up a battery monitor and observe what is going.
    Telematics, which was mentioned, is usually asleep as well.
  6. bisco
    52,650
    I used to leave my gen 2 for 3 months every winter, no problem. gen 3 as well, but the 12v only lasted 6 years
