My 2012 Prius V with 172,000 miles started having the oil light comes on even when the oil is full?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tina L Moore, May 20, 2026.
  1. Tina L Moore
    Tina L Moore New Member
    Lombard, IL
    Yes, that is the light, the dealership ran diagnostics and said it burns oil drive it and check the oil every 1000 miles- gave the car back with the oil light on. Said a new engine would be $7,000 the only one available had 110,000 miles on it and he said that his car does the same thing and he drives it and just checks the oil. Also that the hybrid battery was another factor to consider that will need replacing in the future.
    when I put fuel injection cleaner in (2oz) the light went off for 3 days then back on with a shaky start up for a few seconds.
  2. rjparker
    10,821
    6,792
    That is new information. One thing to know is Service Advisors at dealerships are usually commissioned salesmen often with no mechanic experience. They try to translate a mechanic's notes to something a typical customer might understand and often lose context in the process.
    Shaky starts could be a sign of a problem. The engines have two common shaky start issues; one is a head gasket leak and a second is a sticking open egr valve. Both can be intermittent, eg not every time or even every day.
    As a result a dealer mechanic might not experience it.
    While unusual, clogged fuel injectors can also cause a shaky start but would normally continue and code as misfires.
    The shakes could be bad enough to reduce oil pressure if the oil pump or oil passages were already partially clogged.
    However the oil light staying on longer than 5 seconds really is not good. It could fail completely at any time.
    #22 rjparker, Jun 9, 2026 at 8:41 AM
    BiomedO1 likes this.
  3. Mendel Leisk
    42,126
    For a heady moment I thought “huh, $7k (USD) for a new engine, not bad”. Then reality set in.
  4. ETC(SS)
    7,420
    Tina,
    You need to start seeing other mechanics.
    Immediately.
    Like......before you drive it again.
    As stated before, 99.44% of the time when you see a red oil pressure light then your engine is the process of destroying itself.
    Also, as stated before the "shaky startup" is something else entirely.
    It's like chest pain in a human.
    It could be gas pains.....or......you might be having a heart attack.
    and.....$7,000 for a new, 110,000 mile engine?
    Did they say that with a straight face - or is 110,000 miles the warranty period for the new engine??
  5. rjparker
    10,821
    6,792
    Toyota does not sell new engines. You can buy a new short block and separately get a new head as an assembly but that's about it.
    Mendel Leisk and BiomedO1 like this.
  6. BiomedO1
    4,417
    2,326
    Left Coast
    That's NOT the issue and basically BS. Injectors can leak gas into the combustion chamber and a very bad injector leak would throw a bunch of error codes, so your CEL should be lit also. You would smell gasoline on your engine oil dip stick. The gasoline would thin-out the oil and cause a low oil pressure issue. Your mpg would also take a good wrack. ANY decent mechanic would recommend an oil change and replacement of the leaky injector(s) - NOT tell you to dump injection cleaner into your gas tank an call it a day; because your causing long term damage to your engine.
    You need to have someone else that's competent look at your car.
    You may want to talk to these guys: TCCN Automotive
    Sorry...:(
  7. Tina L Moore
    Lombard, IL
    I took it to my friends son’s shop- family owned for 68 years- he did many diagnostics- put a new oil switch on and finally today he said : ( I put a coolant sealer in, it stops the shaking on startup and the oil light does not come on, this will last you until the winter. I highly suggest you trade in this car or get and get a new one before winter sets in. When it’s warm weather it will be OK. In the Winter he cannot guarantee and his hands are done.)
    He’s told me I need to trade this car. It’s burning oil not that much, but the head gasket needs to be changed.
    This is his recommendation and he saved me as much money as he could to keep it running for as long as he could without issues.
  8. rjparker
    10,821
    6,792
    So you have a blown head gasket and now have sealer in it. It might last 1-6 months until the sealer wears off.
    Putting in sealer has downsides as well and is usually not recommended for a car because of its potential to clog up heaters and radiators.
    If you afford a much newer car, now is the time to do it.
    Tina L Moore and BiomedO1 like this.
  9. BiomedO1
    4,417
    2,326
    Left Coast
    The coolant sealer will clog your cooling system and most likely overheat your engine during the summer months. You'll need to pull over and shut-down when the temp lamp lights up or you can just keep driving it and "blow it up".
    Good Luck......
    Tina L Moore likes this.
  10. Mendel Leisk
    42,126
    oh dear…
    I once asked a dealership service writer if it was normal to hear a whistling sound from gas cap, after a long drive on a hot day (it was). Anyway, the next little while I was always smelling gas in the garage: the jokers had run with that question: drilled a “vent hole” through the gas cap.
    regardless of the shops familiarity and longevity, they just messed up your car even more. That stuff should be illegal. It’s basically a sealant, that’ll gum up everything it’s in contact with: radiator, cabin heater core, water pump, thermostat, all the coolant passages in the engine.
    the “shaking on start up” is due to coolant pooling in the cylinders, having leaked past the failing head gasket.
    A proper course of action would be replace the head gasket, and all the other gaskets encountered, AND thoroughly clean the EGR (Exhaust Gas Recirculation) system, including intake manifold’s EGR passages.
    #30 Mendel Leisk, Jun 10, 2026 at 8:39 AM
  11. Tina L Moore
    Lombard, IL
    Yes, thank you that is what my mechanic told me to do. Any recommendations on the best car for low budget?
