Featured The all-new 2027 Corolla threatens the Gen 5 (and Gen 6) Prius
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Jun 9, 2026 at 11:42 PM.
  1. Gokhan
    Gokhan Senior Member
    6,663
    2,641
    Paramount CA
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,754
    1,460
    Would it still be as cheap is they put a brand-new engine in it not put in any other Toyota?
    The Corolla already starts at about $25,000. That's a lot of money. If it ends up costing about the same or more than a Prius at around $30,000, especially if it's smaller, then maybe it wouldn't compete.
  3. mikefocke
    4,064
    1,852
    Sanford, NC
    Cannibalize your brand or let someone else do it.
  4. Trollbait
    12,776
    Anything on emission controls?
  5. bisco
    52,662
    looks like something an 18 year old might want, or a midlife crisis
  6. PriusCamper
    PriusCamper Senior Member
    13,316
    5,389
    Pacific Northwest, USA
    I bet the one in all black doesn't look as stupid as the one in gray and black, which literally looks like two different color cars were put together and the lines that creates look incompetent with no sense of flow or clarity to the design, just uncoordinated design chaos.
  7. Trollbait
    12,776
    Or someone wanting a Chinese EV.
    Toyota bZ3 - Wikipedia
  8. Tideland Prius
    16,650
    The Prius needs to evolve to either cover the midsize segment (so fit between the Corolla hatchback and the Crown Signia) or become Toyota's EV platform like it was for hybrids in the early 2000s. Toyota can't keep thinking the Prius is a Corolla class vehicle but charges Camry class prices.
    Right now, the Gen 5 is actually getting people talking. I've had two Gen Z coworkers bring up the Prius while we were chatting cars and they both said they like it. One for fuel efficiency (he rented a carshare which are Corolla Hybrids and Prii models and was amazed at the fuel efficiency of it) and the other liked the sporty design and powertrain. Toyota could lean into that too.
    So either take it as a filler between the Corolla and Camry staples as it has been (but bring the interior up closer to Camry than Corolla) or take it in the direction towards a Civic Si type vehicle - sporty, fuel efficient, reasonably affordable and keep the Corolla level interior.
    Isaac Zachary and Trollbait like this.
  9. Isaac Zachary
    2,754
    1,460
    The Prius might be going away for good.
    If everything Toyota is now a hybrid, why keep the Prius?
    One reason that the Prius had been different, other than being a hybrid when everything else wasn't, was its shape. But the problem I see with car shapes is as cars are pushed to being more and more aerodynamic, they also start to take on the same exact shape. Everything is becoming the Prius in shape. Even SUVs are becoming more and more Prius-like with the push for coupé SUVs like the Model Y.
  10. Gokhan
    6,663
    2,641
    Paramount CA
    If the new Corolla is going to be a hatchback, there is a good chance the Prius will go away.
    The Gen 5 Prius would be a great car if they didn’t mess up the wheels. If you want fuel economy, you are stuck with the base trim. If you want much-needed convenience features, you sacrifice fuel economy. 19” wheels should have been an option only.
