Is there a fob code to put the car into a battery saver mode ?
Discussion in 'Gen 5 Prius Main Forum' started by Graham PR, Jun 10, 2026.
  1. Graham PR
    Graham PR New Member
    Toronto, Canada
    2026 Prius
    XLE AWD-e
    Hi everyone. I'm about to take ownership of my first Prius next week (hopefully) and have been reading up on everything I can get my hands on.
    Somewhere along the line, I thought I saw that you can put the car (not the fob) into a power-saving mode by pressing Lock, Unlock, Lock on the key fob. But now I'm unable to verify that though searches on the forums.
    Am I wrong, or did I somehow see something for a prior year's model ?
    Thanks, and looking forward to joining the Prius community very soon.
  2. mingc
    mingc Member
    104
    74
    Portland, OR
    2023 Prius
    XLE AWD-e
    Yes. For the battery saving mode, press the unlock button twice while holding down on the lock button. The fob light will flash 4 times if you've done it correctly. Take it out of battery saving mode by pressing any button.
  3. Graham PR
    Toronto, Canada
    2026 Prius
    XLE AWD-e
    Thanks for the answer, but I was not asking about the fob's battery saver mode, but putting the car itself into a saving mode, where it reduces the rate that it scans for a fob. I don't drive much, and am looking at this as a way to reduce drain on the 12v battery.
  4. dabluesman
    dabluesman Junior Member
    28
    17
    Eastern USA
    2024 Prius
    Limited AWD-e
    There's a youtube video ( https://youtu.be/c4hpQGxq4iY?is=FFv0vJG0EWKEriYy ) that mentions:
    Battery guardian mode:
    Key fob: Lock, then press lock quickly 2 more times. (Should get a different sounding confirmation tone/sound.)
    Though I've never tried it.
    (That video might be AI slop..)
    #4 dabluesman, Jun 11, 2026
    Graham PR likes this.
  5. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    That's for the fob.
  6. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    didn't work for me.
    I wouldn't mind accessing the diagnostic menu (not just the infotainment), but the odometer button trick didn't work for me. Neither did the temps/volts tip.
  7. Graham PR
    Toronto, Canada
    2026 Prius
    XLE AWD-e
    That's not a video that I had seen, but I have watched some others. Unless someone can confirm here, I'd going to agree with you that it's an AI hallucination. (The one I watched said the code was Lock/unlock/lock quickly in sequence.)
  8. mingc
    mingc Member
    104
    74
    Portland, OR
    2023 Prius
    XLE AWD-e
    D'oh! I'm not aware of battery saving mode for the car itself.
  9. LRO
    LRO Member
    97
    98
    United States
    2024 Prius Prime
    XSE Premium
    Turning on the battery-saving feature of the key fob will also save your 12-volt battery too if you happen to wash or detail your vehicle with the key fob on you (or walk by your car often). Any active key fob that is registered to your vehicle in that kind of proximity kicks the car's electronics and pre-flight routines and pumps into a mode that is anything but sleeping to your 12-volt battery. Something I no longer forget to do with a reminder ...
    VelvetFoot and BiomedO1 like this.
  10. BiomedO1
    4,608
    2,416
    Left Coast
    Drop your keys into a Fariday bag to block it's signals. That'll also keep thieves from amplifying the fob signals and stealing your car; since some people hang their keys by the front door.
  11. Graham PR
    Toronto, Canada
    2026 Prius
    XLE AWD-e
    I found the video that originally told me about this "feature", and yes, it's an AI one.
    It's at 11:30 in
    I'm guessing it's false information, as I can't find anything to confirm it.
  12. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Are you talking about the 12-V battery? The car goes into deep sleep after shutting off, as long as the key fob is at least 3 feet away. No special procedure is needed.
  13. Gokhan
    6,714
    2,672
    Paramount CA
    A Faraday bag is not needed for the car to go into deep sleep. See my previous post.
  14. LRO
    LRO Member
    97
    98
    United States
    2024 Prius Prime
    XSE Premium
    Gen 2 Prius (2004-2009) was last to have a physical button on the dash to Enable/Disable the Smart Key System. Described as "If you do not intend to drive your vehicle for a long time, push the cancel switch to deactivate the smart key system".
    These days if you want that feature --- P. 620 of the Gen 5 owners manual shows there is a customization setting to turn the smart key system on/off but it's not available until a dealer activates it. Then, I assume the option is visible to you to choose. My assumption there is backed by statements like P. 584 of the latest owner's manual talking about reasons your smart key may not work properly and suggests "Make sure the smart key system has not been deactivated in the customization setting. If it is off, turn the function on.".
    Without going that route, know that there are multiple levels of 12-volt battery preservation and not just one level of sleeping which Toyota subscription technical documents mention under "Auxiliary Battery Saving" that kick in when out of range of the fob to "preserve the vehicle and key batteries" which is "activated when the vehicle remains parked for a long time". Such as after 5 days the "Door electrical key antennas and electrical key antenna stop emitting signals for creating the actuation area" and after 14 days "Door lock sensors and unlock sensors for seats other than the driver seat are disabled". Pages 202-203 of latest owners manual speak to this too.
    Oh, and let's not forget if you choose to use a phone as a digital key you've now enabled bluetooth communications with your vehicle as another path to invisibly use your 12-volt battery. That's other electronics and antennas involved and listening which no doubt operate farther than the 2.3 foot range of the key fob antennas.
    mountaineer, VelvetFoot and Graham PR like this.
  15. dabluesman
    28
    17
    Eastern USA
    2024 Prius
    Limited AWD-e
    I've used the Carista app (with ODB2 adapter) to disable the car's "waking up" when the key-fob is nearby feature.
  16. BiomedO1
    4,608
    2,416
    Left Coast
    You do realize that Bluetooth adapter draws as much power; possibly more than the fob routine and is usually the source of parasitic draws along with dealer installed thief tracking devices for insurance purposes???
  17. dabluesman
    28
    17
    Eastern USA
    2024 Prius
    Limited AWD-e
    I guess it's a good thing that I unplugged the adapter after I was done using it..
  18. Hammersmith
    Hammersmith Senior Member
    2,490
    2,548
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You probably saw a video on YouTube titled: This SECRET Japanese Function Is Only KNOWN by 1% of DRIVERS (Use It Now!)
    Or at least the person who wrote what you saw watched that video. I'm not saying it's wrong, but that whole video is AI slop. I wouldn't trust anything in it as gospel without a second reliable source. It says that you enable Battery Guardian Mode on a Toyota by locking the doors with the fob, then immediately pressing the lock button twice more. According to this "source", the car should emit a different locking tone to confirm that Battery Guardian Mode is activated.
    The lock-unlock-lock(<5sec) method is for Subarus according to the video.
    edit: I just tested it a couple times and my car didn't make any special noises.
    #18 Hammersmith, Jun 12, 2026
