please read my future from these tea leaves (er, sparks plugs)... is it that time?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by viciousthinker, Jun 10, 2026.
  1. viciousthinker
    viciousthinker Junior Member
    28
    Houston tx
    Hi again all... ok, so I somehow got it into my head to pull my plugs this evening and see how they are fairing... my 2012 has around 280k on it now, and I live in a constant state of (fearing? longing for??) the final conclusion to Shroedingers head gasket. I've attached pics that show the pulled plugs lined up and numbered left to right... if any of the learned here could take a look I would appreciate it... I just don't know what I'm looking at. Numbers 1, 2, and 4 look like they gave somehow *RUSTED* down in the combustion chamber, that doesn't seem right to me...
    If it's time, I guess I'm ready. I have a new FelPro headgasket here on hand, torque wrench, timing kit w/ new guides, chains, and sprockets, engineers straightedge, feeler gauges, that weird ratchet attachment that helps to measure 90°, 180°, 270° rotations, etc... still a little unnerved by the timing chain procedure but if it's ready...
    Ps, I am cognizant of the fact that the outlier plug that isn't rusted is a proper DENSO, whereas the rusted ones are some third-party brand... but still, actual rust?
    Or not? I honestly don't know how to read these plugs
    thx in advance all..
  2. ETC(SS)
    7,519
    You're using a rectal thermometer to diagnose a sore throat.....
    Let's talk about why you pulled the plugs.
    Any other symptoms?
    You don't need a cat and a box to determine whether or not your head gasket has failed or not (or both....)
    Do a leak-down test......
    Check your coolant level regularly.....
    You live in TX, right?
    That means that there is a high likelihood that HAVE a borescope, or you know somebody with a borescope - and you've already done the hardest part......
  3. Mendel Leisk
    42,304
    When were they last changed; do you know? Toyota says every 12 years or 120k miles, whichever comes first.
    With your miles, their appearance, since you've already removed them, and doubly so if you don't know the car's full history, I'd just replace.them.
    Any cold-start shaking, coolant loss?
  4. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
  5. PriusCamper
    PriusCamper Senior Member
    13,427
    5,421
    Pacific Northwest, USA
    Your fear has taken over your imagination and you aren't looking at this objectively... That's not rust, that's combustion residue, which with that type of color means your engine is running a little hotter than before... As for the head gasket you aren't describing those symptoms in this post but you were in your post 10 months ago.
    As in, you're making everything way harder / doing a disservice to those trying to help you by starting a new post without referencing your previous post, as well as how many miles are on those plugs. Are we to believe that there's only 20K miles on these plugs or did you not swap these plugs out at 265K miles?
    What you need to do is buy a borescope that plugs into your phone (I bought a really nice one on tiktok for $8) and see what's going on in the combustion chamber. If cylinder 1 or 2 look way cleaner than 3 and 4 than yes, the head gasket failed and coolant is washing that cylinder.
    But again, you don't explain symptoms of a rough running engine in this post, but you do in previous which may of been an anomaly because you never explain how often it happened.
  6. Hayslayer
    Hayslayer Active Member
    529
    320
    Maybe the problem is you're using 3 Autolite plugs and one Denso?
    At least that's the way it looks to me.......................
    Bejesus......am I the only one seeing that?
    The Autolite plugs are obviously not hitting quite right based on the color. They should be Denso's, which looks to be hitting perfect..........
    The more I look, the more I laugh. They're not even the same heat range. Look at the length of the insulators..
    #6 Hayslayer, Jun 11, 2026
    frodoz737 and BiomedO1 like this.
  7. bisco
    52,806
    ^what they all said^
  8. Mendel Leisk
    42,304
    Good catch.
  9. Hayslayer
    529
    320
    yikes....just got home and happened to look at this again and the colors look a bit different than the laptop. The 3 autolites don't look horrible or anything, just different. A bit tan is ok, but I like a light gray like the Denso. Go with the Denso plugs so you have them consistent, you can't go wrong. Get that straight and then see how the car behaves.
  10. Mendel Leisk
    42,304
    Google AI’s got it right:
    3rd gen Prius spark plug info
    the Denso plug was revised to be slightly hotter. Owner’s Manual specs SC20HR11, but rev’d part no is SC16HR11.
  11. ChapmanF
    18,993
    The AI said "The spark plugs sit deep under the windshield wiper cowl assembly, which requires some plastic trim removal to access." which isn't the way I'd have said it, as the wiper mechanism and whole metal cowl need out, not just "some plastic trim".
    You could technically say the AI was correctly saying that "the windshield wiper cowl assembly" is what "requires some plastic trim removal to access". :) Right. Then you've accessed it, so you can start taking it and the wipers out next. ;)
    Unless your gen 3 is in one of the markets without the big double-jointed right wiper. Then you can just go straight for the spark plugs.
    There was more on heat ranges in ➡this post⬅.
    Denso uses the term "low heat range" (and a low number) to mean slower heat dissipation toward the plug shell—meaning a plug that stays hotter. They use "high heat range" (and a high number) to mean faster heat dissipation toward the shell, meaning a plug that runs cooler. So in Denso literature, "low heat range" means a hot plug, and "high heat range" means a cold plug.
    NGK avoids that mess by not even using terms like "low heat range" or "high heat range"—they say "hot heat range" or "cold heat range" (respectively!), instead.​
  12. Mendel Leisk
    42,304
    Concur. As my my daughter is want to say: “choose your battles”?
