Questions about AC
Discussion in 'Gen 5 Prius Main Forum' started by AndyRuan, Jun 12, 2026.
  1. AndyRuan
    AndyRuan New Member
    Waltham, MA
    2024 Prius Prime
    XSE
    Hello everyone,
    I know these may sound like beginner questions, but this is my first PHEV, so I’m still learning how everything works.
    I recently bought a used 2024 Prius Prime XSE and currently live near Boston, MA. With summer coming, I’ve noticed something that seems unusual about the A/C performance.
    When I park the car under direct sunlight for 3–4 hours, the cabin gets extremely hot. It seems to take a very long time for the A/C to cool the interior down. Previously, I drove a 2023 Toyota Camry Hybrid and a 2023 Chevrolet Corvette. In both of those cars, setting the temperature to 72°F would make the cabin comfortable, and 68°F would feel quite cold. Even after sitting in the sun all day, I would usually feel cold air coming from the vents within about 5 minutes.
    With my Prius Prime, however, things seem different. If the car has been sitting in the sun, I can set the A/C to 68°F and drive for 30 minutes, but the air coming from the vents still doesn’t feel particularly cold—it feels more like normal airflow. On the other hand, if the car starts out in a garage, the A/C performs much better and even 74°F feels cool.
    I also have a question about AUTO mode. My understanding is that the A/C compressor needs to be running to produce cold air. However, when I use AUTO mode, the A/C indicator light is not illuminated. Does AUTO mode automatically control the compressor even when the A/C light is off, or should I manually press the A/C button after enabling AUTO mode?
    Is this normal behavior for a Prius Prime, or could there be an issue with the A/C system?
    Thank you for any advice!
  2. Hammersmith
    Hammersmith Senior Member
    2,487
    2,545
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I can help with part of your question. AUTO does control the compressor unless you change it in the settings. So the light being off doesn't necessarily mean the compressor isn't running. But because your car is used, I'd check to see if the previous owner changed that setting. You access it by going into Settings on the infotainment screen(gear icon), then I think you scroll down to climate settings. There should only be one option on the page called something like "A/C to AUTO". If you set it to ON(the default), then the AUTO setting has full control over the compressor. If you set it to OFF, then you have control over the compressor(mostly) and it will only run when the A/C light is on.
    As for A/C performance, is your drive mode usually set to Normal or Eco? Choosing the Eco mode puts some restrictions on the climate system. The compressor will try to run at a reduced setting, and the fan will also be throttled down. If you're currently using Eco, try Normal for awhile and see if that makes a difference.
    A side note about the Prime is that the A/C system is also used to cool the HV battery. I suppose it's possible that the reason your A/C performance is reduced is because the HV batt is hot and the A/C system is struggling a bit to both cool the battery and the cabin at the same time, but I have a problem believing that. I've got to believe Toyota sized the compressor to be able to easily handle both. And it's not like you're living in Death Valley or something with temps above 110F.
    If you change to Normal and you're still getting substandard cooling, I'd consider having an A/C service done by a dealership. Because of the refrigerant loop that runs under the car and through the HV battery, there's an increased risk of leaks. Between the battery loop and the extra coil in the A/C box, I think the Prime has at least twice as many O-rings in its A/C system as a regular car. And there have been limited reports of gen5 Primes having leaks. It doesn't appear to be an epidemic or a systemic problem, but there seem to be enough anecdotal reports to at least keep an eye on things. Especially because a compromised A/C system could allow the HV battery to overheat and be damaged. And that could lead to a very bad day. But it's your call.
    Just make sure to ask about any costs for the A/C service before agreeing to it. The gen5 uses the new R1234yf refrigerant, which is VERY expensive.
    DigDoug, AndyRuan and Trollbait like this.
  3. AndyRuan
    AndyRuan New Member
    Waltham, MA
    2024 Prius Prime
    XSE
    Thank you very much for your detailed reply—it was really helpful.
    I usually drive in Eco mode, but after noticing this issue, I specifically tried both Normal and Sport modes to see whether the A/C performance would improve. Unfortunately, I didn’t notice a significant difference in cooling performance between the modes.
    I’ll definitely check the “A/C to AUTO” setting the next time I drive. I wasn’t aware that the previous owner could have changed that setting, so that’s a great suggestion.
    I also think your point about the A/C being used to cool the HV battery is interesting and could be relevant. In fact, during some of these drives, the cabin was getting so hot that even bottles of Kirkland or Poland Spring water I had left inside became almost too hot to drink. That makes me wonder whether the system could be prioritizing battery cooling or if something else is going on.
    In any case, I’ll bring it up with the dealer at my next service appointment, which should be in about two weeks (roughly 1,000 miles from now). Since the car is still under the factory warranty and is a Toyota Gold Certified Pre-Owned vehicle, I’m hoping any necessary diagnosis won’t cost much.
    Thanks again for taking the time to explain everything and point me in the right direction. I really appreciate the help!
  4. p3p5p
    p3p5p New Member
    22
    2025 Prius Plug-in
    XSE
    I own a 2025 PHEV XSE, and even in a recent heat wave with temperatures in the high 90s Fahrenheit, I got cold air within a minute or two even when the car had been parked in the sun. Yours does not sound like it’s behaving normally!
  5. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    I have noticed somewhat the same problem. I thought it very odd since my PHEV has less than 3K miles. Sure enough someone, apparently my silly arse turned the A/C mode with AUTO to the off position AND had the car in ECO mode. Just fixed it so hopefully when I leave the mill tomorrow I will be cooler than previous days.
