My daughter has had her Prius V for a couple year, purchased used. Last year there was a leak in the condenser up front and that was replaced and the system recharged. It worked fine until recently where of course now it's not cooling. I fired up Techstream and in Active Test mode I can ramp up the compressor speed to 7500 RPMs (as shown) but it doesn't make much if any different in the air temp. I can see liquid in the sight glass and the pressure sensor in Techstream shows about 150-155psi so it's not empty, though I'm not sure what that sensor reads normally. If the engine is on battery when parked and I turn the A/C on high the engine typicaly kicks on and it sounds like the compressor is buzzing, but again I'm not sure what's entirely normal on these vehicles since I know the compress operates differently. My next step is to spend $160 to have someone diagnose it, but I'm hoping from the description there's something obvious.
You could check the cabin filter and verify its not clogged or being used as a nest. Odds are its low on refrigerant based on the compressor is working (it stops with excessively low pressure) and the fact its cooling to 80f. Low refrigerant means there is a leak. The sight glass with a leak will show bubbles/ white foam occasionally or all the time depending how low it is. A manifold gauge and subcool calc is a better indicator of low refrigerant. If we want to speculate on something more costly, the air blend door could be bad allowing the heater core to add heat. Normally you can hear and feel the difference in air flow by switching between air flow modes. To verify the air blend door, increase the heat to max while air flow is set high through the dash vents. This should result in the blend door decreasing air flow and sound since flow is being diverted through the heater core. Partial foamy bubbles
Thanks, yeah my guess is low on refrigerant as well due to a slow leak. I don’t have gauges to check the pressure, was hoping someone else can confirm/deny what the psi should read in techstream.
There is no absolute psi number with a variable capacity compressor. In your case its still cooling and you don't have a max load. However with max load high pressures can be 300 psi.
A recent capture around your conditions showed 264 psi and an evap fin temp of 44f. Yours was 155 psi and 83f.
Picked up this gauge set today to check the high and low side, but it seems the Prius fittings aren’t compatible. Anyone know if there is an adapter for these? The kit comes with female (internally threaded) hoses, and the H and L pressure fittings on the Prius are also female, so there’s no way to connect without a male-to-male adapter. Since the fittings are center pinned I can’t just grab an NPT fitting or what have you from Ace hardware. https://www.harborfreight.com/r134a-ac-manifold-gauge-set-58776.html
The internal threads on the Prius r134a fittings are not for your gauge set quick connect coupler. Those threads allow the Schrader core valve inside the car's fitting to be removed with a special tool. R134a quick connects are much like a garden hose quick connect, male on the outside of the car fitting, and female on the gauge set fitting. The low side male fitting is on the right. You can see the Schrader valve inside. Do not try to remove the Schrader valve or your whole refrigerant charge will be lost and you could get severe freeze burns to your hand or face. Always wear gloves and at least eye protection!
From Harbor Freight manual Blue (L) and Red (H) are different sizes and therefore only quick connect to the matching L or H on the ac system. If this is your first time with refrigerant systems, consider finding someone who has done this before.
If you want to add a standard small can of r134a ($10 at Walmart) using your HF ac gauge manifold, you need this can to yellow hose adapter from Harbor Freight or elsewhere. Note 1: This is for the common self sealing cans, not the old style puncture cans. Note 2: The HF manual age 8 does not include a step to purge air from the manifold hoses prior to charging r134a. The purging keeps air and moisture out of the ac system. Note 3: Purging and the above adapter are not required to simply read pressures.
ah bingo, I was confused after seeing the schrader valve. I had no intention of removing it but I had the impression it was a push down pin and there was an intermittent fitting that was missing from this kit. yep first time. I’ve rebuilt suspensions, a ford v8 engine, done various electronic repairs, and I have the Toyota FSM. The fitting threw me off.
