Actual MPG vs. car's estimate, informative?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Jun 15, 2026 at 1:33 PM.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,973
    913
    Southern California
    It is well established that the car's cumulative MPG display is optimistic. (Car mpg displays tend to be pretty uniformly optimistic, across all models and brands.) Last time I filled up the actual (pump gallons/miles, same pump at preceding and current fill) was ~41 but the car said ~43. Which makes me wonder, is there any useful information in these two numbers? Or is there just so much noise (from variation in tank fill and variation in car's estimate) that no comparison actually tells us anything useful?
    52,671
    slightly useful, but I prefer long term averaging. when we go to Florida, there's quite a variation in each tank based on weather and driving conditions.
    after the 4,000 miles or so trip, I'm comfortable with the average.
    for a one tank trip, that fill up calculation is close enough for me. with a gen 2, you can usually get a good feel for the bladder with experience, and if it is filling to different levels at different times.
    BiomedO1 likes this.
  3. BiomedO1
    4,436
    2,332
    Left Coast
    By law; those numbers need to fall within + or -, 5%-10% of specifications, though most OEM will "juice" the numbers to land on the higher end of the standardized test. Their way of gaming the system. The same way OEM's claim their ATF is life-time; will last to the end of their warranty period.o_O:censored:
    I would trust a year long average of fill up tanks calculation averages over the built-in guess-o-meters. Luckily the MTE calculations are very pessimistic; as it should be.:whistle::love:
    YMMV
  4. pasadena_commut
    2,973
    913
    Southern California
    Agreed on all of that.
    I was mostly wondering if the two values could be used to detect a problem. I'm going to make up an example for discussion sake. Let's say that one injector isn't working great, but it isn't so bad yet as to trigger a code. The car is always driven under the same conditions (routes, speeds, temperatures) and its estimated mpg (Mc) falls from ~43 to ~42 but the physical gas added / miles traveled (Mp) falls from ~41 to ~38. Let's use the formula (Mc-Mp)/Mc for the metric we are checking. It rises from .0465 to .0954. Conversely, if there is nothing wrong with the car, but the accuracy of both Mc and Mp is +/- 1mpg the expected range of the metric is (44-40)/44 to (42-42)/42, or .0909 to 0.0. In which case the .0954 is outside the expected range, but only just.
    I guess that pretty much answers the question, as the accuracy is probably worse than +/- 1mpg, for both methods, at least at the single tank level. If it is +/- 2 mpg then the high value becomes (45-39)/45=.133, which is well past the "problem" case, and no way to see the signal through the noise. Also if the Mp on my car fell from ~41 to ~38 for no obvious reason, and stayed there, that alone would be enough to make me wonder if there was a problem, regardless of whatever Mc showed.
