Pressing PARK while moving! ?
Discussion in 'Gen 5 Prius Main Forum' started by Don_23805, Jun 12, 2026 at 4:53 PM.
  1. Don_23805
    Don_23805 Junior Member
    VA
    2023 Prius Prime
    I wondered what would happen if I accidentally pressed P while moving. A couple times while not quite stopped at the mailbox, I did this and it stopped abruptly! What if I was REALLY moving . . . tried this in the long driveway. Found that above about 2 mph nothing happens . . . button doesn't light, car keeps going. If I'm down around 2 mph, then it stops. Conclusion is that I don't have to worry about pressing it while going 70. FYI
    Don
    mva, mingc and VelvetFoot like this.
  2. ChapmanF
    18,874
    In my generation (gen 3), above the speed where it goes to park, I think it just beeps and goes to neutral.
    fuzzy1 and douglasjre like this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,297
    605
    Alberta
    2024 Prius Prime
    XSE
    I have not done that with my Prius, but in older vehicles, the parking pawl vibrates without locking into place. This is probably enabled by bevels on the holes in the locking mechanism. Newer vehicles, I assume, will prevent this happening while the car is moving at a speed which would damage the mechanism.
  4. douglasjre
    douglasjre Senior Member
    2,236
    745
    Null, NL
    Q's that don't need answering:
    1. What sound will my car make of driven over a curb at 60mph?
    2. What would happen if I put diesel in my Prius?
    3. What will happen if I put my car in park while driving on the highway
  5. ChapmanF
    18,874
    In a Prius where the P button is nothing but an electrical input to a computer that decides what to do, of course it's very simple. The computer knows how fast you're going, and won't do it when it doesn't make sense.
    In Prius gen 1 and (I think) Prius c, where the shift lever really moves a mechanical cable to the parking pawl, I imagine it is as in other cars.
    fuzzy1 likes this.
  6. Paul Gregory
    2,297
    605
    Alberta
    2024 Prius Prime
    XSE
    Easy to say, but have you tried it?
    I once accidentally hit the park button while I was still moving, and the car came to an abrupt stop.
  7. Paul Gregory
    2,297
    605
    Alberta
    2024 Prius Prime
    XSE
    I'll answer anyway:
    The worst sound you've heard in your life.
    Nothing
    Same
  8. ChapmanF
    18,874
    The behavior differs according to whether the speed is above or below a threshold.
    For any shift from D➤R, R➤D, or (anything)➤P, when above the speed threshold, the ECU instead beeps and shifts to N. (This is just as documented in the "Reject Function" section on page CH-18 of the gen 2 New Car Features manual, and also matches the behavior of my gen 3. If it has changed in later gens, I wouldn't know.)
    Below the speed threshold, the car will do what you told it. When shifting D➤R or R➤D, you get a very smooth effect (you're just changing which way electric motors are pulling). I do that routinely, finding the threshold to be somewhere around 6–7 MPH. A shift to P below the speed threshold can still make a jarring bonk, as you noticed. I don't do that routinely.
    fuzzy1 likes this.
  9. fuzzy1
    10,653
    I did in my 2010 and 2012 Prii. Many times over the years, to build up muscle memory in case I ever suffered the alleged Sudden Unintended Acceleration (SUA) that was afflicting numerous Toyota drivers back then. Similar to the runaway Audi 5000s a generation earlier.
    In mine, attempting to shift to either Park or Reverse at highway speed just produced a double-beep warning as the car instantly went into Neutral. In fact, shifting to R was the fastest way to get to N, as it skipped a built-in delay when intentionally shifting to N, or the even longer delay from holding down the Power button.
    There seems to be a threshold low parking lot speed below which the car will go into Park with a hard jolt, above which it instead goes Neutral.
    I did experience a severe-fatigue-induced "surge" or "runaway engine" in a previous car. Hitting the clutch was one of my two recovery reflexes that prevented a collision. With Prius lacking a clutch, I wanted an alternate path to immediately halting propulsion, so practiced shifting to R (and sometimes P, but this can't be done eyes-free reliably in the same manner as R) at highway speed. Though my old 'incident' was at parking lot speed.
    #9 fuzzy1, Jun 15, 2026 at 2:11 PM
  10. ETC(SS)
    7,430
    So it doesn't go into Neutral when selecting "P" at speed....?
    If so that's a change from my old G3.
    It's nice that you're sharing this with the community, but it's also one of the many MANY reasons I do not buy used cars.
    Good Luck with the journey!
    BiomedO1 likes this.
  11. BiomedO1
    4,437
    2,332
    Left Coast
    Yep; using the parking paw as a brake can jam or break something.
    I knew an old guy that used to throw his truck onto park before coming to a complete stop. This was an old manual articulating gear selection; no electronic lock-outs. His rear tires would squeak. Told him not to do that and he came back saying; "I've been driving longer than you've been alive". In any case; one time we were all camping in the sticks someplace and he couldn't get the truck in gear, out of cell service of course. We had to tie a tow strap to the truck to take the pressure off the parking paw gear; so he could put it into drive.
  12. Paul Gregory
    2,297
    605
    Alberta
    2024 Prius Prime
    XSE
    Just hold the start button until the engine stops.
    But you won't think of it unless you develop muscle memory for it.
  13. fuzzy1
    10,653
    That has a couple seconds of internal delay built in, and requires taking eyes off the road to see where the button is so the finger doesn't miss it. Remember the California Highway Patrol Officer Saylor crash, in a loaner Lexus in 2009, where the built-in Power-Off delay defeated his attempts at this response? Four people died
    Opening the hand wide to diagonally sweep the Gen3 gear shift lever left-up to Reverse, can be done more swiftly and surely by feel alone, and has no delay programmed in.
    #13 fuzzy1, Jun 15, 2026 at 7:53 PM
  14. TinyTim
    TinyTim Active Member
    403
    239
    Seattle
    The funniest driver ed story I ever heard. A student driver in the late 80's- early 90's was driving with the instruction. She decided to put the transmission into P for pass. The transmission agreed to disagree and dropped out from under the car. They don't make them like they used to. Cars have come along way from preventing stupid.
  15. ChapmanF
    18,874
    When the Barr Group analyzed the firmware (I think it was in a different Toyota, not exactly a Prius), they published findings indicating that one task ("Task X") running on the ECU could crash, and it was responsible for both throttle control and for monitoring certain driver inputs. I don't remember offhand if the shift selector input was one of those.
    So it may be good to practice more than one control action to try in an emergency situation. If you sweep the shifter to R and nothing happens—maybe because the task responsible for noticing is the one that has crashed—another approach, like the long power button, might be processed through another channel that's still working.
  16. TinyTim
    403
    239
    Seattle
    In an emergency situation should you lose control of your Prius. Throw the FOB out the window. It will lose contact with the car within 30-50ft and the party will be over.
  17. ChapmanF
    18,874
    Once a Prius is in READY mode, you can drive it as far from the fob as you want, until you turn it off.
    Brian1954 likes this.
