Prioritize recommended service
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Cee Mo, Jun 11, 2026 at 7:23 PM.
  1. Cee Mo
    Cee Mo New Member
    Thursday
    CA
    2021 Prius
    L Eco
    The dealership is recommending service of almost $1400 on the 2021 L eco I bought in 2024.
    Can anyone tell me the order of importance of each one so I can budget for them?
    Please just give me the numbers if you don't want to spend time saying why each one needs to be done (like, 3, 2, 4, 1 if that's the order of importance in your opinion).
    If you have some reasons for your priorities and feel like sharing them, please do!
    THANKS in advance!
    1. MAF Cleaner $150
    2. "Platinum" Fuel System Service $360
    3. Throttle Body Service $146
    4. Hybrid Fan Clean/Filter Replacement $366
    (The other items I will get done elsewhere are Alignment and Brake Fluid exchange which brings total to $1382)
  2. JC91006
    JC91006 Senior Member
    16,912
    8,633
    You don't need any of that stuff. You can ask the service adviser where in your owner's manual that shows you need those services. They won't be able to show you, cause they are selling you a bunch of nonsense on a 2021
    Cee Mo likes this.
  3. Tideland Prius
    16,656
    that’s it lol. Even then, if you want to save even more money, just buy the hybrid battery filter and replace it yourself (it’s under the rear seat on the passenger side).
    2 is definitely not needed. I’ve never needed 1 or 3 on any of my Prii (up to 100,000 miles on the gen 3 and 60,000 miles on the Gen 4).
    Cee Mo likes this.
  4. fuzzy1
    10,653
    We have never needed anything even remotely similar on the older non-hyrids that we kept more than 200,000 miles either. And they spent most of their lives back when fuel has dirtier and had fewer detergents than now.
    Cee Mo and Tideland Prius like this.
  5. Mendel Leisk
    42,165
    What’s the miles on it?
    FWIW, none of the services you’ve mentioned are in the Toyota USA maintenance schedule. Not to say they’re unnecessary, but some more pressing than others. Going through your list:
    1. MAF Cleaner $150
    ^ I’ve done that once. The sensor looked pristine; I gave it a few shots of CRC brand MAF Sensor Cleaner. It’s literally a 5 minute job; to charge $150 USD for that is larcenous.
    ^ Not needed
    ^ Good to do occasionally, say every 50k miles. Best to remove the throttle body’s hold-down nuts/bolts, lift it off with coolant hoses attached, for better access. Torque value for the nuts/bolts is quite low, 7 lb/ft IIRC<confirmed. quoted price is “ok”.
    ^ Good to do occasionally, especially if it’s never been done, just to see where it’s at. Doubly so if you regularly transport dogs, for example. It’s about an hours work for an experienced tech, price a bit steep.
    I would not bother with an alignment, unless you’re noticing something.
    Toyota USA says nothing about brake fluid replacement, but FWIW Toyota Canada recommends tri-yearly or 48k kms, whichever comes first. $150 USD would be a fair price, but those are hard to find these days. There’s a link in my signature on this, to give you some idea of the complexity. (On a phone turn it landscape to see signatures)
    #5 Mendel Leisk, Jun 12, 2026 at 10:15 AM
    fuzzy1, Cee Mo and Tideland Prius like this.
  6. Mendel Leisk
    42,165
    I've attached a (self-cobbled, not guaranteed) spreadsheet summary of the Toyota USA maintenance schedule for 4th Gen Prius, which is in the Warranty and Maintenance Booklet. If you're missing that it can be downloaded from Tech Info Toyota, under the Manuals tab. You can check the spreadsheet against the official, event-by-event publication.
    Something else to consider, that hasn't been mentioned, and is absent from the Toyota USA schedule, is a transaxle fluid replacement. Just my opinion: you can't do a first one too soon, say at 12 months or 10k miles. Then a subsequent change, say at 10 years or 100k miles. Should not cost more than $100~125 through dealership, but...
    #6 Mendel Leisk, Jun 12, 2026 at 11:36 AM
    Cee Mo likes this.
  7. Cee Mo
    Cee Mo New Member
    Thursday
    CA
    2021 Prius
    L Eco
    Welp, I can't post my response to you directly because I'm too new (have to have posted 4 times and be more than one day a member, neither of which I am yet).
    SO
    To MENDEL
    Thank you! Just turned over to 55K miles Got it at 43K 2 and a half years ago so I don't drive hard or a lot.
    Yes, the transaxle fluid replacement is on the list for 60k.
    This is so helpful. I have the encyclopedia - er, PhD textbook - er... manual - but finding what I NEED to know in all that is a little overwhelming since I don't speak auto anymore.
    Mostly I've searched online when I need specific help on something.
    But this list seemed weird since my 31-year-old Camry didn't need much of this at 100k, let alone 55.
    Thanks for all the links and info!
    To Fuzzy1, JC91006, and Tideland Prius =
    Great information and a relief to hear. Thank you all for answering and making things clearer
    Until 2.5 years ago, I drove my Dad's 31-year-old Camry I inherited, which needed a lot of these things so I'm a real newB with this car. I know dealerships are out to make a buck, but I was getting estimates on all these things from shops I've been to before, thinking all this was necessary. Maybe not all of it.
    Tideland Prius - thanks, they told me the air filter requires removing the back seats which is why it's so pricey, but you made it sound easy. I was a DIYer back when I had a little Corolla and could rebuild the carburetor and do my own oil changes and repairs. These days, 4 or 5 cars later, not so much. I'll look into it since it doesn't require computers.
    Thanks again, everyone!
  8. Tideland Prius
    16,656
    Interestingly, there's nothing in the manual about changing the filter yourself. It says to contact the dealer but I've changed it. Here's a picture from the manual on the location of the vent.
    Just be careful when you open the cover.
    Here's the relevant part from the manual:
    I guess they just want to you to vacuum it. But it is replaceable but yeah just vacuum first.
    Cee Mo likes this.
  9. Mendel Leisk
    42,165
    Seat removal “might” be for hybrid fan cleaning. I’m sceptical though. With gen 3 there was a video advocating removal of the rear seat bottom, but good lord, it’s for ONE bolt, and you only need to push apart the top an bottom of seat , you can see, and reach, that bolt, no problem. Maybe 4th gen has similar shenanigans. I’ve done our gen 3 a couple of times, takes about an hour. With your low miles, chances are yours is pristine, barring using the car as a dog taxi.
    #9 Mendel Leisk, Jun 12, 2026 at 11:29 PM
    Cee Mo likes this.
  10. Cee Mo
    Cee Mo New Member
    Thursday
    CA
    2021 Prius
    L Eco
    The shop where I took my 31-year-old Camry says it can do the Hybrid Fan Clean with Hybrid Fan Filter Replacement for $107.50 when the dealership said it would cost $365.84.
    Now I'm REALLY confused by the huge difference in price.
    It makes me wonder if the shop is talking about the same service the dealership is or if it really SHOULD cost only $100+.
    Any thoughts on this?
  11. Tideland Prius
    16,656
    It’s likely the labour cost. The filter itself is inexpensive.
  12. fuzzy1
    10,653
    That is part of how 'free market capitalism" works. Different businesses charge different prices for the same products and services, and the differences can be huge, especially in captive markets. Or in markets that function in a similar manner, such as car owners who automatically and unquestioningly have all work done at dealerships without shopping around. This is also how dealerships often earn the nickname "stealerships".
    Don't be bamboozled or bullied into their "upsells".
    Brian1954 likes this.
