Why doesn't the app indicate 12V battery level?
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Jun 15, 2026 at 3:02 PM.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,296
    605
    Alberta
    2024 Prius Prime
    XSE
    Since I've moved to my new residence, I've been left with a dead vehicle twice in one week, despite having driven the car the day before. I have a battery maintainer, but no way to plug it in. I am frequently faced with an inoperable vehicle due to "battery level too low," requiring a boost.
    Of course the stupid reply is always: "replace the battery" or "fix the parasitic drain." But both those avenues have been exhaustively pursued, hence the battery maintainer (and the boost-pack).
    This is a serious flaw with my Prius Prime. The battery can run down to a level which disables the car, sometimes within a few hours. A way to check the battery level from the app would be a helpful start.
  2. Brian1954
    Brian1954 Senior Member
    2,563
    1,014
    South Central PA, USA
    I assume you are talking about the Toyota app that connects to the car. I agree that a look at the actual 12v battery voltage would be a nice feature. Any questions about why it is not included in the app would need to be directed to Toyota. Maybe if enough people ask for it, Toyota will include it in the future.
  3. bisco
    52,671
  4. Hammersmith
    Hammersmith Senior Member
    2,424
    2,477
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    So, you want hardware and software running all the time to monitor battery state and communicate that info to the Toyota servers using the data communication module? And this is because you're concerned about the car using too much power when it's not in use?
    Does anyone else see the inherent problem with this idea?
    OP: Just have your battery tested again so that they'll tell you it's bad, you'll get a replacement under warranty, and we can put this to bed for a few months. Please?
    Brian1954 likes this.
