Heavy Engine P0302, P0304
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by bharghav9, Jun 10, 2026 at 6:35 PM.
  1. bharghav9
    bharghav9 Junior Member
    Austin
    2014 Prius v wagon
    Hi Prius Experts,
    Yesterday, when I started my 2014 Prius V (120k miles), it rattled, and shortly after that, the engine light came on. Today, I took the car to a showroom, and they charged me $189 for a diagnosis (I also called a local garage in Austin, and they quoted $190 as well). The Toyota service center informed me that there are misfires in cylinders 2 and 4, which occur only during initial startup. The codes they provided are P0302 and P0304.
    To diagnose the issue further, they are quoting an additional $500.
    I would appreciate your advice on how to proceed. I have kept up with all recommended services from Toyota, with the last service performed at 116k miles just a couple of months ago. At that time, Toyota did not mention any urgent issues.
    Should I pay the $500 for further diagnosis, or would it be better to consult a local service shop in Austin? If anyone can recommend a reliable Toyota service center in Austin, I would be grateful.
    Thank you!
  2. rjparker
    10,858
    6,821
    Bearden Automotive
    12402 Technology Blvd, Austin, TX 78727
    Independent Toyota specialist, better for diagnosis than a dealer but usually dealer pricing on repairs which is likely a head gasket or engine swap.
    Hometown Hybrids
    Austin shop
    Hybrid Battery Replacement & Mobile Repair | Hometown Hybrids
    Probably better repair pricing
    If you end up needing an engine and are willing to go to San Antonio, pm me ("conversation" w phone on landscape)
  3. bharghav9
    Austin
    2014 Prius v wagon
    Thanks @rjparker for the references. Before contacting the dealer, I called Bearden Automotive, and their price was the same. As a result, I decided to go with the dealer. I'll also be getting a quote from Hometown Hybrids. However, I am likely going to skip the additional $500 fee to the dealer and take my vehicle to Bearden Automotive for further diagnosis.
  4. bharghav9
    Austin
    2014 Prius v wagon
    I took my car to Bearden Automotive and had a pleasant conversation with Albert. The pricing seems to be comparable to what I would find at a dealership service center. I'm considering whether I should invest $6,000 to $7,000 for the head gasket repair. The car is in good shape, and I personally want to keep driving it for as long as possible. Should I choose a local repair shop or stick with the dealership?
    Please advice.
    Thanks in advance.
  5. rjparker
    10,858
    6,821
    Hopefully the diagnostic cost was low cost or free.
    As expected, dealer priced repairs. Actually those prices sound like a rebuild, not a head gasket. Which is what a dealer would do for $7k. Should include most if not all of this:
    1.8L HYBRID ENGINE 2ZR-FXE REBUILT MOTOR (GOLD PACKAGE)
    Otherwise a plain vanilla head gasket should be $2,500 or less to be a reasonable value. Dealers never recommend just a hg job on these engines.
    If you have not tried Hometown Hybrids, you should visit their shop.
  6. bharghav9
    Austin
    2014 Prius v wagon
    Thanks, @rjparker. I will try to obtain an email quote and see the actual work that needs to be done. I'll also check with Hometown Hybrids. Currently, the dealer cost is around $130, plus BearDen is approximately $200, and I believe Hometown is about $250. Normally, in the past, I would have traded in my car for a new one, but with car prices being so high right now, I don't want to rush into anything. I'm feeling confused about whether to go ahead with this expensive repair or not.
  7. rjparker
    10,858
    6,821
    Try to find out what Bearden did to diagnose. For $200 I hope they did something more than listening to you describe symptoms.
  8. bharghav9
    Austin
    2014 Prius v wagon
    Below is the diagnosis. They mentioned other than this car is good condition. And they were very nice.
    DIAGNOSE CHECK ENGINE LIGHT IS ON. SCANNED AND FOUND CODES P0300, P0302 AND
    P0304 FOR RANDOM MULTIPLE CYLINDER AND CYLINDERS #2 AND #4 MISFIRES. FOUND THE
    COOLANT RESERVOIR EMPTY OF COOLANT. TOPPED UP AND PRESSURE TESTED SYSTEM
    AND FOUND AN INTERNAL COOLANT LEAK. REMOVED THE SPARK PLUGS FOR INSPECTION AND
    FOUND COOLANT IS ENTERING THE #2 CYLINDER DUE TO A FAILED CYLINDER HEAD GASKET.
    REMOVE CYLINDER HEAD AND DISASSEMBLE FOR INSPECTION. REPLACE THE CYLINDER
    HEAD GASKET AND ALL RELATED UPPER ENGINE GASKETS. RESEAL TIMING COVER AND REPLACE
    FRONT CRANKSHAFT OIL SEAL. REPLACE ENGINE THERMOSTAT AND WATER PUMP.
    REPLACE SPARK PLUGS. REPLACE ALL VALVE GUIDE SEALS AND LAP ALL VALVES FOR PROPER
    SEALING.
    I will try to get quote from dealership and other local vendors. I heard from another vendor in Houston they mentioned they will generally do for 2500 but thats too far.
  9. rjparker
    10,858
    6,821
    They did a proper diagnosis and it sounds like an advanced case. Normally there are occasional rattles that clear quickly and no coolant loss for months.
    It really is important to know how long occasional rattling has gone on.
    Is this car relatively new to you?
    I would simply visit Hometown Hybrids and show the diagnosis. Another one is not needed. Ask what options they have, which is recommended and how much for each.
  10. bharghav9
    Austin
    2014 Prius v wagon
    Thank you, @rjparker. I spoke with Hometown Hybrids as well. They cannot perform the repair in Austin and asked if I can transport the car to Houston for the repair. They quoted 2500$.
  11. bharghav9
    Austin
    2014 Prius v wagon
    Normally there are occasional rattles that clear quickly and no coolant loss for months. :- Car rattled only one in while just during start. After that its smooth.
    It really is important to know how long occasional rattling has gone on. :- When I was driving I hear only during start that too once in a while. Not always.
    Is this car relatively new to you? :- 2014 Prius
