1. MichaelB126
    MichaelB126 Junior Member
    Phoenix
    I've been chasing this for a while. Previously, recently changed maf sensor, fuel injectors( beck arnley), and catalytic converter. Separate unrelated issue, dash cluster not working, i think its the known capacitor issue prius' have.
    On way to work this morning, while driving car shutters. Check engine light was on then flashing. Checked on Dr prius app. Said P0301. Reset code. Shuttering continues.
    Any guidance is greatly appreciated. Im stuck. Thanks
  2. JC91006
    JC91006 Senior Member
    16,923
    8,634
    If you have a code P0301 and you reset the code. It does not magically fix itself. You need to dig deeper to see what's causing that code and change the necessary parts to correct it
  3. MichaelB126
    Phoenix
    I understand. Any thoughts on what else I could look at?
  4. Mendel Leisk
    42,165
    Google's AI is telling me a flashing check engine light is more urgent, and to stop driving immediately.
    Just editorial: it's "shuddering", not "shuttering". :)
  5. JC91006
    16,923
    8,634
    Last time I encountered a flashing check engine light, the problem was a broken spark plug. You should check cylinder 1 on your car
  6. PriusCamper
    PriusCamper Senior Member
    13,329
    5,393
    Pacific Northwest, USA
    Move your ignition coils around to see if location of code changes... That's most likely the problem. Either that or you're two quarts low on motor oil.
