Gas Gauge Not Working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rick Grahn, Feb 5, 2007.
  1. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    I left a message with my local Toyota service department...no response yet. Here is the deal...
    Tank was 6/10 full (according to the dash light bar). Stopped, filled up tank (about 4.5 gallons) , drove away. The dash display (light bar) did not change. The MFD did not compeletely reset (showed MPG on bottom left, showed NOTHING on bottom right - where miles normally displays). I hit the MFD reset button and then the miles began showing up on the bottom right. Thinking I must have really screwed up, I stopped again and filled up again...it took about .25 of a gallon. Restarted. The dash light bar/gas gauge did not change, still showing 6 blips.
    Could I have a bad sensor in the tank? Is there some other reset I need to try?
    I have an '05 with 62,000 miles. I did by the 100,000 mile extended warrantee...hopefully this is covered.
  2. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    did the MFD reset to 0 miles when it started working again?
  3. klevitsky
    klevitsky Junior Member
    34
    I believe the right side of the "Consumption" display will show nothing until you go 1 mile, since it does not display fractions of a mile (like the ODO does). The fact that the MFD "Miles" reset shows that the car knew that you put gas in. Let us know if the blips display changes.
  4. Rick Grahn
    285
    Illinois
    The MFD did not reset to zero. It had nothing (not even a zero) in that location). Since this started showing up, I have filled the tank 4 times (every time I come home...just in case). The MFD does not reset, the dash is still stuck on 6 bars/blips. I have an appointment tomorrow morning for the car. My guess: bad sensor in the tank.
    Other thoughts.
  5. galaxee
    9,810
    469
    MD
    strange that the first time you put over 3 in there it didn't reset. did this perchance happen on a non-level surface?
    anything less than 3 won't get you any credit with the car though. provided we've got time to discuss (i'll admit this is not the case of late) i'll talk to DH about that tonight.
  6. Rick Grahn
    285
    Illinois
    <div class='quotetop'>QUOTE(galaxee @ Feb 8 2007, 11:08 AM) [snapback]386958[/snapback]</div>
    Regarding the non-level surface, if you are referring to when I filled it up (even the first time), I was at gas station...the ground was by observation level.
    Interesting though...yesterday things started working fine again. I thought maybe it was the bitter cold affecting it but the outside temperature was -2F when it began working again.
    Could something have been caught/covering the sensor? Would extreme cold cause the bladder to constrict in such a way to impede the function of the sensor? Is the sensor in the tank electronic or are their physical motion properties to it (ie. float balls, etc.)?
    Sorry for so many questions.
    FYI, after it started working I added a fuel cleaner to a tank full (those little red bottles at the gas station you can add to a tank to "clean the fuel system and remove water from the tank." I sure hope that does not damage anything.
    Thanks for replying. This is so odd I think people believe I am crazy.
  7. galaxee
    9,810
    469
    MD
    well the first thing a tech would have done is recal the inclination meter, which can get screwed up by filling on a non-level surface. the sensor is a magnetic float. if something caught it, you've got bigger problems than a nonfunctional gauge!
    since it works now, just keep an eye on it.
  8. Rick Grahn
    285
    Illinois
    <div class='quotetop'>QUOTE(galaxee @ Feb 9 2007, 09:48 AM) [snapback]387419[/snapback]</div>
    Will do!
  9. galaxee
    9,810
    469
    MD
    and just a note, don't add any more of that tank cleaner to your gas. it's probably fine after the one but with regular use who knows what'll mess up that bladder. it is touchy, as we all know well.
  10. Rick Grahn
    285
    Illinois
    <div class='quotetop'>QUOTE(galaxee @ Feb 9 2007, 11:14 PM) [snapback]387858[/snapback]</div>
    Thank you. I appreciate the expert advice and will follow your recommendation(s).
