Help on unusual symptoms p0a94-555
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Henrysprius, Apr 1, 2026.
  1. Henrysprius
    Henrysprius New Member
    San juan
    Hi
    I have a prius 2005 with code p0a94-555
    In indicates that is inverter but the car gets ready mode an it runs on battery ac and everything working in the hybrid part the car moves on batteryin all gears, but ice (internal combustion eng.) Not turning on It had the p1122 also change the part and code clear itself but not change in the other symptoms
    Ice. Stil not running .
    The only code is p0a94-555
    Thanks in advance
    Expeting your expertise can help on this
    Thanks
  2. Tombukt2
    13,836
    2,513
    Generally here you replacing the thing on bottom of inverter under gold plate with lots screws . Good luck getting that plate off . Faster to change whole inverter
  3. ChapmanF
    18,993
    Nope. That's also called a DC/DC converter, but it's the one that drops voltage to 12 volts for the low-voltage system.
    P0A94 is about the other DC/DC converter, the one that boosts voltage to 500 volts for the motor-generators.
    It's inside the inverter assembly, and replacing the inverter assembly as a whole still is probably the much easier way to go.
    The freeze-frame in the OP shows "Voltage before boosting" as 208 and "Voltage after boosting" as 207, which could be normal if the HV control ECU didn't want any boosting at the time, but would be a little disappointing if the system was trying to boost. In any case, the P0A94 code indicates the car can tell there's a problem there.
    The car may not be completely immobile with the boost converter out of commission, but it won't be happy.
  4. Tombukt2
    13,836
    2,513
    Yep another DC to DC converter anyway it is no cost effective to work on inverter . They're getting thrown out all over the country. Can probably find one you can have locally. That's not broken.
  5. Henrysprius
    San juan
    Thanks for the advice
  6. Henrysprius
    San juan
    Im trying to find a g9200-47121 i was told is a revised version for 2007 -2009
    Can it work on a 2005 prius
    Thanks
  7. Tombukt2
    13,836
    2,513
    I know it'll plug up I just got an 05 I'll probably try it if it fails. The Gen 2 inverter is pretty stout I haven't had any fail yet.
  8. Henrysprius
    San juan
    Happy Easter
    Found an inverter installed today
    Everythibg fine engine run no mil until I stopped the car in ready mode and the mil apeared aganin with different codes
    As follows
    Incude the hyb battery live info also
    I NOTICE ONLY 3 BARS ON THE DASH MONITOR and I think the batteries are full in the techstream.
    Thanks in advance
  9. Tombukt2
    13,836
    2,513
    And what is this the 05 inverter or you putting an 06 up in your 05?
  10. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    The third Techstream image attached shows the SoC at 48%, so 3 bars sounds correct.
    Brian1954 likes this.
  11. Henrysprius
    San juan
    Good day
    So what os the max limit in voltage per cel when is fully charge
  12. Henrysprius
    San juan
    Good day
    Yes I put a 09 on it they say is mor actualize
    Today I connect bsrvice plug and battery and the car moves without code , so neither engines are bad , tje question is rhe inverter can run and rhen give a code or when is done is done?
    May be one of uou had the same experience
    Thanks
  13. dolj
    dolj Senior Member
    8,635
    4,389
    Around 8.2-8.4 V. It varies depending on ambient temperature and the condition/age of the module. In my experience, if you are able to charge to voltages higher than that, it indicates a depleted module. A module that exhibits that trait will probably also charge and discharge faster than the others.
    Note: A module is made up of 6 cells. As the modules are sealed, it is not possible to do cell-level analysis.
  14. Henrysprius
    San juan
    Hi to you all
    About the car with changed inverter , everyrhing was good no codes until last week the car goes again with the limp mode again with the codes provided in picture maybe someone had the same issue and what could be the problem. Any advice will be appreciated
    I've change the 12 votl battery and inverter water pump working turbulence seen in tank
    Thanks in advance
  15. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    Look at the freeze frame data and tell us what the detail/INF code is. That will narrow down the trouble shooting process for the P0A7A code.
  16. Henrysprius
    San juan
    Here is the freeze frame data
  17. Tombukt2
    13,836
    2,513
    It's 309 sub
  18. Tombukt2
    13,836
    2,513
    They're saying this is isolation type fault business but apparently in MG or wiring etc .
  19. Brian1954
    2,668
    1,066
    Thank you. How many miles was the car driven after you changed the inverter?
    Based on the freeze frame data, it appears the car was stationary and the engine was not running when the code was triggered. Can you please describe what you were doing with the car when the code triggered? Was the car in Ready?
    There are not many parameters listed in the freeze frame data. It appears that the car was not driven after the previous code was cleared. The engine coolant temperature shows 0C which can not be correct. The +B voltage is 11.28V which is low. That is the reason I asked if the car car Ready. Have you tried clearing the trouble codes?
    The troubleshooting procedure for P0A7A with the -309 detail code looks to be very simple. You check the wiring harness that runs between the HV ECU and the inverter. Here is a link to the repair manual, DTC 309 — 2005 Toyota Prius L4-1.5L (1NZ-FXE) Hybrid Service Manual | Operation CHARM
    #19 Brian1954, Jun 18, 2026
