Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,755
    1,783
    Bay Area
    yep, that’s what we do too. One time I forgot and slammed the hood down and broke the filler cap because I forgot it was there :ROFLMAO:
    CR94 and Mendel Leisk like this.
  2. ASRDogman
    ASRDogman Senior Member
    7,977
    4,049
    I've been working on bicycles, motorcycles, and cars since the early 70's.... I've done
    a lot of stuff like that.
    Usually because I wasn't paying attention. Or "thought" I had already done something I hadn't.....
    Now that I'm antique, I'm triple checking EVERYTHING! :eek:
    Even a basic oil change, I keep the old stuff in sight so I knew I did it.
    I keep my 5qt jug of oil on top of the engine with the filler cap, just to be sure.
    I've never forgotten to put the oil in, but I had forgotten to drain it!
    Not of my car, a Mercedes. At least I didn't start it! When I check the oil level it was really high
    on the dip stick!
    NutzAboutBolts and Mendel Leisk like this.
  3. Mendel Leisk
    42,183
    When rotating the wheels, I put the torque wrench on the floor near the car. :)
    NutzAboutBolts likes this.
  4. NutzAboutBolts
    1,755
    1,783
    Bay Area
    :ROFLMAO::ROFLMAO: We’re clumsy lol
  5. Fostel
    Fostel Member
    99
    31
    Kent, England
    Excel
    He's done it.
    A bit of a hack job though
  6. Mendel Leisk
    42,183
    ^ Removal of the inverter coolant pump from below, WITHOUT removal of the inverter, priceless. Involved a little bending of the bracket. Maybe that could be avoided with a mod to the bracket, somehow make the bracket removable, replicate it with something removal some sort of trick. It'd be nice to just disconnect the coolant hoses at the pump too. Hmm.
    Fostel likes this.
  7. ASRDogman
    7,977
    4,049
    Wweelll, it kinda appears that he did it.
    He really didn't SHOW what he actually did, which is the important stuff.
    But at least it's a good reference. I'm sure it was "fun" to do. (y)(y)
    You don't have to start the car to get the inverter pump to run.
    Just press the "start" button twice, don't press the brake pedal.
    It "may" run with just one press, but I can't remember.
    I had watched a video years ago where he did something similar.
    And someone just loosened the bolts holding in the inverter and lifted it up.
    Without removing any of the high voltage lines.
    Fostel likes this.
  8. ASRDogman
    7,977
    4,049
    Thanks for posting it!
    Fostel likes this.
  9. NutzAboutBolts
    1,755
    1,783
    Bay Area
    Nice, at least it’s doable from the bottom. I’m wondering how many times it’ll take bending the bracket back and forth till it snaps off. I know we won’t be changing the inverter pump too much so who knows.
  10. Mendel Leisk
    42,183
    Maybe something other than bending the bracket, mod it in some way that it's still supporting the pump, and either doesn't block removal or can be removed. In the video he says it's aluminum, but looks like steel to me.
  11. NutzAboutBolts
    1,755
    1,783
    Bay Area
    would be crazy if someone made a 3D print of the bracket to have it pop off :whistle:
  12. Mendel Leisk
    42,183
    Maybe cut the existing bracket at these two narrow spots, then replace with brackets per the sketch. Or, just cut the bracket, rely on 2 bolts for stability...
  13. ASRDogman
    7,977
    4,049
    It's likely you'd only be doing it once. Unless you got a cheep pump.
    I was thinking of a bracket also. But if that 3rd bolt was accessible from the bottom, it wouldn't
    be an issue. Depending on where the hoses connect.
