Mourning the B52 crew
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Jun 16, 2026 at 7:48 AM.
  1. futurist
    futurist Member
    57
    157
    United States
    2024 Prius
    IYKYK. If you don't, then this wasn't intended for you :rolleyes:
    Gun owners buy and use Priuses too, fortunately for me anyway :D
  2. PriusCamper
    PriusCamper Senior Member
    13,335
    5,395
    Pacific Northwest, USA
    Yeah... hitting the ignore button on your profile so I don't see you anymore... All you gun crazed freaks are vile and wretched and way more likely to die by suicide.
  3. fuzzy1
    10,671
    Getting put on his Ignore list is often a blessing.
    futurist likes this.
  4. ETC(SS)
    7,446
    We may never know.
    There were 8 beans aboard....meaning 3 pax, probably.
    They were working out at Edwards on something with "testing" in the description - meaning probably 'Secret Squirrel' stuff.
    Weather was CAVU.
    There were the military equivalent of CVR/FDRs aboard.....but good luck getting those data.
    Pretty senior people aboard that bird - eh? ;)
    I'm guessing that the NTSB isn't going to be investigating this one - although the three extra pax may be a wildcard.
    The Buff is an extraordinarily safe bird, especially when you consider their age and the number of cycles they've amassed.
    We'll see.
  5. fuzzy1
    10,671
    Some other article mentioned that it was in the air about 3 minutes, executed a 180 degree turn, and at the end was 'descending' about 5000/minute, much faster than it should, 'landing' on a parallel runway from where it took off. I believe these details were taken from a flight radar system, not from any visual witness.
  6. bwilson4web
    16,493
    Grain of salt my friend.
    Edwards has to be one of the most heavily instrumented bases with cameras that probably captured every second of this doomed flight. Plus, any test would require a telemetry downlink. Ordinary air bases would not have the infrastructure at Edwards.
  7. ETC(SS)
    7,446
    Besides the ah.....interesting crew composition, the crash site is also interesting.
    It didn't 'mush in' like most aircraft at speed.
    What we see is a rather compact 'auguring in' suggesting a departure from flight from a stall or loss of pitch control.
    If we knew everything the USAF folks know the clouds wouldn't get much thinner.
    Scheduled flight duration?
    Fuel load?
    What was being tested?
    How many cycles for this bird?
    Lots of recent gripe sheets?
    Any weapons aboard?
    An all ossifer crew is ops normal for a BUFF.
    The USAF rolls like that - sending officers, if not senior officers into harm's way while the enlisted stay behind, but two 05s and three 04s is a little interesting for a 5-bean crew, along with the three civilians - but probably not the stuff of a Tom Clancy novel.
    They might have been testing anything from a new interphone system mod to a civilization (or drone) threatening death ray.
    Probably closer to the former given the dearth of standers-by.
