Featured California APPROVES Aftermarket Catalytic Converters!
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by fullylaced1, May 3, 2021.
  1. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    It just makes in infinitely more difficult to near impossible for non electrical engineers to finger out the schematics posted in forums or such, when the manufacturer proprietorially closes off all public access to specs for the model, ie: honda - as one example. Well maybe not infinitely impossible, but damned near close to it for anyone without prior knowledge and or enough experience to decode what the schematics are showing as well as the experience to comprehend the ramifications of the implementations of individual who figured out the original fix - descriptions and examples. Just a couple of variables to sus out individually.
    On something as easy as body codes, most anyone can sus the important parts fairly easily - relatively speaking.
    I'm by no stretch of imagination implying the automatic extended door handles was easy to sus out or for others to follow. What I am trying to say is that the stuff gets mighty complex for generalizations about what the status quo is on any one project for any one manufacturer is just fodder for argument at best.
  2. PriuSocal
    PriuSocal Member
    375
    62
    SoCal
    I just ran into this post and dont know how it evolved from CA approving some cats to Teslas lol. I for one knew someone who had a similar experience with a prius that had an aftermarket Walker cat that the prev owner purchased in a different state than CA for $800 and when they smogged it here, it passed with no issues and all he had to show was the proof of purchase. I guess it may have had the exempt number stamped.
  3. BiomedO1
    4,440
    2,337
    Left Coast
    Walker is one of two aftermarket companies that produce CARB compliant CATs, the last time I've checked.
    It's up to the smog shop to determine if it's CARB compliant. Most shops are too lazy to crawl underneath to do a visual check. If there's no current or pending CAT codes - it'll usually get a pass; minus $50 bucks out of your pocket for the inspection.
  4. mikefocke
    4,068
    1,855
    Sanford, NC
    Just got a NC inspection done for $13.50. 5 minutes. No smog. Just safety.
  5. AzusaPrius
    AzusaPrius Senior Member
    2,249
    939
    I am probably the only member here with the Magnaflow California cat.
    Been using it ever since I got it and have had zero problems.
    Yes its expensive and that is the only con the rest is all pros.
    I have a thread here, take a look if you want.
  6. PriuSocal
    PriuSocal Member
    375
    62
    SoCal
    The serious issue here in CA is very simple. They only wanted cats from Toyota or Magnaflow to be allowed by the CARB for purely money and power grab reasons and ZERO due to save the environment. CA has been trying to phase out older cars to make way for all electric ones which IMO will never happen. Now, back to the reasoning to my theory… The aftermarket cats do not have the same amount of “precious metals” as the OEM for thieves to steal your cat BUT your car will drive and function as an OEM even passing emissions (minus the visual) and you can also have the peace of mind that your cat will NEVER get stolen BUT, CA does not want this to happen. They simply invented CARB Mafia for control.
    Plain and simple, you have a Federal cat…your prius will pass emissions in CA (as long as no CEL is on) and its not causing any more harm than the OEM would and the whole prius/stolen cat fiasco ends. However, CA will never bow down to the consumer hence why people tend to cheat the system instead thus creating a vicious cycle of draconian vehicle compliance laws.
  7. Trollbait
    12,787
    The factory cat in the Prius is the same regardless of market. Toyota just certifies to a dirtier standard for costs and warranty reasons in federal states. A federal replacement will meet that federal standard, but may not be clean enough for the CARB standard.
    The precious metal content of the cat has been going done over the Prius generations as the tech was refined. The ultra low sulfur gas will allow it to drop further.
  8. BiomedO1
    4,440
    2,337
    Left Coast
    There's no conspiracy; ANY CAT manufacturer can pay for the extra testing required to get CARB compliance replacement status. Their part just needs to test as good or better than OEM. As far as I know, only two non-OEM manufacturers has done so; Walker n Magnaflow.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,553
    2,593
    Taylors, SC
    It probably is not the cost of making a compliant converter but the cost of the certification process.
    #129 Georgina Rudkus, Jan 20, 2026
    BiomedO1 likes this.
  10. hill
    9,001
    It certainly is that way in order to get the Underwritersl Laboratories (UL) SEAL. For this very reason, others start their own official safety purpose certifications
  11. BiomedO1
    4,440
    2,337
    Left Coast
    Yes; just like the ETL standard that is recognized as good as an UL label.
  12. TinderPrius
    TinderPrius New Member
    Today
    Here I am in June 2026 and my cat converter was stolen, didn't know that was still a thing. By way of internet, I'm learning about the CARB restrictions and the approved list of after market, CARB legal, yadda yadda. Seems that Maganflow is the only real approved manufacturer actually selling something for CA, and current pricing is around 3800 bucks for the flange to flange piece (suitable for a DIYer that doesn't weld). The cat only pieces (welding required) are around $2500, add shop costs for installation and I'm over $3000 (yes, Cali prices), and still have to confirm if these pieces come with the integrated heat shield (it's not shown in the product pics). Add to all that, I should buy the cat anti-theft shield. Just money and some DIY time, right??? Options? Not really. Walker website doesn't list anything for my Prius. There are other makers on CARB list but I haven't found them yet with my Duck Duck Go searches, so de-facto Magnaflow monopoly. It is frustrating to see other states have options as low as $128, but I'm on the hook for a lot more. Thought I got lucky with a $1500 price at an on line Toy parts dealer but Trust Pilot says to steer clear of them, and they don't exist on BBB. Calling my Toyota dealer today, and continuing WEB searches, and calling more local exhaust shops, due diligence. I would be happy with the OP price of $2000 back in 2021. My tale of woe for your reading pleasure. Vive la CARB.
  13. Georgina Rudkus
    3,553
    2,593
    Taylors, SC
    I would contact member AzusaPrius. He had a direct fit Magnaflow cat installed by Hybrid Pit of Buena Park, California several years ago.
    He posted a thread on the installed.
    You can see it, if you do a search.
