Gen 3 Prius Shows 1 Bar Of Battery Charge
Discussion in 'Gen 3 Prius Technical Discussion' started by PriusMan2010, Jun 20, 2026.
  1. PriusMan2010
    PriusMan2010 New Member
    Hello guys, sometimes my prius battery indicator will go down to 1 bar. Ive looked online, and the lowest Ive ever seen it online is 2 bars which seems normal (40% SoC). Why does mine go down to 1?
  2. ASRDogman
    ASRDogman Senior Member
    8,027
    4,073
    Is it the original battery? Mine did that when it got weak. It surprised me!
    And it would quickly charge fully, almost to the 2 tabs that indicate the terminals.
    Time for a Sodium Ion Battery Pack!
  3. PriusMan2010
    Yes, its the original battery that has about 350k miles on it.
    I heard about that pack, I wonder how much better it is vs the standard NMH battery
  4. ASRDogman
    8,027
    4,073
    I'm running it, it's GREAT!
    Very light, easy to install. It hold the charge much longer. You can run in EV longer than
    the oem battery.
  5. Alexikor
    Alexikor Junior Member
    36
    Arizona
    when did you install the sodium ion pack, and how has it improved your driving experience? any significant difference in mileage?
    i'm considering replacing the oem one when it dies, but the oem one is actually $400 cheaper than the sodium ion pack. plus i know i'll get ~250k miles from an oem pack. the sodium ones look attractive than oem- more power for longer EV use, about 45lbs lighter, slightly more overall power, but i've seen too many good things about it
    #5 Alexikor, Jun 21, 2026
  6. ASRDogman
    8,027
    4,073
    I gained about 5mph in the city. I averaged 38mpg, but had to drive easily to get it.
    I can now drive normally and get 42mpg without trying.
    On the highway, I had to drive easy to get up to 65mph, but usually kept it at 64 or 63 and
    averaged 44mpg.
    Now I can drive normal, or a little faster and drive 65-67, and get 48mpg. If I can draft behind
    a semi, I can get 52.
    I'm driving a little faster and more sporty, and get the mpg I did driving carefully with the oem pack.
    It would be a decent "guess" that you would get close to the mileage out of a replacement pack
    and you did with the original one. "IF" the blocks are NEW. No one seems to know if they are new
    ore "refurbished. Until you take it apart. But they might have stickers on they to seal it and if they are
    broken, you loose the warranty. Which is only 2 years. Unless you have to dealer install it. Then it's 3.
  7. frodoz737
    frodoz737 Top Wrench
    4,790
    2,557
    33
    Respects, but your car has 350K miles on it. Consider the big picture at this point.
  8. Alexikor
    36
    Arizona
    so the oem battery is basically a collection of reconditioned packs? i don't see "new" or "reconditioned" in the item description on their parts website
    how long ago did you install the sodium-ion battery?
    gains of 5mpg are impressive. is that throughout all seasons? would really help my summertime mileage in AZ
    not sure who has the 350k miles. i'm chugging along at 222k and no HV failure, yet
  9. ASRDogman
    8,027
    4,073
    Info is in the message...
  10. Alexikor
    36
    Arizona
    you didn't provide a date or time when you installed the sodium-ion battery
  11. frodoz737
    4,790
    2,557
    33
    OP stated his in post 3.
  12. Alexikor
    36
    Arizona
    this seems to be creating confusion - in my first reply in this thread, i asked ASRDogman when he installed the sodium-ion HV battery in his prius, he hasn't answered that yet.
  13. Brian1954
    Brian1954 Senior Member
    2,651
    1,058
    South Central PA, USA
    All Toyota OEM hybrid batteries purchased at a dealership are NEW. I do not know what ASRDogman is talking about in his post
    Alexikor likes this.
  14. Brian1954
    2,651
    1,058
    Yes, it is because you highjack the OP's thread.
  15. ASRDogman
    8,027
    4,073
    I installed a Prototype to test it in September 2024, and put 22,513 miles with it.
    And installed the final version in August 2025 and have put about 12,000 miles or so on it.
    I not driving as much as I used too.
    Here is Florida, we has some freezing weather, for a change. But a lot of 40's weather.
    NOT issues with the Sodium Ion battery. And HOT and extremely high humidity the last few years.
    Still, no issues. It certainly holds it charge longer. I can drive in EV a lot longer!
    The charge/discharge cycle is very smooth.
    It's very light. I lifted it EASILY by myself. I had to have help getting oem one out.
    It is certainly a lot safer! Jack is a Great Help!
    It should last as long as the original. Realistically, how much longer will you be keeping the vehicle?
    Mine is a 2010, and I'm antique, certainly the car will last longer than me. But if the next person takes
    as good care of it like I did, it should last at least 10 years.
