How long before that new car is just a throw away item?
Discussion in 'Fred's House of Pancakes' started by T1 Terry, Jun 18, 2026 at 4:32 AM.
  1. futurist
    futurist Member
    57
    162
    United States
    2024 Prius
    My gen-1 Paseo was 20yo when sold in WA for $200 to the kid of a friend of mine -- had 285K, on the original clutch, and still got 35 mpg.
    There was a JDM 1.3L turbo version of that car's engine (4E-FTE) that bolted right in, provided you had the right ECU and pigtail harness adapters -- could take a lot more boost than OEM, as in 180 wheel hp with no real hit on reliability. Back when I was thinking about it Y2Ks... getting a 4E-FTE shipped from JDM cost as much for shipping as the motor / trans, something crazy like $600 shipped. So you could have a 180 whp, 2000-lb-soaking-wet FWD rocket roller skate, for $600 and your own labour to drop the drivetrain in (probably needed an LSD and shorter gearing from a Starlet C52 5-spd, whilst we're dreaming :p )
    Could kick myself for not going for it in Y2Ks, would've been a terror to the BMW crowd of the Dubya years :D
    Isaac Zachary likes this.
  2. ETC(SS)
    7,456
    #22 ETC(SS), Jun 19, 2026 at 5:15 AM
  3. futurist
    futurist Member
    57
    162
    United States
    2024 Prius
    What gets me about the '4-cylinder turbo to replace V8s' path in up-to-half-tonne in the States... is the reason why mfrs added cylinder count in the first place, early 20th century.
    Ford had lots of Fours in the early 20th century -- selling them as fast as could be built. But the issue with Inline-Fours, is they only get a combustion stroke in two places in a crank revolution. When Ford introduced the Flathead V8, that added two more places on the crank, torque could be applied... and thus gangsters bought them up :p
    This is why 60-deg V12s feel almost effortless under throttle -- you have six places on the crank each cylinder is applying torque, smoothing out the delta between them. Trucks that haul or climb w/ 4WD need this torque, thus the ubiquitous 90-deg V8 in most passenger gas applications.
    But when you turbocharge an I-4... all you do is increase the amt of push, until the next cylinder can fire, 180-crank degrees away -- making the delta larger, not smaller. Compound this with the extra heat... and this is why turbocharged Fours don't last all that long in HD hauling or climbing applications -- they have to be spinning pretty fast for those deltas not to catch up with you.
    Toyota's V8s used to be loafing at their purpose for being. This new turbo V6 isn't going to inherit the legacy of Toyota V8s, for many reasons but for this discussion, due to this focus on short-term-gain on emissions, at the cost of being far less reliable and long-lived for the people buying 4WD trucks. It's better than making a Four do Tundra work... but only going to get worse before petrol ICEs are phased out entirely.
    BiomedO1 likes this.
  4. T1 Terry
    T1 Terry Senior Member
    950
    527
    A vehicle bought after around 2023 will have clearances for bearings etc, so fine a human hair wrapped around the crankshaft journal would cause a locked engine.
    Gone are the days when just adding thicker oil would increase the oil pressure and quieten the engine noises, 0W thickness oil has problems circulating on start up, try running one of the reliable older 6 or 8 cyl on 0W - 20W oil, it would be battling to make oil pressure cold.
    Here is a late model Toyota engine teardown
    and another by "I do Cars"
    that I enjoy watching to see where the internal combustion engine is headed .... and it doesn't look good for it still being sold in new cars in the foreseeable future .... emission and fuel economy demands will be the end of them ....
    T1 Terry
  5. ETC(SS)
    7,456
    FOMOCO and RAM both cried "Not in the face!" a couple of years ago...and promised to kill off the V8s.
    GM has quietly kept 5.3-liter and 6.2-liter V8s in their lineups.
    Markets do respond.....
    #25 ETC(SS), Jun 20, 2026 at 1:09 PM
  6. futurist
    futurist Member
    57
    162
    United States
    2024 Prius
    And it's nice that these LS-based V8s are some of the best available to Everyone. Salvage yards are teeming with loads of iron- and aluminium-block versions from dead trucks and vans to pick from, up to 8.1L (496 ci) if you're lucky.
    Selling ludicrous 1.2L-turbo crossies like the Envista may be off-putting to anyone wanting to merge with 3 people aboard onto the freeway w/o foot to wood (11-sec 0-60 with one 200-lb driver, when a Civic with an Atkinson-cycle 150bhp NA 2.0L, does it in 7.7), but man do their CAFE sacrifices make way for 6.2L and smaller LS V8s to stay (in every new V8 GM truck and Corvette, plus the 5.5L flat-plane-crank one in baller-spec Corvettes).
  7. T1 Terry
    950
    527
    Our MG4 51kwh poverty pack EV does the 0 = 100km/h in 6.2 secs, the MG4 XPower does it in 3.2 secs, and not a scrap of emissions, even from the tyres if the traction control is left switched on .....
    The new V8 engines would survive if the bearing clearances were increased and all the nonsense with cyl deactivation was scrapped. Add a hybrid transmission like the Lexus GS450h uses and a decent capacity LFP or sodium ion battery pack and the ability to drive in EV only around town, and the V8 towing capacity of the Australian version of the 1500 Ram with the towing capacity of 5.5 tonne (10,000 lb) would make it great as a local run around and a serious tow vehicle that would meet emissions with an engine that would last the distance expected of a decent V8. That incredible low down torque of the Lexus L110 transmission in low range and 350kw output without the V8 even turning, would make it great off road vehicle as well .....
    I wonder if anyone will start to build the Glider Cab models of the favourite V8 trucks of days gone by with a decent spec V8 that will go the distance and an EV 2 sp transmission behind it, ending the drought of muscle trucks that last the distance and don't cost the earth to run and maintain.
    T1 Terry
  8. Isaac Zachary
    Isaac Zachary Senior Member
    2,762
    1,482
    Customers saw the V8 and thought "8 is better than 4 or 6." But that's not the point. The benefit of a V8 (at least that of a cross-plane crank V8) is it has the engine balance of an inline 6 cylinder but is about as long as a 4 cylinder. Today we can get around a 4 cylinder's secondary imbalance making the V8 obsolete. We can even reduce the vibrations from a 3 cylinder enough to make that feasible.
    Trollbait and T1 Terry like this.
  9. T1 Terry
    950
    527
    Many yrs back, the heavy haulage truck engines went to electronics and high boost turbochargers and even series turbo charging in the case of the last Cat highway engine, and the big V8 normally aspirated was replaced by an inline 6 cyl with half the capacity, yet made the same torque and horse power ...... but the reliability and million mile rebuilds vanished. When the smaller engines failed, it wasn't an in chassis rebuild, it was a replacement engine, the block and heads were stress fatigued and the crankshafts were either cracked or twisted .... so those that had to repower went up to the bigger capacity engines so they didn't have to work as hard.
    Then, for some reason, the car manufacturers didn't seem to learn from the truck engine builders, and decided a twin turbo V6 could put out the torque and horsepower the big capacity V8 did, with no penalty in reliability, and at the same time reduce clearances down to high performance European performance engine specs, yet churn them out at a faster rate and with less craftsmen, because they said so from the shiny arsed suits sitting a boardroom having never actually pick up a spanner or ever got their hands dirty .....
    It can't be fixed at the major manufacturer level, they are run by accountants and engineers drawing and test cell results for products built to blueprint tolerances, and expect the mass produced product to work the same. The over built by 50% has gone because the engineers no longer actually get their hands dirty, they go straight from their uni degree to the corporate office and completely miss the trip through the workshop the old school engineers who built the reliable engines had done.
    The internal combustion engine could have lived on for a few more decades as personal vehicle power units, with just a bit of " listening to the techs that work on the things during their preproduction testing, but who wants to buy a petrol powered truck that gets blasted into the weeds by an EV and spends at least half of the first 12 mths at the dealers workshop because it fails to proceed and needs a tow truck .....
    Once the current govt has been sent packing and the gates open for EV's from China to flood the market, the one track minded vehicle boardroom built dinosaurs will go straight from the car lot to the recyclers ......
    T1 Terry
  10. Isaac Zachary
    2,762
    1,482
    I don't believe the number of cylinders changed the longevity of those engines. There are plenty of 6-cylinder and 4-cylinder engines with plenty of power that have extremely long-life track records. Most of the million-mile engines that I'm familiar with were 6-cylinder, not V8s.
    The problem is that now we have computer simulations that attempt to design parts that last at least as long as it takes to keep customers happy while at the same time costing as little as possible. In the 80's and 90's everything was overbuilt and sometimes lasted seemingly forever as a result.
  11. T1 Terry
    950
    527
    Agreed, but you can't expect a V6 that originally develops 100hp on a good day, that now develops over 400hp and the clearances are a fraction of what they were back then in an attempt to squeeze the max fuel efficiency, to last as long as the original did .... but you would at least expect them to make it out of warranty ......
    T1 Terry
  12. Leadfoot J. McCoalroller
    8,236
    7,739
    Pennsylvania
    2018 Prius c
    It may help to understand that the Japanese government desired that status, and worked to cultivate it.
    Taxes on automobile registrations are relatively cheap for new cars in Japan, and then they rise after a few years. They get to be rather extortionate on older cars. If you see someone in Japan driving around in a 15 year old car, know that they paid through the nose to hang on to that relic.
    Why?
    They wanted to have extremely low pollution from auto emissions.
    They wanted the best road safety.
    They wanted to stimulate and support their domestic auto-manufacturing industries.
    So the tax structure is very deliberately stacked to encourage short first ownerships. Then those cars are shipped overseas, which has created very large markets for gently used Japanese cars all over the far east.
    Think about how little maintenance the average modern Japanese car actually needs- especially when operated on an island by people with relatively low personal mileage needs: They aren't exactly skipping out on very much. Those cars are still in fantastic condition.
    Trollbait and Isaac Zachary like this.
  13. Isaac Zachary
    2,762
    1,482
    Of course. But they don't have to take an engine designed to output 100 hp and make it into a 400 hp engine. There are 6 cylinder engines designed to produce 400 hp or more designed from the ground up.
    Cylinder count has very little to do with power output. You can make the cylinders bigger, for an example. There are V8s designed to output 100hp and turning those into 400 hp engines would also affect their longevity.
  14. Trollbait
    12,789
    Back to the OP on disposable cars, I felt that was going to be the outcome of fuel cell cars, at least the hydrogen fueled ones. PEM fuel cells were losing output faster than ICEs over time. Then the very high pressure vessel that is the fuel tank had a set lifespan. The maintenance and replacement costs might be something acceptable for commercial vehicles. They won't be for most private car owners.
  15. futurist
    futurist Member
    57
    162
    United States
    2024 Prius
    probably why it wouldn't have passed muster for most buyers, even ignoring the infrastructure issues and meager range and power density. At least when one hasn't been gaslit (hurr-hurr) about practical limitations of fuel cells, no one would've bought one if it only lasted 4 MYs before you had to buy another. Or lease... would probably be the sugar for the medicine.
    #35 futurist, Jun 21, 2026 at 11:02 PM
  16. ETC(SS)
    7,456
    I talked with a tech who was issued an H vehicle - either in Nawluns or Mobile - don't remember which turf.
    I'm thinking it was not the Honda CR-V e:FCEV or Mirai because he complained about a 200 mile tank range and a longish amount of time to load fuel - and I'm thinking that I read that the car FCEVs were easier to refuel.
    It worked out well for him.
    AT$T is pretty famous for keeping their fleet vehicles until they are well past their economic lifespan - and he got another car after only a year or two.
    I have the second newest vehicle in our group and it's 6 years old and rapidly closing in on 100k.
    It was a manager's car for a few years - otherwise it would already be well over 200K.
    Face it.....todays cars even the 'crappy' domestics are not very 'disposable' as I understand the meaning of the word.
  17. notspam3
    notspam3 Member
    126
    67
    Toronto
    2024 Prius Prime
    XSE Premium
    It's all perspective. To me cars ARE disposable items like toilet paper. Use them a while then get rid of them. Some brands last a little longer, some brands have a higher operating cost (read cost of ownership). Using a $100 bill to wipe your @ss doesn't make it any better than two-ply Cottonelle.
  18. ETC(SS)
    7,456
    That's fair enough but for some people cars are a little bit more than the sum of its parts.
    I include myself in that group.
    Think about it.
    GM used to run an ad campaign that went something like:
    "It's not just a car, it's your freedom!"
    That thought has provoked divided sentiments since long before those 35+ year old ads were first published.
    https://www.washingtonpost.com/archive/lifestyle/magazine/1989/01/22/ - under the hood the depths of ignorance
    Henry Ford.
    A man with, literally, an 8th grade education.
    Industrialist. Business Magnate. Granted well over 100 patents.
    Inventor of......nothing.
    Credited with being a genius AND dull witted - depending on what YOU see in the ink blot.
    (The story of his first quadracycle not fitting through the shed's doorway is not made up!)
    Probable racist, misogynist, somewhat ineffective strike breaker.
    Proven eugenicist and antisemite - although the latter prejudice is still widely accepted even today!
    Admirer of Hitler.
    The REAL one....not the greatly diluted one that idiots point to today.
    Although it's impossible to discern whether or not it's HIS original thought, Henry Ford is credited (or blamed) for the following quote:
    "I will build a motor car for the great multitude. It will be so low in price that no man making a good salary will be unable to own one — and enjoy with his family the blessing of hours of pleasure in God's great open spaces."
    People today have no idea how democratizing that is - or that now almost any person that can enjoy the autonomy of individual transportation.
    That's right - poor people now drive too.
    EVEN some of the most wild-eyed leftists, hopelessly captured by the "Outrage Industrial Complex" will quail at the thought of 'Big Brother' tracking their automobile - or depriving them of the ability (freedom) to travel, although unlike SOME FREEDOMS, this RIGHT is unenumerated.......and thus unprotected by phrases like SHALL NOT BE INFRINGED......... :D
    I've said often in this forum that one of the forks in human development might result in cars being more antonymous.....and people less so.
    Your first clue will be the absence or presence of things like throttle and steering in YOUR car.
    OR perhaps whether or not somebody can remotely disable YOUR car......or just monitor where YOU are going in it........ :unsure:
    #38 ETC(SS), Jun 22, 2026 at 10:03 AM
  19. Trollbait
    12,789
    You aren't passing that toilet paper along to someone else once you're done with it. Meanwhile, a new car isn't going to the scrap yard after 3 to 5 years because the first owner is done with it. Neither is it crushed cause it needs new tires or brakes.
    Razors are the better bathroom item analogy. Cars are like safety and cartridge razors. The costs to keep using the razor vary between models, but when the person is done with either, another person can keep using them. When talking disposable cars, it means like a disposable razor where the entire thing is thrown out after one person uses it.
    futurist likes this.
  20. ColoradoBoo
    ColoradoBoo Senior Member
    1,323
    939
    Monument, Colorado USA
    In a land of disposable everything, I guess I'm still old-school.....just fix it!
    In late April, my old Toro front-wheel drive lawn mower decided not to drive, anymore, and was running pretty bad (surging and being hard to start, even after being warmed up) so I did some research and picked up a new Toro rear-wheel drive Max Recycler with the Smart Stow, which his pretty handy in my small shed. I wanted the model that allows you to keep it running but shuts off the blade, to make dumping out the bag faster, but that model looks to be very popular and Toro didn't even offer it on their website and no Colorado dealer had one in stock (or many other models...I ended up buying the thing from a Lowes that only had 2 left in stock.)
    Anyway, the old lawn mower was sitting there so I figure why not learn about working on small engines? Downloaded the schematics and ordered a new carb, drive belt, traction cable, air filter, and blade. Spent a few weekends tinkering and she ended up running like new. But she doesn't fit in my shed so listed her on Facebook Marketplace for $125 and got 6 guys asking about her...one offered me $80 sight unseen and a few wanted to look at her so I got a guy over yesterday who check her out and offered me $120 cash. (Maybe I should've asked for more? But glad she's not going to the landfill.) I have a bad back so the idea of bending way down to work on the thing wasn't desirable so got her up on my Quick Jack and raised her up about 4-feet....much better height!
