Help me decide if I keep or return newly purchased 2020 XLEe (Dr Prius data)
Discussion in 'Gen 4 Prius Main Forum' started by Bilbo Goggins, Jun 21, 2026 at 4:15 PM.
  1. Bilbo Goggins
    Bilbo Goggins New Member
    Yesterday
    Massachusetts
    2020 Prius
    XLE AWD-e
    Hello, new owner but still in the 7-day return window, trying to do my due diligence before Wednesday when purchase would become permanent. Vehicle is 2020 XLE AWDe with 38k, one owner with dealer service history
    drives well, MPG says 55.5 mpg, battery filter is clean. Previous owner told dealer that car had sat for over a year between early 2025 and 2026; dealer replaced 12V at that time
    Ran Dr Prius via a Veepeak scanner and have the data below. I wasn’t able to complete the life expectancy test (possibly because of AWDe model as per another user?) and it read about 30-35% driving around which is concerning albeit inconclusive since I couldn’t complete the test.
    is there anything that can be drawn from the other Dr Prius data below?
    Should I take it to the dealer/hybrid mechanic for an expert opinion? Thanks
  2. JC91006
    JC91006 Senior Member
    16,924
    8,635
    The hybrid battery is under warranty and sitting for a year usually won't harm that battery.
    BiomedO1 likes this.
  3. BiomedO1
    4,443
    2,341
    Left Coast
    If Massachusetts is a CARB state that traction pack has a 10yr or 150K mile warranty, otherwise Federal warranty is 8yr or 80K miles.
    Dealer doesn't care what Dr Prius states; traction pack needs to throw error codes; before they will do anything about it and most likely just erase the codes to see if they return.
    Good Luck....
    Merkey likes this.
  4. bisco
    52,694
    how many miles on her?
  5. Brian1954
    Brian1954 Senior Member
    2,587
    1,028
    South Central PA, USA
  6. bisco
    52,694
    is it a nimh battery?
