What happens when your battery goes dead?
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Jun 22, 2026 at 5:06 PM.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,318
    607
    Alberta
    2024 Prius Prime
    XSE
    I had it happen when I parked the car for a few weeks, and for some reason, the battery maintainer had turned itself off. What I got was a taste of what would happen if I had used a battery disconnect. I don't ever want to go through that again.
    The car did nothing when I pushed the start button; the battery was truly dead. I eventually boosted the system to get it started. Not only did I have to go through all my settings, I had to sign into the system and even resubscribe to a service I already had. Inconvenience is not an adequate word.
    For those not here to flame me for whatever I say, I am sharing my experience so that it could help someone in a similar situation.
    52,694
    that's awful. on the older pri, you might lose radio presets or window function, but not always
